ENEDED
449 posts / 0 new
demonnov
demonnov's picture
Last seen: 4 years 2 months ago
Interested. MM18JR Depending on price. Thank you.
freeme
freeme's picture
Last seen: 6 hours 37 min ago
Done.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
freeme
freeme's picture
Has anyone received the other two models yet?
muellihenry
muellihenry's picture
Last seen: 8 months 3 weeks ago
My MM18JR is currently stuck in German customs, let’s see when it goes on! Sad Before, nothing happened long ago, they are not the fastest!
freeme
freeme's picture
Did you opt for standard airmail or expedited? undecided
muellihenry wrote:
My MM18JR is currently stuck in German customs, let's see when it goes on! Sad Before, nothing happened long ago, they are not the fastest!
muellihenry
I had standard airmail. With DHL express ($ 25) I could have bought them at Banggood.
There was not another option.
andrew124C41
Last seen: 1 year 4 months ago
I am interested.
casi29061965
Last seen: 3 months 4 weeks ago
My MM18JR and the BK-FA30S are at Germany customs too. I ordered via standard Airmail too.
surasakkongtha
Thank you freeme. I order MM18III $154 / 1 piece send by register air mail
Bruno28
Got mine today.
The reflector has some marks, the LED is far from centred. Sad
I tried the rear button and I get a green/red blinking when pressed. When pressed again it stops the blinking.
But the light does not turn on with the main button, not even a sign of life form what is meant to be the battery indicator in the centre of the button. Am I missing something?
WSB
WSB's picture
Last seen: 2 years 9 months ago
Interested
Nicolicous
Nicolicous's picture
Last seen: 1 year 8 months ago
Bruno28 wrote:
Got mine today.
Definitely a sad thing to hear.
I’m waiting for mine to arrive
Nico -.-
DENGOH
DENGOH's picture
Last seen: 2 weeks 2 days ago
Bruno28, can you post some pictures of the LED and reflector?
Mine still stuck at somewhere in airport I guess.
cool i'll see you when you get there
Narwhals
Last seen: 3 years 11 months ago
Interested in the BK-FA30S
Bruno28
DENGOH wrote:
Bruno28, can you post some pictures of the LED and reflector? Mine still stuck at somewhere in airport I guess.
So I managed to dismantle a bit and see what the issue was. No idea what it was, but when I put it back together it started working.
But mode 4 and 5 has massive flicker. And it actually doesn’t change mode as its somehow interrupting the mode change, even to turn on and off. Its almost like I have to keep trying until I get the perfect timing where there is no interruption for it to work. The battery level light in the middle of the switch also flickers.
So mode 4 and 5 are completely not possible to use on my light. So I programmed one button as lowest output and the other as highest, and that allows me to exit when stuck on mode 4 and 5.
Here is the link to reflector photos and LED centering:
https://www.dropbox.com/sh/4lxbelsy5042imp/AAAmirSOLgl_rJN73fAAB5U6a?dl=0
Videos of flicker:
https://youtu.be/S-pa_eATZJs
https://youtu.be/BOGIWQ30HO8
https://youtu.be/x3-X1l0wVDs
https://www.youtube.com/edit?o=U&video_id=SGD61OZMaWI
I did a run test on turbo, and the flashlight reached 72 degrees C. Never stepped down.
mmalive
Last seen: 3 years 6 months ago
Interested in all 3 if still available.
freeme
freeme's picture
The rear button is not the power switch for the main light. I believe it is meant for signal purpose , or act as a flashlight location beacon?
Bruno28 wrote:
Got mine today. The reflector has some marks, the LED is far from centred. Sad I tried the rear button and I get a green/red blinking when pressed. When pressed again it stops the blinking. But the light does not turn on with the main button, not even a sign of life form what is meant to be the battery indicator in the centre of the button. Am I missing something?
DENGOH
DENGOH's picture
Bruno28, have you tried different batteries?
The LED looks centered to me, but maybe the white insulator is not. Do you manage to correct it?
Bruno28
DENGOH wrote:
Bruno28, have you tried different batteries? The LED looks centered to me, but maybe the white insulator is not. Do you manage to correct it?
Its not batteries issue.
If you read my post I explain that its got flickering issues after I manage to disassemble the light and put it back which miraculously made it work.
I was able to correct a bit of the centring of LED. You can remove the whole Reflector head and get straight to the LED and MPCB.
