UM25C, can it be wired to Win7 instead of Bluetooth to display graph?
Anybody have one of these? Want to know if it can display the graphs on Windows 7 by USB connection or does it only work wireless?
https://www.aliexpress.com/item/UM25C-UM25-USB-2-0-Type-C-Color-LCD-Tester-Voltage-Vurrent-Meter-Voltmeter-Ammeter-Battery/32858626590.html?spm=a2g0s.8937460.0.0.qq3HD0
Not 100% sure, but I think it can only communicate via Bluetooth (eg. use the built-in bluetooth in a Windows laptop; or get a Bluetooth USB adapter for a Windows desktop that doesn’t have built-in bluetooth.). I’m using a Windows 10 desktop with a Bluetooth adapter to communicate with the UM24C (previous lower version of the UM25C)
I thought that may be the case, thank you d t a. Got a new laptop recently and just checked and it does have Bluetooth.
You may need a USB to TTL adapter and an optoisolator. Keep in mind that high voltages can damage your USB port or even your computer.
YZXStudio ZL1280 can be wired.
” this device allows remote data logging by connecting a UART USB/Serial adapter”
“Users will need to use their own serial communication software for the actual logging and data analysis though. The USB Power Monitor simply sends the raw data.”
