It did actually occur to me that it makes it less likely for the light to turn on in my pocket (which has happened twice with the D1). Maybe I’ll leave it and see how I get on with with a harder press.
I know some people have griped about how the Emisar lights feel in - hand, so I thought I’d show this…
I was using some blue Sugru for another project (un-cured silicone) and had quite a bit left over, so I rolled it into the handle (battery tube) of my D1s. Worked out pretty neat, especially seeing as how the nice blue color ano wasn’t offered in this light.
I rolled my ball of Sugru and wrapped it around the middle of the tube, then rolled it out on the counter like a pastry roller til it filled the major part of the tube, using a little water on the counter top to make it smooth. So now my D1s has a silicone insulated grip panel.
My D1S switch feels about the same as my D1 and D4
Sugru is not a thing I’d expect as a tube wrap. That must have required a lot more care than a common shrink wrap. It looks like it fills in the grooves nicely though, as if they weren’t even there.
For quite a while I’ve been looking at different compact size thrower lights ($30-$60) to find the best combination of distance and pocket-ability.
The D1S is still the most compact sized production thrower currently available for under $60 in it’s range class (700-800 meters)
Here’s the ones I’m considering:
………………………………………………………………Length mm……Head mm…….Distance (mfg. spec.)
- Emisar D1S…………18650…………XPL-HI………….127……………50…………………720m
- Maeerxu M8…………26650……….XPL-HI……………142……………54…………………800m
- Utorch UT02……….26650……….XHP-35 HI………148……………59…………………700m
- Catapault V6……….26650……….XHP-35 HI………132……………58…………………750m
It has about the same range as the others but it’s the smallest size. And even more compact having the thinner 18650 tube.
So it comes out on top if compact size for pocket carry is your main concern. I’m leaning more and more towards this one.
I’ve started a discussion thread on the subject: Discussion of compact size production throwers 700m+ under $60
Thanks for posting, interesting stuff, didn’t know about it.
Is this it? https://www.homedepot.com/p/Sugru-0-88-oz-Multicolored-Mouldable-Glue-5-Pack-SMLT5/206007535
Is it removable after it’s cured?
Pity there’s no knurling on these, has anyone found any tube that lego’s with the D1S?
If I get a D1S I’ll put some of these silicone “Vape Bands” on the tube.
They make a real nice grip for a smooth tube. They’re mostly perfect size for 18650 tubes.
Fasttech has hundreds of them. https://www.fasttech.com/category/0/-/-/p/1?sort=r&keywords=vape+band
That’s the stuff, sure didn’t know Home Depot carried it! Nice find!
I tried to remove the switch covers on both my D1 and D1s to see what’s going on underneath. The difference is definitely very noticeable, and you wouldn’t be able to miss it.
Unfortunately, I ripped the rubber switch cover of the D1, thinking it would be a good idea to try and pull it out with a pair of needle nose pliers. What do I need to look for when I order a new one? I assume they’re pretty standard - are there any UK suppliers?
You may try writing directly to Hank at Intl-Outdoor, keep it OEM.
Sounds like a plan - I’ve already had three lights from there, and I’m sure I’ll be coming back for more!
It’s necessary to remove the switch cover retaining ring first, by carefully prying it up with an X-Acto blade or similar, rotating it around the edge to gently pop it up.
D1 and D1s are on sale on intl outdoor for $35, could not resist, ordered a grey D1s 5D.
Thanks for posting, I wonder if you got the last remaining grey one, only Matte Black showing now.
I would have maybe jumped on a grey one, not sure I like the look of that Matte Black, kind of looks like a dirty chalkboard!
I am curious how I will like the chalky ano. Maybe they are selling the stock and switching to the smooth ano, than the joke is on me.
bring back the smooth green!
I didn’t like it at first, but after a bit of use it becomes a lot smoother. It feels more like stone than metal, and it’s actually quite nice.
+1 love the smooth green on my D4.
Thanks. It will not be an edc light living in my pocket, so I think I will be ok with it also.
