You can drive 6V LED with 2 18350 1200mAh cells without driver
Or wait for my boost driver which will be not cheap
You know… I want to buy the FIRST (21mm) boost driver you sell Lexel :+1:
I was just slummin’ around :sunglasses: for something that might have been doable with available parts since I don’t need a UI- because OF your FET tail switch!
I just want RAW POWER from an 18650 in a C8 with an XHP70.2 (is all) :innocent:
Thanks for entertaining my ideas (and educating me) guys!
Not cheap as in $20-30 or as in $30+?
Either way I’m still in for at least one
about 21€
Mouser managed to restock the chips so I bought now 100
Thanks again Loneoceans (and Lexel)… I (again) appreciate your time and patience as you both educated me here on this post.
I’ll try loneocean’s idea: using TWO 18350s in my C8(s) host I am building up next. I’ll run them DD’ed through a board (with no chips/driver “parts” on it- just a bare board AND Lexel’s FET tail switch).
Lexel just said (in a PM to me just now) that I could run a (shaved) XHP50.2 about as good as it’s gonna’ get for throw (given my form factor and it’s limitations with the C8 and using either DD or his driver)— that was also something I wondered about.
So changing gears from the XHP70.2 to the XHP 50.2 in a high tint— so when I shave the dome, it will fall down to about 5k(ish).
I will also still buy one of Lexel’s drivers when he gets them done too— I LOVE my NarsilDs in my C8Fs.
Love the options guys! You BOTH rock :+1: (… best I can do, no little smily with an air guitar available)
I’m so going to wait for boost driver
But is it long wait lexel?
Lexel can you make a Buck driver for Convoy L2 to drive a dedomed XP-G2 with 6A and with 2S battery config? Or for maximum throw I will be more happy with one of your Osram black flat drivers in my L2 with a black flat led and 1S battery config? How much current a black flat can handle?
Buck drivers:
Input 2S-25V
Output 1-8A as requested
20mm
4 layer for better thermal properties
Black flat draws too much current from a high drain 26650, better to go with a Buck driver 2S on 4.5A
Hmm. I just like the Short L2 But I don’t want to use 26350-s. How much is the too much current? I don’t really care about runtime. Just max throw in a compact form. Or the current will be too much for the driver? Or like the XP-G2 the forward voltage going too high? Sorry for lot question but Soon I will be ordering from you some boards or complete drivers. :money_mouth_face:
DD driver with high drain 26650 and bypassed spring can kill a Black Flat, just too much current
The MOSFET can handle like 30-40A or so on the board thermally
Ah now it is clear! Or I need to make a lot 7135 driver to give the led about 4,5A and I can keep it in single cell form.
stacking 7135s is one option
the other is to have enough resistance from Cell PCB and springs
17mm 1s boot for xhp35 available?
I am currently making progress with them
Bistro HD OTSM got modified and seems to work now, still need to fine tune modes
Any updates on the boost drivers? My D1s is waiting
Yes me too.
A boost driver for a Convoy S2+ and a 144AM would be legit AF.
I think many of us are waiting on the boost drivers… Having said that, I think Lexel is having issues with the firmware (narsil or bistro) working properly with the new drivers and he’s reached out to the driver gurus but they seem to be busy/nonresponsive.
NarsilM drivers will take longer as the Boards need to be changed again as well firmware modified
I’m just now seeing this thread. Sorry.
Texas_Ace already built a GT with the 70.2.
I seem to recall he upped the amperage to around 8A (12v). He was getting over 7000 lumens and I think 1600 meters.
I am not familiar with the black flat. Too small and weak for my needs.
OBF should get close to 2Mcd
If using normal CRI70 70.2 I estimate 650kcd with 12V 6A Buck driver possible to go to 7A, over 7A the sustained lumens do not increase much
I should get this week new boards for a far more efficient MOSFET than the old
at those currents it is critical to bridge the carrier springs
