Apologies for my ignorance and I'm not sure who Dale and Everett are, but hopefully the GFS system will be useful for anyone looking to try some new things on their lights ^_^/
Anyway I've been using this new switch system for a little bit and it's been working really nicely so far. I'd imagine people who like to use DD FET drivers might find this useful to squeeze out more performance.
Sure the LFPAK33 is a fine package. IIRC it's used on a lot of smaller FET boards as well as those used in the LED4power boards. However I saw no reason to since space is really not a constraint, and the Powerpak fets are generally more robust, with a lot more options available from different manufacturers with comparable or cheaper costs, and definitely much better R_ds_on at low voltage gate drives . I suppose if I used one of those fat springs http://www.mtnelectronics.com/index.php?route=product/product&product_id=385&search=spring I could put a smaller FET in the middle. Maybe I'll just make a board with dual footprints and everyone will be happy!
[Edit]
Ok I had half an hour to mess around and I've made a Rev B with dual footprints.
Won't fit small springs but I guess if you're serious about modding, you'll have a few of these lying around: http://www.mtnelectronics.com/index.php?route=product/product&product_id=385&search=spring. So now you can use whatever FET you want . Personally though for my builds I'm just going to stick with the PowerPak SO8 just because the FETs are strictly superior, especially at low gate drive voltages
Yes, it should be useful to anyone wishing to add lighted tailswitch. I was just saying that the hard core modders will be the most likely to jump in early, because they’ve already squeezed out maximum performance in every other area possible. Dale is BLF member DB Custom. He has made some insane builds, including getting his titanium neck light to output over 1000lm using just a 10440 cell for power.
Loneoceans, you’ve got mad skills. I’m glad you found our forum!
I’ve built a bunch of the basic illuminated tailcaps, would love to build a couple of these bad boys. I’ve soldered quite a few 0805 LEDs by hand (what size did you use?), but those resistors look absolutely TINY.
Hello GChart, thanks for your kind commends! The LEDs I used are 0603 size and the resistors are 0402 size. I recommend these Wurth Electronic LEDs, only because they have a nice triangle marking on the bottom telling you which is the anode and which is the cathode. However you can use any other size you want.
I made them small so I could fit them properly in a ring with sufficient clearance around them. For example in the Convoy S2+, the LED ring replaces the metal washer which the switch sits on, which then presses against the shelf. For some of the other LED rings out there, it appears that the resistors are placed in this keepout area so you'll be crushing the resistors, which should work fine, but is bad practice (e.g. the end caps of the resistor can crack from the substrate etc).
As for soldering, if you can solder 0805, you can solder 0402. If you find it too difficult, it's actually more a matter of using the right tools and solder. I highly recommend using a fine tip soldering iron (actually this is not that critical), needle tweezers (critical, and cheap), and the thinnest solder wire you can find (VERY important - use .015"/.38mm or 0.020"/.5mm solder). This will make your life so much easier.
Also magnification helps, either with an optical setup, or with a USB microscope or your phone (there are apps that do this!).
I’ve been using the PilotDog68 Rev5.3 boards (top only; not using the bottom/pot boards). The LEDs seem to have sufficient clearance, and the resistors are located on the bottom of the PCB so as not to be crushed (link)
I’ve found that when working with some of these small buggers, it’s easier to put a dab of solder paste on the PCB pads, place the components, and then just touch the connects with a small/chisel tip iron. Not sure if that’s proper, but it works well for me.
Thanks everyone again for your kind comments. I managed to put together another set of FET tailswitches with the smaller form-factor FETs and nice Beryllium Copper springs from Noctigon and it's working beautifully.
All fits well (in a Convoy S2+).
An alternative view.
Finally, above is a clear view of the GFS16 (LED 18mm) board with components soldered as a reference for people trying to make their own. The BOM is updated in the OP. With the default resistor values, BANK 1 of LEDs turn on when V_bat is >2.97V, and changes to BANK 2 when 2.73<V_BAT<2.97V.
