No I don’t think so, I think if you did that the switch boot/bezel may no longer fit.
If it did fit there would be a open gap around part of the switch.
The switch on mine is not perfectly centered in the hole but that didn’t matter after doing komeko’s mod of a plastic disc inserted between the boot plunger and switch. Not only did it take up the gap between the plunger and switch (which was too long) I believe it also corrects the mis-alignment of the switch with the hole.
I think what corrects the mis-alignment with this mod is than I made the circumference of the plastic disc nearly as big as the hole in the body, (much wider/larger than the white button/acutator on the switch)
The plastic disc acts as a “contact plate” that in effect enlarges the surface of the internal switch button/acutator to correct the mis-alignment offset in the hole. You could even glue the plastic disc on to the end of the switch.
The thickness of the plastic I used was 1.15mm, the switch is super sensitive now, I might try a bit thinner plastic (.75mm - 1mm) But the thickness may vary between lights as komeko used a 1.5mm and that would have been way too thick for my light.
I used plastic cut from one of those bread bag closures from a sack of Bagels!
