Edit: I contacted Sofirn through Amazon and they let me know that I accidentally swapped the the SP31 tailcap with the button onto the SP32A. Oops my bad =( ā¦ā¦ But it actually worked great on the SP32A, which already had one of the best single button UI. The SP31 with the right tail cap is actually an extremely user friendly two switch flashlight. Sofirn was also very nice to ship me a replacement tail cap eventhough it was my mistake.
Yes this really helps, thanks for the link to the TIR thread, thatās an interesting thread, that optic from the SS light measures like the ones for S2+, guess Iāll have to just try some different ones too.
And thanks for the link to the SS light,Yupard has a lot of interesting budget lights.
Hi. MascaratumB,
I have now modded mine with a TIR under the glass and an extra O-Ring.
Did a Great Job of blending the awful colours, and diffusing the Hot Spot.
Thanks for the Hints and Tips, we all learn something new from each other on BLF.
Ordered 2 more as on special at Ali Xp.
Cheers,
S-L
Hi Splott-Light
Glad these experiences helped you on your mod as well Indeed, the stock ābeamā is kind of :confounded: but the TIR allows it to get better! If I didnāt have the idea of the triple mod, I would have stayed with the TIR instead of the reflector.
It was too much āgreenishā!!
If I may ask, what TIR did you use? I used one from another light and it fit perfectly (without the gasket). Did you use TIR + gasket?
If you can tell or show what you used that would be great as other members may benefit from that as well
I would also like to know this. The reflector height is 15mm, the TIRās I have are around 11.7mm-12.6mm so theyāre too short. Couldnāt find any the right size that were made for XP-L2
Hi Splott-Light! Thanks for posting the links for the TIRs!
Hum, those seem to be like the Convoy S2+ TIRs, with the white gasket! Funny, I didnāt experimented those before I tried the one I used for a whileā¦ :person_facepalming:
Well, but if they fit well (even with the mods youāve done) thatās nice
I guess that someday I will try to open the SP32 (not the SP32A) and stick a TIR there as well, to smoothen the beam
Thanks for taking the time to write
And if you are Madā¦welcome to the club :smiling_imp: :face_with_monocle: :sunglasses:
Received my SP32A earlier this week and really liked it. :+1:
I have the same optics from Fasttech, in 10, 15, 30 and 60 degrees, also from a few years ago.
So I tried to put a 15 degree in and accidentally dedomed the LED :person_facepalming:
The centering gasket was stuck (glued?) to the bottom of the reflector and I didnāt put any in, I was trying to measure how thick of an o-ring I needed and the sharp legs of the optic dedomed it. It took away some phosphorus so now I have a sick purple beam that looks something like UV.
So soon I will order an XP-L2 V5 4000k to replace it. The 5350-5700K was a bit too cool for me anyhow. Iāve read the XP-L2 5000K is a bit cold compared to others and the 4000k has less tint shift.
A few thing differ from the review:
1. Ramping time: about 3 seconds from lowest to highest (and visa-versa) :+1:
2. MCPCB has a smaller silver screw instead of the black one, and the head is smaller than the opening in the board, so the screw wasnāt doing anything! Also the threaded shaft of the screw is too thin so itās loose in itās hole!
I may not use a screw with the new MCPCB if the reflector holds it down, otherwise Iāll need to drill a hole in the new board for it and get a larger screw.
Even if it wasnāt tight, the screw will keep the the MCPCB from rotating if the reflector rotates as you tighten it. Still, it would be good if there was no chance of it being shaken loose in the head.
Good point I never thought of that, is that the main function of the screw? Or was it mainly to hold the MCPCB down tight? (because the reflector should do that anyhow?)
So now Iām considering an SST-40 (sliced dome) instead for my SP32A. The current on turbo would be perfect for that, 7.5-8A, what do you guys think?
In one of the SST40 emitter reviews the sliced dome would yield a tint of approx 5000 - 5500 K, and that was for the 7500K, Iāll be using a 6500K so itās could even be warmer (hopefully not too green though) A dedomed SST40 is said to have a better tint (more uniform) than 2nd generation Cree.
Although I might need to slightly widen the reflector opening as itās a slightly larger footprint (3.45 x 3.45mm) vs (5.0 x 5.0mm)
I really appreciate the mod ideas presented in this post! I have a working SP32A and it's great so I bought another one. This time I ran into a bad driver so I bought replacement drivers. Now, the only problem is I can't loosen the driver retaining ring because it's glued! Opf!
I heated the head with my soldering iron... didn't work. Then froze it for a few days to try cracking the glue. The brass is soft so other than my needle nose pliers, what can I use to get this out? If it's a no go, I have two drivers to offer someone! Help :/
Hum, have you tried bow opening pliers? With some force it may help you!
If the driver is already damaged, it wonāt hurt, youāll just have to look the brass ring !!
Heat usually works best to get the glue going.
And donāt be shy with the butane torch.
Unless there are plastic optics in a head, you can heat the outside to some 150Ā°C with no problems.
But, you need to have the tools to screw it open with enough force and without damaging too.
