That is the plan, to possible make the BLF lantern interchangeable with the Q8 battery tube body/base. I wish i had an extra Q8 body/host so that i could incorporate that into the upgraded prototype. Thorfire built a great light with the Q8, and know they could do the same with the BLF lantern.
Thanks for the update, DBSAR; hope you’re able to find some joy and peace in this difficult season you’re going through. We appreciate you and can wait — your happiness/health is most important.
That would be awesome. Right now I have the original prototype taken apart to re-design & simplify some parts, but incorporating the Q8 components to the revised prototype would be a benefit to its compatibility, and possibly lower cost of each unit if we can work it out with Thorfire to build the production model, as they already have the design CADs for the Q8 body parts.
If they will code me one from Amazon, I told them I would pay to ship it to you in Canada. I really want to see this project happen. This is the best lantern idea to come around in a long time. Hopefully they will respond to my email sometime tomorrow.
*+UPDATES,April,16,2018 -
So with the help of fellow member here on BLF, RobertB and Miranda of Thorfire, we acquired a Q8 to use as a new prototype for the BLF lantern. it has been discussed before that building the lantern as compatible with the already awesome BLF Q8, will reduce costs especially if we work with Thorfire to build the production model, as they already have the blueprints and design criteria for the Q8.
i do need to talk to talk to the developers & designers of the Q8 driver, as it may be possible to use that driver for the lantern, if i can figure out how to reduce the maximum output amps on it maximum modes to around 1.2 amps, ( or even up to 1.5 ~ 1.7 amps to the LEDs then somehow have it step down either by timing, or wired remote temperature sensor mounted on the lantern head. As we all like the mode-groups & programming of the Q8, they woudl probably work great for the lantern too. (only issue is if that will cut costs down, and if we can add the charging input, (and possibly the USB powerbank feature)
So once i receive the Q8, it will be focused on as the prototype for the BLF lantern. I hope the team from the Q8 development can chime in here with help & suggestions.
I have already spoke to Miranda of Thorfire on the thoughts of working with them to build the ultimate BLF lantern.+*
I hope i can talk with Tom-E on the driver before i decide to utilize the original Q8 driver as the lantern driver, ( if not we will have to go with the new complete design.
I’ve held off your far, but now that things are moving I have to admit I really want one of these. Put me on the list for 1, depending on price and release date.
If you just want to use (as close as possible) the Q8 driver design but lower the effective max output, the simplest thing might be to just replace the FET with a bank of five AMC7135 chips, and use the same firmware. You would then have a 5 + 1 driver instead of the Fet + 1 driver the Q8 has now. If the more stable 350mA chips are used, the max output would be 5x 350mA which is 1.75A total. If you wanted to save one chip and the space it takes up, the driver code would have to be modified just a little to use both banks (four plus one for a total of five) together in the highest mode.
By the way, Tom E isn’t the only one that could make the (very minor) adjustments needed to the code for this modification. Texas_Ace or ToyKeeper could easily do it, I think, as well as others. There are also several who could draw up the physical layout for the modded PCB.
