TA, are you testing them outdoors and at what meter height and distance?
High output lumens tends to have more reflections into light meter from surrounding that’s not open space.
That is a good point, these tests were indoors. That is a possible explanation. Although in past testing I have not really noticed a difference in readings at the same distance indoors or outdoors with my particular location.
Once the new meter shows up I will take some outdoor readings.
I will say that these numbers are higher then I expected.
Even if numbers of low output leds like an xhp30 are lower and numbers of more powerful leds like an xhp 70.2 are higher due to a low quality meter or indoor testing, it is clear that shaving or dedoming increases throw significantly even with the xhp 70.2!
Yes, the xhp70.2 seems to gain around 40% throw from a dedome, much more then I expected.
Wow! I’m very interested in a TA GT XHP70.2 driver when they’re available. :+1:
Forgive my ignorance, but I’m having difficulty understanding all of the modifications needed to get the 70.2 into the GT.
Do the battery carriers require modification? Does the 70.2 need a new MCPCB or can it be reflowed onto the GT’s stock 35 board?
Thanks, Texas_Ace!
It will need the Driver, MCPCB, XHP70.2 LED itself and Centering ring.
The stress test I ran was to see if the carrier springs could handle the power and they passed, although they were pretty warm at the end of the test.
I am working on getting the mcpcb’s made and getting them sold but it has been a hard sell for lumintop and they have still not given me an answer. If they don’t sinkpad makes an mcpcb that will work with some sanding/filing although it is not quite as nice.
TA, Where did you get the GT centering rings for the XHP70.2?
Thanks for the explanation.
I hope Lumintop gets on board after seeing some photos of your 70.2 protos…
I 3D printed them
I actually printed a bunch of different sizes since the height plays a big role in the focus. Around 2.5mm saw the highest lux but it also has a dark spot in the middle at longer ranges. By going up to ~4-4.5mm it removes the dark spot with minor effects on the lux.
Yes, I am hoping they do as well, if these numbers hold up I am guessing they will, even I am shocked at these numbers if they are real.
I would not believe them if I had not seen them myself and I still doubt.
I am interested on the MCPCB with 70.2
I am interested in modding my GT with a 70.2. I will purchase the parts if they are made available…
Guys, how hard is to replace bottom part of GT, where battery tube goes in?
Mine is broken, Lumintop offered that they can repair that or I can do it by myself.
Mike
Well, it is very simple, you just unscrew the head and then screw it back on the new light engine.
The hard part is getting the head off. You will need a strap wrench almost assuredly. I was able to get one apart without a lot of hassle by loosening the bezel first and then the head. I carefully clamped the light engine in a vice to do this.
some are much harder to open though.
I would try opening it first and see what happens.
I noticed on CPF that Vinh is in the process of modding a BLF GT.
His modded one will use XHP 35 HI emitters arranged in 18 quads … 72 emitters total! :+1:
I guess he is bored with CFT90 mod now.
He’s said before he cares more about lumens than throw.
My prediction is that is going to cost around $20 per emitter…
He says reflectors waste too much light outside hotspot, so he likes tir. That could be why he choose not wasting lumens over throw, but i think he likes throw, so he must build massive world record flashlight output of lumens in order for tir to throw as much as it can.
I don’t think it will be lower than $30 per led. His goal for Sirius is 80000lumens and 600kcd.
Mike
These pictures may help.
The weather is terrible tonight in this part of the world so no beam shots. Before I do take them I will have to replace the led as it has a black spot on it which appeared this morning. The cause has not been investigated yet. Starting with the tailcap. This picture shows the lanyard strap hole in two different places. The part the hole is in rotates 360 degrees around the tailcap itself. The hole has a diameter of just over 4mm and the width is just under 5mm. Wall thickness is around 1mm. […
Post 61 had some more pictures.
