Nice Iāll be waitinf
Love the rainbow tailcaps and trimmer adjustment. Iāll definitely be in for 2 of those.
Yep Iām in the queue too! :+1: That rainbow one is fantastic, so is the other lol.
Iād be ok with a spring to solder so Iāll have a look, thanks.
I will set up my sales topic in the next few days
Rainbow would be perfect for my colored S41S
Why doesnāt it work, do you know?
I use boards that replace the washer, so they are way more effective than on the switch board
any color combination you want
green and blue based phosphor LEDs(white, pink, ice blue) are most efficientGen one with balance resistors and trimmers 2x3 LEDs
6 LED
8 LED rainbow
Gen. 2 version has a voltage regulator and trimmers for brightness adjustment
the v2 cross pattern for trimmers are ordered
Okā¦Soooā¦Those werenāt turnkey so where are the lead wires supposed to be soldered to (which Iāll have to have someone else solder)???
I find this thread after just buying these
The rainbow ones look very cool.
Positive wire gets to the tube contact
negative gets to the spring
replace washer with board and just connect to to both switch connections
pinkpanda3310: led4power:ā¦.Iām donāt know if it fits S41.
I just tried it in my manker E14 (same as S41) and it does not fit.
I guess it could be made to fit as it is close. Diameter is the problem, I think it would fit nicely otherwise. However, myself, Iām not willing to file down the switch nor open up the threads in the tail.
I will soon offer ILC-1 kit without brass ring at significantly lower price than assembled ILC-1, top and bottom pcbs have 16.5mm diameter , so such "ringless" ILC-1 should fit in more lights (brass ring is not really necessary, but without it switch and top pcb should be glued to prevent twisting).
Aah, that makes sense why the brass ring is there
Pulsar: pinkpanda3310: led4power:ā¦.Iām donāt know if it fits S41.
I canāt see the images
Thatās how I see them
Try againā¦
Did it work?
If not - itās just a pic of some measuring calipers in the tail cap and on the switch. ID of tail cap = 18.05mm OD of switch = 18.19mm
Howās do you get to the spring when the board the switch is mounted on, is between it?
Try againā¦ Did it work? If not - itās just a pic of some measuring calipers in the tail cap and on the switch. ID of tail cap = 18.05mm OD of switch = 18.19mm
I see you didn't remove kapton tape from brass ring?
Lexel:Positive wire gets to the tube contact
replace washer with board and just connect to to both switch connectionsHowās do you get to the spring when the board the switch is mounted on, is between it?
both contacts are on the switch
I see you didnāt remove kapton tape from brass ring?
Doh! Good eyes led4. Without the tape it measures 18.08mm. I guess I could force it but since I donāt want the switch in that light Iām still not going to ā¦
Depending on the machining it might well fit in other E14ās / S41ās :question:
I don't have any of those lights, are tailcap parts compatible with Convoy(especially threads)?
