Test/review of Vapcell INR18350 1100mAh (Purple)
26 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 3 days ago
DSC_5789
Official specifications:
  • Model: INR18350
  • Size: 18.1*35.0mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50v
  • Typical Capacity: 1100mAh (0.2C discharge)
  • Min capacity: 1000mAh (0.2C discharge)
  • Weight: Max:26g
  • Internal resistance: Max:25mOhm
  • Standard Charge: 500mA,CCCV 100mA cut-off
  • Charging Time: 3hours(standard charge)
  • Quick Charge Current: 1500mA
  • Max Continuous Discharge Current: 10000mA
  • Operating Temperature: Charging, 0°C ~ 45°C, Discharging: -20°C ~ 70°C
  • Storage Temperature: -5°C ~ 35°C
  • Storage Humidity:
  • Standard environmental conditionTemperature:23±5°C
  • Humidity: 45-75%RH
  • Atmospheric Pressure: 86-106KPA
Vapcell%20INR18350%201100mAh%20(Purple)-info
A high current and high capacity 18350 cell.
DSC_5788
DSC_5790 DSC_5791
DSC_5792
DSC_5793
DSC_5794
Vapcell%20INR18350%201100mAh%20(Purple)-Capacity
Up to 10A (Rated maximum current) the discharge curves look good, the overload at 15A is not as nice.
Vapcell%20INR18350%201100mAh%20(Purple)-Temp-10.0
Temperature stays reasonable at 10A
Vapcell%20INR18350%201100mAh%20(Purple)-Temp-15.0
Vapcell%20INR18350%201100mAh%20(Purple)-CapacityTimeHours
Vapcell%20INR18350%201100mAh%20(Purple)-Energy
Vapcell%20INR18350%201100mAh%20(Purple)-PowerLoadTime
Vapcell%20INR18350%201100mAh%20(Purple)-TripCurrent
Vapcell%20INR18350%201100mAh%20(Purple)-Charge
Conclusion
These batteries looks very good and are from the new generation of high power 18350 cells.
Notes and links
The batteries was supplied by Vapcell for review.
Comparison to other LiIon batteries
d_t_a
Last seen: 2 hours 20 min ago
Looks good.
The label indicates “middle drain” rechargeable battery.
So will there be a “high drain” version? Facepalm
Not sure where to source it for shipping to our country though..
HKJ
HKJ's picture
Middle drain must be compare to a 18650, for 18350 this is high drain.
Agro
Agro's picture
Last seen: 19 hours 12 min ago
Looks slightly worse than Aspire.
Any idea what might be the reason?
koyotee
koyotee's picture
Last seen: 2 weeks 2 days ago
Where did u get these?
Finaly, proud owner of a Powerex Maha mh c-9000 for my Eneloops:)
koyotee
koyotee's picture
HKJ
HKJ's picture
Directly from Vapcell, they have send me a couple of cells to test. The information is also in the review.
maukka
maukka's picture
Last seen: 8 months 1 week ago
Looks like they have the same problem of big sample variations like the Aspire. Better buy a bunch and pick out the winners.
You seem to be missing the discharge curve for the other battery at 5A in your comparator.
HKJ
HKJ's picture
Yes, one of my test stations have been skipping a curve once in a while, I hope it is fixed now.
Because I do not check each battery after testing it, but first when I publish the review, I did get a couple of batteries with one or two missing traces.
djozz
djozz's picture
Last seen: 9 hours 30 min ago
I got in touch with Judy from Shenzhen Vapcell Technology on Alibaba and bought 10 of these 18350 cells. She was really communicative and I can recommend dealing with her. They will send a PI (pro forma invoice) with a request to pay with PayPal.
I bought 10 to make the shipping costs worthwhile but would like to resell 6 of them, preferably in just one or two shippings. They will be cost price plus shipping (worldwide), so 3 batteries cost $4.58×3 + $5.30 = $19.04 (so $6.34 per battery). All 6 is double that because the shipping appears simply double. No tracking, no markings on the bubble mailer to make the costs affordable. Oh, and without those nice pouches because they make the package too thick to send as a letter (and too heavy too)
Anyone?
djozz
djozz's picture
I just tested capacity of 2 cells in the Opus (which usually tests a bit higher than HKJ, but now it is the same).
