Hmm . . . ran across this light in the KD thread. I’d be interested if it did NOT have memory (or simply a way to force it on in low level first) and had a NW option (or at least knew it was an easy emitter swap).
I like just 3 modes, length is critical to me (18650 lights are on the border of pocketable), and I can replace leds myself. So that makes the S20 more interesting to me than the SP32A. Critical as well is direct access to low mode from off, that still has to be confirmed.
Wow, sounds like you (djozz) and I have similar taste in EDC’s - direct access to low, no memory, LED swappable to our own choice, simple 3 (or maybe 4) modes, as short as possible - just add deep pocket clip availability to that list for me. I know it’s anathema, but I’m actually not carrying an EDC much anymore because I need to find something shorter than doesn’t bother me in my pocket. Phones keep getting larger which means more of a problem carrying my EDC light. I started trying to put the light in my rear pocket, but that’s not always comfortable either. I might try going to a belt clip/pouch.
I’m always looking for the shortest 18650 light, that’s why I’m subscribed to this thread.
I already have the SP32A and it’s a great light but it’s long…
…However… the main reason I got the SP32A is because it legos with the Convoy / Jaxman 18350 & 18500 tubes:
106.7mm with the 18500
89.3mm with the 18350
So it’s a real gem with the shorty tubes.
So for this Ultratac I agree with you djozz, 3-mode is fine and I will also swap the LED, but I also need to know the UI.
One thing I would miss (if it doesn’t have) is direct access to the highest mode.
BLF A6 and Zanflare F1 are supposed to be 1200 lumens (Turbo). Turns out SP32A also gives out only 1200 lumens instead of the listed 1500 lumens, according to 2 reports. So my question becomes moot.
Yeah, I though 1500lm sounded a little high for what I’m seeing, but 1200lm is quite bright. I’ve got to get a light meter, at least to do basic comparisons.
I wished mode memory was never invented If I can not even remember the important things in life, why on earth should I know in what mode my flashlight was last time I switched it off?
I noticed that too about 10 days ago when I found out about this light.
I also find it odd that a company can design and implement a new model, all they way through production and listing it on amazon, but still not have a listing for it on their website. I’ve also noticed this same pattern with one or two other companies, can’t remember which ones ATM.
