Test/review of Samsung INR21700-48G 4800mAh (Gray)
18 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 16 hours ago
DSC_2593
Official specifications:
  • Typical standard discharge capacity: 4800mAh
  • Minimum standard discharge capacity: 4700mAh
  • Typical standard discharge energy: 17.4Wh
  • Minimum standard discharge energy: 17.04Wh
  • Charging voltage: 4.20V
  • Nominal voltage: 3.6V
  • Standard charging current: 1440mA
  • Rapid charging current: 4800mA (Not recommended for long life cycle)
  • Max. discharge current: 9600mA (Not for cycle life)
  • Max. pulse discharge current: 30A for 10sec, 25A for 30sec, 18A for 60sec
  • Discharge cut-off voltage: 2.50V
  • Operating temperature: Charge: 0° ~50°C, discharge -20° ~ 60°
  • Storage temperature: 1 year: -20°C ~ 25°C, 3 months: -20°C ~ 45°C, 1 month: -20°C ~ 55°C
  • Internal impedance:
  • Internal resistance:
  • Cycle life: 500 cycles to 75% at 23°C or 70% at 45°C (Charge=0.3C, Discharge=1C)
Samsung%20INR21700-48G%204800mAh%20(Gray)-info
This is a high capacity cell in the new 21700 format.
DSC_2592
DSC_2594 DSC_2595
DSC_2596
DSC_2597
Samsung%20INR21700-48G%204800mAh%20(Gray)-Capacity
Nice tracking discharge curves with fairly constant capacity, but the cell cannot handle above 10A without heat problems, this is acceptable with a maximum rating of 9.6A
I only discharge the cell to 2.8V, not the rated 2.5V and get a bit less than full capacity.
Samsung%20INR21700-48G%204800mAh%20(Gray)-Temp-7.0
Samsung%20INR21700-48G%204800mAh%20(Gray)-Temp-10.0
Samsung%20INR21700-48G%204800mAh%20(Gray)-Temp-15.0
Battery gets to hot and i stop the discharge.
Samsung%20INR21700-48G%204800mAh%20(Gray)-CapacityTimeHours
Samsung%20INR21700-48G%204800mAh%20(Gray)-Energy
Samsung%20INR21700-48G%204800mAh%20(Gray)-PowerLoadTime
Samsung%20INR21700-48G%204800mAh%20(Gray)-TripCurrent
Samsung%20INR21700-48G%204800mAh%20(Gray)-Charge
Conclusion
This is highest capacity 21700 cell at the current time (Jan 2018) and it looks very good, but it is not designed for high current discharges or fast charging.
Notes and links
The cell was supplied by a reader for review.
Compare to 18650 and other batteries
ECHO
Last seen: 6 months 3 weeks ago
Excellent work as always HKJ, thanks!
ChibiM
ChibiM's picture
Last seen: 12 hours 44 min ago
4800 is pretty impressive!
FPV
FPV's picture
very nice cell, thank you for the detailed review.
I think I will try to bore out a light to try a 21700.
MRsDNF
MRsDNF's picture
Thanks HKJ. Thumbs Up
Agro
Agro's picture
Last seen: 2 min 37 sec ago
That was a long wait….but thanks for the test, great as always.
HKJ
HKJ's picture
Yes and my queue is still very long.
will34
will34's picture
Last seen: 2 hours 2 min ago
Thanks for the review! I’m hoping to see multi 21700 lights soon.
Henk4U2
Henk4U2's picture
Last seen: 4 hours 46 min ago
Always charge my batteries at 0.5Amp (when not in a hurry Wink ).
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
DENGOH
DENGOH's picture
Last seen: 2 years 1 week ago
Thanks for the review.
May I know what is the advantage of 21700? It seems to perform not as good as a good Liitokala 26650.
cool i'll see you when you get there
HKJ
HKJ's picture
Size
ZoomieFan
ZoomieFan's picture
Capacity is a little less than I hoped for.
Any idea what’s the difference with this version?
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88 4/5, LiitoKala: 3x100 3/5, 2x202 3/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k 2/5, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5, Xtar PB2S 5/5
Waiting for: (DQG Tiny) 21700 EDCs.
Henk4U2
Henk4U2's picture
ZoomieFan wrote:
Capacity is a little less than I hoped for. Any idea what's the difference with "this":https://www.imrbatteries.com/samsung-48g-21700-4800mah-flat-top-battery/ version?
The color rendering of the IMRbatteries website. Mine is gray and has the same text as the battery in the picture.
PERMABattery
PERMABattery's picture
Last seen: 3 years 8 months ago
Great Job as always, HKJ! I will show it to our battery pack engineers for reference. Many thanks!
Custom Battery Pack Solutions
ferongr
ferongr's picture
Last seen: 10 months 2 weeks ago
Wondering whether the 48G would be okay to use for a pulsed, low duty cycle (5 sec. on, 30+ sec. off), 45-50W max. application with a 3.3V cutoff voltage.
HKJ
HKJ's picture
According to specifications:
It looks good enough (I would expect double current needs four times the cool down time, i.e. 25% duty cycle at 2×9.6A)
But is would not guess on cycle life.
Satan@103TFS
Last seen: 2 weeks 1 day ago
Since GB is only practical place I can order battery wonder is this the same as SS 48G https://www.gearbest.com/batteries/pp_824699.html?
Agro
Agro's picture
Said to be the same. But as with most rewraps you won’t know until it arrives.
