Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17432 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 6 hours 55 min ago
What banggood coupon do you have? I was looking for some type of coupon earlier.
jstay
Last seen: 7 months 5 days ago
Im using a code from https://m4dm4x.com/blf-q8-arrived/ which gives me about 45% off.
*edited to remove code and include website
GreenLights
Last seen: 56 min 2 sec ago
I don’t think you are supposed to post that code openly. You need to go to M4D M4X’s website to get the code, and for him to get his commission. (I think)
Just discovered this wonderful addiction.
raccoon city
raccoon city's picture
Last seen: 56 min 37 sec ago
Post 17,000!
(at the moment)
teacher
teacher's picture
Last seen: 2 years 1 month ago
17,001
(atm)
g_sintornillos
g_sintornillos's picture
Last seen: 11 months 3 weeks ago
Sorry for my bad English (gogole transtorla)
teacher
teacher's picture
It “was” at one time maybe….. Big Smile
teacher
teacher's picture
17000
(atm)
g_sintornillos
g_sintornillos
Facepalm
y no juego más
Big Smile .
blinker
Nice to see you still have your sense of humor g_sintornillos.
Not a flashlight guru, but like them just the same.
Misspellers of the world UNTIE!!!
kubed_zero
Last seen: 11 months 1 week ago
I posted a while back about a dead green indicator LED that was unable to be fixed with soldering. Does anyone have any email addresses or usernames of people I could try to contact to get a replacement assembly?
joechina
Try it again with the old mail address. Now Chinese New year is over
jstay
Update: I wiped the led as instructed and the “bubble” is gone. Seems like it is just a speck of dirt. Don’t know why it seemed so much like it was inside the dome initially.
On a side note, I accidentally wiped off some of the thermal paste (TIM) while removing the reflector. I used some of my CPU thermal paste (cooler master ic essential E2). Is this fine or do y’all have a preference for thermal paste for flashlights?
thanks for the help everyone
djozz
djozz's picture
Last seen: 4 hours 10 sec ago
^ although there is much heat to be transfered, the contact surface of the ledboard is large so the thermal paste should not be critical, as long as you keep the layer thin.
jstay
@djozz ok thank you for the clarification!
Alexium
So I’ve bought four Samsung 30Qs, and I’m underwhelmed at the Q8 light output compared to two and even one regular 5A Sanyo batteries that I’ve been running the light with previously. To be precise, I don’t see a difference between 2xSanyo and 4xSamsung 30Q. All fresh out of charger, of course. Also, I don’t see a difference between 4×30Q and 3×30Q. Should I be able to see it? I know naked eye is very poor at spotting small-ish differences, especially when comparing sequentially and not side by side.
And a related question. As I ramp up the Q8’s output, at some moment just before the max brightness is achieved, it blinks shortly. Is it when it switches to direct drive? I don’t see a difference between the flat-out max mode, and the closest ramp-down mode (just before the light blinks). Do you guys see any difference there as you ramp your Q8 up?
MTE C3-907 -> Convoy C8 -> Convoy S2+ -> BLF Q8 -> Sofirn SP36 -> Somebody please make me stop!
WalkIntoTheLight
Last seen: 7 months 2 weeks ago
You probably won’t see a difference in brightness between 2, 3, or 4 cells. You should definitely notice a difference at 1 cell, when it will only be about half as bright at maximum.
This is a bright light, at over 5,000 lumens, but don’t expect a blinding light. It’s equivalent to about 3 or 4 100 watt light bulbs. So, a fairly bright room.
The light blinks when it finishes the ramp to maximum. You won’t see anything when it switches from the linear driver to the direct drive, which occurs much closer to the low-end of the range. You can tell when you release the switch, though. If the switch blinks once, it’s using only the 7135 linear driver. If it blinks twice, it’s using the FET direct drive.
cabfrank
Last seen: 2 days 9 hours ago
17,000. Aren’t we going the wrong direction here?
Alexium
Didn’t torture a single cell. Meh, I was lead to believe the number of cells does have an impact on the absolute max brightness, as does the type of cells (regular vs. high current). Thanks for clearing that up for me.
You mean incandescent lights? Makes sense, with about 10x efficiency for LEDs vs. bulbs and considering that each LED in Q8 is well over 10 W.
So the linear modes are PWM free, and direct drive modes are PWM?
JasonWW
JasonWW's picture
They do, but your eyes are not that good at measuring it. The difference between 5k and 6k lumen is hard for human eyeballs to see especially when you have to take a break to change out the batteries. You have to remember what the first brightness level was as your looking at the second brightness level.
A lux meter would definitely see the differences as would an amp meter measuring the current.
WalkIntoTheLight
I’m talking high-drain only. If you try 2 vs 4 regular cells, you probably will see a difference. There’s also a difference between 4 regular and 4 high-drain cells, though you probably won’t be able to tell with your eye between battery changes.
Also, the battery voltage makes a huge difference. You’ll only get full output if your cells are fully charged to 4.2v.
IIRC, PWM is used for all modes, unless you’re right at the output max for the 7135 or FET. It’s very high frequency, so you won’t be able to see it. Perhaps you might notice on moonlight, but that’s probably the only mode.
Alexium
Gotcha, thanks. Yes, I understand how difficult it could be spotting a difference in light intensity with a naked eye, definitely could use a lux meter.
teacher
teacher's picture
Just a quick question… Are your 30Q’s button top or have they been solder boobed??
If not, that could well be part of your problem. Not all the batteries making contact at the positive (+) end.
oto
oto's picture
Last seen: 4 days 13 hours ago
You don’t need fancy equipment to measure brightness difference. Use your smartphone, download lux meter app and do some ceiling bounce tests.
teacher
teacher's picture
Yep, seem so. Big Smile . Seems some deletions have occurred for sure. Wink
Alexium
They were flat top, and I have solder-boobed them myself. I was aware of this potential problem, but thanks for the tip!
teacher
teacher's picture
OK. great! Just checking & your welcome. Thumbs Up
djozz
djozz's picture
There is even a special flashlight app for that: search for ‘ceilingbounce’. It makes use of the same phone sensors as the various luxmeter apps so in accuracy it is not anything special but it has all sorts of nice features that makes flashlight measurements more convenient.
edit: de ceilingbounce app is not in the app store, a link is here: http://budgetlightforum.com/node/53741
Alexium
Great idea! I have went as far as installing a couple lux meter apps, but I didn’t find a suitable piece of semi-transparent material to cover the sensor to prevent it from saturating. Totally didn’t think of bouncing the light off the ceiling.
