Got mine today.
The reflector has some marks, the LED is far from centred.
I tried the rear button and I get a green/red blinking when pressed. When pressed again it stops the blinking.
But the light does not turn on with the main button, not even a sign of life form what is meant to be the battery indicator in the centre of the button. Am I missing something?
So I managed to dismantle a bit and see what the issue was. No idea what it was, but when I put it back together it started working.
But mode 4 and 5 has massive flicker. And it actually doesn’t change mode as its somehow interrupting the mode change, even to turn on and off. Its almost like I have to keep trying until I get the perfect timing where there is no interruption for it to work. The battery level light in the middle of the switch also flickers.
So mode 4 and 5 are completely not possible to use on my light. So I programmed one button as lowest output and the other as highest, and that allows me to exit when stuck on mode 4 and 5.
Its not batteries issue.
If you read my post I explain that its got flickering issues after I manage to disassemble the light and put it back which miraculously made it work.
I was able to correct a bit of the centring of LED. You can remove the whole Reflector head and get straight to the LED and MPCB.
Yes its only a Beacon, not very useful. Would have been best if it was a tail click switch like the older model. To be honest I think the older model is a bit better as it has a click switch and a magnetic rotating mode switch. So much easier to use.
Ill try both lights tonight, but seems like they are about the same in throw (even though the old has 200lumens more) and spot size when I tried inside, making the older model much more compact as its a smaller head.
I will see how they differ in throw tonight.
Yes, I understand that you dismantle and put it back, and it start to work, but it has flickering issue for mode 4 and 5.
I meant to ask do you try different batteries to troubleshoot the flickering issue.
