I just ordered a real 22mm Super Engineer II from Amazon for my new Seiko. The fake ones are not nearly as good. I know because I bought one for one of my Timex’s. The clasp is thin and doesn’t clamp well. The band it’self isn’t bad, but uses push-in pins instead of screws. I already had to re-push a couple of them in after a couple of weeks. I ended up putting loctite on them. That said, you get what you pay for in most cases.
I bought it for my Amphibia and I didn’t want to double the value of the watch by the bracelet.
I had no problems with the pins but I had to bend the clasp slightly for a better fit.
Thanks Ven. I’m loving this new watch. It’s been 3 days since I received it and it hasn’t lost or gained a second so far. I’m sure it’s well within it’s 15 seconds a month spec
I’m glad I don’t obsess about my few grandfather clocks’ accuracy.
Hard enuff to find repair when they quit.
The last guy showed up in a Cadillac Escalade that wanted mileage and portal to portal from 250 miles away.
We have a local guy that has retired, butt will accept the action iffn I can remove it from the cabinet and transport to him.
Wish me luck, I’m a clutz,
Where is the compass? cool though it does technically need one
and the latitude adjustment
amazon has them with both for $20 or $30
lots taller than this though
I calculated my new Seiko (Tuna 033) diver watch’s accuracy. It’s minus 5 seconds a month. I wish it was plus 5 seconds a month instead. Makes it easier to correct. Oh well, it’s light years better than all my automatics. I’m extremely happy with this watch.