Barkuti
Barkuti's picture
Last seen: 9 hours 16 min ago
Sorry to say but these #@%@ns look to be all over the place here and there at the E-CigaretteForum clearly bribing reviewers to show with a product which hardly can be purchased outside of usual sources for far western vapers. They also fear stating the underwrap OEM cells used in their products, this alone is enough cause for concern in my honest opinion.
Cheers Smile
Originally posted on Fri, 03/16/2018 - 03:31. Edited to fix error in judgement.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
djozz
djozz's picture
I’m not sure where that rant comes from, perhaps you must be a vaper to understand it. If Vapcell has their distribution not sorted out well, it is a bit dumb and it costs them money, but I do not see why they should be condemned or blocked for that. (it was pretty easy to order directly through them though) And they are one of many companies that are not open about how and where they produce, nothing uncommon about that. And we know it anyway Smile
HKJ
HKJ's picture
Barkuti wrote:
…clearly bribing reviewers…
I do not like suggestion about being bribed in my reviews.
I have never been paid for a review (I use more than $100 each month on product to review). I do sometimes get product for free to review and it is stated in the reviews.
Barkuti
Barkuti's picture
 Sorry, Vapcell was not of the bribing companies, my mistake. This stuff was mentioned by Mooch at the E-CigaretteForum with certain rewrapping companies and only with the purpose of being pushed up in the reviewing queue. I do neither vape, djozz.
And sorry about the other stuff, HKJ. I didn't state you were bribed about this, which anyway is no reason for a biased evaluation. My ranting was more a wtf thing with regards to their lack of market presence.
Cheers Party
HKJ
HKJ's picture
Barkuti wrote:
.. only with the purpose of being pushed up in the reviewing queue.
I understand companies that offer that, it is very frustrating to wait many months for a reviewer to publish a review. I have also been offered that a few times, but always answered no.
Henk4U2
Henk4U2's picture
Last seen: 3 min 46 sec ago
Henrik, thats why I first and foremost turn to YOUR reviews when I have to divert from my usual cells (30Q) and/or chargers. No offence ment to all others who put a lot of blood, sweat and tears in their reviews. But that’s the way it is.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
RobertB
RobertB's picture
Last seen: 23 hours 20 min ago
If anyone from the US is reading this, Liionwholesale has them in stock. 99% sure these are the same as Aspire, and perhaps the Keeppower from same yodeli battery factory in China. Also, the iJoy, Aspire, & Vapcell 26650, 18650’s from the same yodeli factory.
djozz
djozz's picture
Yes, little sense for US folks to buy the 6 pieces that I have for sale, but for the rest of the world it may be interesting enough.
Nicolaas
I wouldn’t mind two of thos nice ans shiny purple wrapped Vapcell 18350’s Djozz………….I wouldn’t mint at all.
Also: no shipping charges within Amsterdam!
Cheers
Nico
djozz
djozz's picture
Cheers
Nico
That is easy then, they are yours! Let’s say 3 to go (because 4 doubles the shipping).
d_t_a
I would like to try out these cells too. I have ordered from AliExpress many times, but have yet to try how to order from Alibaba, could you guide me on how to order from them? Is 10pcs the minimum quantity?
(sorry if this is out of topic, send me private message if this is so).
Barkuti
Barkuti's picture
Even if off-topic the Alibaba how-to is of common interest. If djozz is willing, I'd like for such info to be shared.
Cheers Smile
djozz
djozz's picture
Buying via alibaba is not difficult, it just takes more effort. Alibaba is not a shopping platform but a trading platform, but many companies trade with private persons too, and minimum order is often 1. So instead of straight buying stuff you will have to contact a company and ask for a quote (with shipping costs). You may even negotiate a different price (but I did not do that). In case of Vapcell I asked for a quote for 10 batteries plus shipping (I guess you can buy 1 too, but shipping will kill that deal). Officially you go through the alibaba pay system but with these small orders I tend to get an invoice with a Paypal address outside the pay system.
d_t_a
(a bit off topic)
I got in contact with Jenny of Shenzhen Vapcell (Alibaba) to inquire about the Vapcell INR18350 1100mAh 10A 18350 batteries.
At first, it seems like they can accommodate small quantities of orders.
Then I asked about the estimated shipping costs, there was a long pause….
… and then got a response that I needed to order 20kg worth of batteries (equivalent to 430pcs) before they can ship to my country.
Looks like some volume is indeed needed.
djozz
djozz's picture
^ ouch!
So for shipping batteries they have easy countries and difficult countries Sad .
(I still have 3 batteries that I would like to get rid of, see post #10)
