It does look like a Latticebright XM2, (their copy of theXM-L2) I have a light with one in it and it has the same more-pronounced surface dots as the ones in your photo does. Though this version of the LB copy seems to be a bit better tinted than their fake copies of the XM-L, XP-G, XP-E emitters.
i think it’s fake, but a good one, performance is not much lower than real one, not sure about the beam
i have recently found this thread. it Looks like that mines are the same. accordingly this one uses the chips from cree.
Cree never made XM-L2 emitters where there was phosphor on the bond wires & contacts like in that topic. (that looks even like a fake Latticbright fake with a very sloppy phosphor coating mess.
Dispute in Progress…
Check out this weird LED I found on the tool truck last week:
Click the second picture for full resolution.
Looks like another variant of a copy of an XP-E emitter.
Hi all,
I bought cheap “GENUINE XHP70” led lamp from aliexpress (as starting point to my own project with XHP70). Here are pictures. Is this genuine led ? i don’t think so. Is it bright ? yes. Is it good ? I don’t know
It es neighter an XHP70 Nor an XHP70.2.
It is no known Cree-LED.
Definitely not a XHP70 (or 50) in any way. must be some kind of new knock-off, or just a odd-ball un-branded LED. The dies size look close to that of a CREE MC-E emitter, but its not one of those either.
i recieved genuine XHP70.2 XHP70B-00-0000-0D0BN40E5 from farnell. By comparing these two there are few major differences :
1) light emittors are up to 3 times bigger than chinese
2) “dome” (i don’t know exact name) is not that clear as is on chinese copy
3) you can not see supply traces on support pcb
4) there is one dot and one rectangle instead one dot
5) there are almost invisible spaces between emittors. Chinese has huge gaps.
I am posting this question here because I didn’t want to create a separate thread just for this question. This emitter is from a genuine CREE spotlight, and I can’t find any information on it. My first impulse was to call it a CXA1603, but I can’t find any information on that emitter.
BTW, I once read somewhere a couple of years ago that CREE was planning on using non-CREE emitters is some of their light bulbs to keep cost down. So i suppose it is possible that this is a “fake” CREE emitter in a genuine CREE light :confounded:
Does anyone know what this is
Looks like a Cree CMA series LED, similar to this: > https://ca.mouser.com/ProductDetail/Cree-Inc/CMA1840-0000-000N0H0A30G?qs=sGAEpiMZZMsl8UZd3ZuU6aAY3C3HMTrKC3ALTIlO%252boNGCTo7l2AB9A%3D%3D
DBSAR, thanks I had never heard of the CMA series
But this one doesn’t match up with any of those.
Diameter of the COB is 14mm while the metal substrate is 18mm. Measured voltage while running is 67.8V
Also they are calling this a high CRI light.
It would be interesting to see how far one of these can be pushed. As it is driven now it is rated at 850 lumen.
Maybe it was a special version/model of the CMA series they make for only use in their LED light bulbs running on the 120 volts line-voltage, (with a voltage reduction circuit) and not available as a separate component? difficult to know in that case.
Well after searching and searching I have concluded that this emitter is not made by CREE but rather made for CREE using their patents. I suspect that CREE licensed the technology and outsourced the manufacturing to an outfit in CHINA.
Bet THAT’S never happened before, right?
Here is the UPC code and statement Made in China and Manufactured for Cree, Inc.
If that is true, then is this a “fake” Cree emitter?
I don’t think so, its could just be called a Cree emitter made by someone else
Definitely looks like it!
This is an example of the first Cree light bulbs that I know of. This first iteration, like other brands, had heavy ribbed heat sinks at the base for long life (23.8 years) LOL
Later on Cree came out with the cheaper to make “4Flow” bulbs that were vented but had no sink
These older bulbs were actually made by Cree, the newer “4Flow” were made for Cree
1603 is a date code I assume week 3 of 2016, does not have Cree logo so not cree
hi cri?
maybe oem by yuji or whoever their oem is?