Hello all, 1st I want to thank loneoceans for sharing this with us. just finished building 2 switches and they work with the H17F driver only if a bleeder resistor is added, I used 2.2Kohms and all functions flawlessly. My question to loneoceans or anyone who may know... would a lower value bleeder expedite the coin battery charging time.. with the 2.2Kohms it took about 3HRs off time to charge from 2.55v to 2.67v on a full 18650 battery, Thanks.
![img]https://i.imgur.com/64TojtG.jpg[/img]!
![img]https://i.imgur.com/bSa23Fr.jpg[/img]!
![img]https://i.imgur.com/eugZNBC.jpg[/img]!
![img]https://i.imgur.com/Q1uZNvW.jpg[/img]!
![img]https://i.imgur.com/N5EzwVN.jpg?1[/img]!
2.2Kohms bleeder is only good for the switch board alone, for both the switch and the led board... 3x 2.2Kohms or 733ohms worked perfectly.
Hello Fady, great job on the assembly of the boards, looks like you did a fantastic job and many thanks for sharing the images.
Fady, the small coin batteries are designed to be charged fairly slowly, and as you probably have seen during assembly, charging is from a small 3.3V regulator and a series 2.2k resistor, and is designed to charge the cell slowly. Now when the switch is on, the battery bleeds via a 1M resistor on the FET gate, so any losses would be through internal discharge, and parasitic loss through the fet and reverse flow on the regulator, which should be very slow.
The first time you're charging the coin cell from the factory, it should take a while. But once it's fully charged, the voltage shouldn't drop substantially any more after in everyday, normal use. Also I suppose compatibility of the GFS system will depend on which driver you're using.
Hi loneoceans, Thanks for your comments, I built nine so far and they working great except for 1 died within 12Hrs… The light was left on a table… next day I noticed the red leds were on, I checked the 18650 voltage and it was full… the switch wouldn’t work, after a bit of T/Sing found out that the coin cell went down to 0v, not sure if somehow it shorted out or was just a bad battery, I drew out the schematics of the switch circuit & made sure I do not have a short somewhere… so I went ahead and replaced the battery, all good now. I also used green leds instead of blue on some of them, P/N 150060GS75000.
A tip for anyone planning on building 1 is to superglue the led board on top of the switch otherwise the rotation force may break the coin cell solder joints, that happened to me.
Now that I have the schematics i and looked up the LDO reg. datasheet, what happens in the circuit once the coin cell voltage is equal to the REG. voltage? and whats the function of R2 also what do you mean by reverse flow on the reg, isn’t the diode there on the positive rail to prevent this? sorry loneoceans I know I’m asking too many questions!! : )
For battery longevity, it's important to charge the battery at or lower than the manufacturer rated charge current. This is outlined in the datasheet here (https://www.sii.co.jp/en/me/files/2016/02/English_Micro-Battery-2016.pdf). Once the battery voltage reaches regulator voltage, the battery simply stops charging. Diodes are not ideal devices and there will always be a small amount of leakage current, likewise with the FET gate, and internal leakage within the battery. R2 is not strictly necessary but it reduces the initial turn-on gate drive current which will lead to a more consistent turn on performance (esp. since the micro battery has a fairly large internal resistance).
Note that the LED board and FET board are standalone so there's no requirement to use both. Also if you use the stacked-fet-switch stackup, with a little bit of filing, it's possible to also swap the battery out (MS412) to the bigger MS518.
Cool! thanks for the explanation, yes I’m aware that both boards are standalone, I already have 3 of them built with the MS518SE battery, it fits best when using Q1 on 0.8mm board and the 1.6mm led board.
I really like the idea and the realization. Is it possibble to use 3x2 leds in 3 different colors for battery indicator? So that way maybe the switch can be green from 4,2V to 3,7V and orange from 3,7V to 3V and red under 3V?
