David, thanks for the info. I don't mean to be a bore, and I'm sorry if this has already been asked, but what is going on with the most popular 700 series SRMs? Why is there limited or no availability for the SS-710 and 763? Are they in-between production runs, or undergoing changes?
Thanks David. I understand the issues with large folders and fixed blades, but still cannot understand how they could let their most popular small folders run out of stock for so long.
For the Tekut LK5033E, there is no money clip, no lanyand hole, not suit for EDC; for the Aluminum Handle, it is not textured, so it feels not safe to hold it (it may slip when your hand sweats).
for the Ceramic Material, yes, it is easier to break than steel . but it is as sharp as steel (or more sharper) and it lasts longer for cutting. and it never rust. so it depends on where you are going to use it.
I have no idea about the blade length, but the blade shape is pretty easy to explain. It's a rescue-knife shape, with a turned down tip so you can stick the knife's spine against skin in order to cut off clothing or a seatbelt pressed against someone's chest, or something of that nature. Basically if you need to cut something off of someone you want a shape like that, that's also why the blade bends upward in the middle, to give a higher cutting angle if you thrust it forward.
