Test/review of Golisi IMR21700 3750mAh S35 (Black)
Official specifications:
  • Size: 21 x 70mm
  • Model: 21700
  • Capacity: 3750mAh
  • Constant Current: 40A
  • Nominal Voltage: 3.7V
  • Charging cut-off voltage: 4.20±0.05V
  • Internal resistance: 30mOhm
  • Standard charging current: cc/cv(<=3A)
  • Cycle times: >800
  • Operate temperature: Charging: 0°C ~ 45°C), Discharging: –20°C ~ 60°C
A high current with fairly high capacity 21700 cell.
The two cell has different capacity, but both has fairly constant capacity even at high load. One cell is close to stated capacity at low low, the other is a bit low.
Temperature is acceptable at 20A
But at 20A I had to stop the discharge due to heat.
Conclusion
The current and capacity is good, but I do not like that the cells have different capacity.
Notes and links
The battery was supplied by Golisi for review.
Compare to 18650 and other batteries
Thanks Henrik for the test.
I want a favor .
Can you test the Basen 21700 4000?
Comparing the positive pole with the photo ……, they seem to be the same.
In the test I made in Basen, I saw that the battery is capable of 15A performance without exceeding the temperature limits.
But some say they are the same battery.
I know Basen 21700 4000 is Lishen’s construction.
Do you know which company is making the battery used by Golisi, Ijoy and others?
Sorry, but I do not have the Basen cell, and I do not know what cell is inside.
Thank’s Henrik.