Bruno28
Yes its only a Beacon, not very useful. Would have been best if it was a tail click switch like the older model. To be honest I think the older model is a bit better as it has a click switch and a magnetic rotating mode switch. So much easier to use.
Ill try both lights tonight, but seems like they are about the same in throw (even though the old has 200lumens more) and spot size when I tried inside, making the older model much more compact as its a smaller head.
I will see how they differ in throw tonight.
DENGOH
DENGOH's picture
Yes, I understand that you dismantle and put it back, and it start to work, but it has flickering issue for mode 4 and 5.
I meant to ask do you try different batteries to troubleshoot the flickering issue.
Bruno28
So I tried my brand new batteries that I got with the BLF GT. It was better. But mode 5 had hissing sounds. Mode 4 didn’t seem to have issues and it was smoother during mode change.
Since its not perfect does it mean that there could still be some issue that’s not battery related? Or is the hissing sound normal?
DENGOH
DENGOH's picture
I am not sure. Looks like mode 4 and 5 are regulated and battery age or contact will play a factor.
Highest mode is not regulated so it will just draw as much current from batteries as possible.
Ya, the hissing sound is mentioned in review posted in BLF.
surasakkongtha
hi my friend group by.I have a question How long after pay to receive a tracking number?. i select shiped by registed air mail
Nicolicous
I purchased two BK-FA30S and first one arrived today.
I had a closer inspection and the LED is well centre also no mark on reflector.
Im very happy with the light and it’s a definitely thrower killer vs Astrolux MF02 Crazy
Nico -.-
freeme
freeme's picture
I will forward your issue to manufacturer.
Bruno28 wrote:
So I managed to dismantle a bit and see what the issue was. No idea what it was, but when I put it back together it started working. But mode 4 and 5 has massive flicker. And it actually doesn't change mode as its somehow interrupting the mode change, even to turn on and off. Its almost like I have to keep trying until I get the perfect timing where there is no interruption for it to work. The battery level light in the middle of the switch also flickers. So mode 4 and 5 are completely not possible to use on my light. So I programmed one button as lowest output and the other as highest, and that allows me to exit when stuck on mode 4 and 5. Here is the link to reflector photos and LED centering: https://www.dropbox.com/sh/4lxbelsy5042imp/AAAmirSOLgl_rJN73fAAB5U6a?dl=0 Videos of flicker: https://youtu.be/S-pa_eATZJs https://youtu.be/BOGIWQ30HO8 https://youtu.be/x3-X1l0wVDs https://www.youtube.com/edit?o=U&video_id=SGD61OZMaWI I did a run test on turbo, and the flashlight reached 72 degrees C. Never stepped down.
ulfm1
Last seen: 3 months 4 days ago
I received my MM18III today and i am totaly satisfied!!! Now I’m waiting for my Vostro Big Smile
But i have a problem. The Charger is not for the EU. Is there a posibility to get one for the EU (Germany)?
Thank you freeme and Niwalker for the possibility of this Groupbuy!!!!!!
Bruno28
Bruno28 wrote:
So I managed to dismantle a bit and see what the issue was. No idea what it was, but when I put it back together it started working. But mode 4 and 5 has massive flicker. And it actually doesn’t change mode as its somehow interrupting the mode change, even to turn on and off. Its almost like I have to keep trying until I get the perfect timing where there is no interruption for it to work. The battery level light in the middle of the switch also flickers. So mode 4 and 5 are completely not possible to use on my light. So I programmed one button as lowest output and the other as highest, and that allows me to exit when stuck on mode 4 and 5. Here is the link to reflector photos and LED centering: https://www.dropbox.com/sh/4lxbelsy5042imp/AAAmirSOLgl_rJN73fAAB5U6a?dl=0 Videos of flicker: https://youtu.be/S-pa_eATZJs https://youtu.be/BOGIWQ30HO8 https://youtu.be/x3-X1l0wVDs https://www.youtube.com/edit?o=U&video_id=SGD61OZMaWI I did a run test on turbo, and the flashlight reached 72 degrees C. Never stepped down.
Thanks Freeme:)
ulfm1
I got a mail from niwalker, that there are no chargers available for the EU.
But I found an adapter and it works fine.
Again thanks to freeme and niwalker!!
Bruno28
Ok so I got my second BK-FA30s. Anddddd it doesn’t work too. This one has over 15 imperfections on the reflectors, its so bad that my other BK-Fa30s reflector looks quite good. Sad whats going on Niwalker!
The Nova MM18III I got today at least seems to be working perfectly. Smile
