Need help deciding....
56 posts / 0 new
Blackdragon1230
Last seen: 3 years 7 months ago
Ive got a Skilhunt H03 and love it, but find myself wanting a headlight with more power every now and then. Im stuck with a choice between the Armytek Wizard Pro V3, or the Olight H2R Nova. They both seem awesome, and are about the same price. So from those here that own either of them can you throw some opinions my way. Thanks in advance for all reply’s.
sp5it
sp5it's picture
Last seen: 3 hours 13 min ago
Buy both. Test and sell not needed one.
Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
 If a lot of people listen to Slayer, the world would be a better place to live" - Tommy Wiseau
Mkduffer
For what it’s worth, I really like my Nitecore HC30. 160M throw. Nice and light. Had it for 2 years and no issues.
People say I’m a flashaholic like it’s a bad thing…
mcfarlie6996
mcfarlie6996's picture
Last seen: 1 year 9 months ago
Just to note, both of those lights have thermal regulation and will drop down to around 600 lumens within a few minutes under normal conditions due to the massive heat they create. It’s a good thing that they drop because you don’t want them to destroy themselves from overheating let alone burn yourself. But I thought you should at least be aware of that since after they drop in output, they won’t be much brighter than the H03 that you are hoping they’d be. If you want a light that can maintain 1000+ lumens, you need to find one with much more mass to handle the heat.
On a side question, why do you think you need more lumens?
Blackdragon1230
Thank you, and yes i do know they get very hot, kinda like the Emisar D4’s. However my eyesight isnt so great anymore and there are times when i do need just a bit more light, and i tend to use headlights way more now than hand held lights. Hope that helps with the explanation. Im at a point when i could even use 2 lights at once sometimes.
ValuseekeR
Last seen: 7 months 1 week ago
Really happy with my H03 and figure to just have another light available for more output if needed. I do sort of miss the red led option I had on my old headlamp though. Maybe should’ve given that more thought before the impulse buy…
Blackdragon1230
I really like how compact and light weight the H03 is, and the floody TIR is perfect for me. Honestly wish Skilhunt would just take the H03 and scale it up and fit it with an XHP-50 led, because i love the ui on it.
Blackbeard
Blackbeard's picture
Last seen: 1 hour 56 min ago
I like the H03 but its very floody, if it is misty out you get a lot of the beam reflecting up close near your face which is not pleasant, I would assume the H2r with similar optic would perform like this too. Don’t mean to hijack thread but can someone also reccomend a good thrower headlight? I also have a few 3xAAA energizer models which I like and have decent output, an older Petzl which is kinda dim in comparison and H1 nova but none are really throwers.
Macka17
Last seen: 1 year 11 months ago
Hi.
76yr old so in your eyes group.
I have a Jetbeam JET-1 MK Pro in pocket. Small and fits between teeth comfortably for extra close up lighting, or more distance.
Your existing one with the little Jetbeam would cover nicely while allowing you to keep the existing light.
mcfarlie6996
Blackbeard wrote:
Don’t mean to hijack thread but can someone also recommend a good thrower headlight?
Hey Blackbeard, so staying with the same form factor, your most throwiest right angle headlamp would be the Sportac PH10LC2 with the XP-L HI emitter. Throws 229 meters. Feel free to PM me any questions.
Sportac PH10LC2
Sales page
From this sales page, I’d also suggest getting the XP-L HI Neutral White tint version.
Satisfaction
Satisfaction's picture
Love my H2R
beam0
beam0's picture
Blackdragon1230… here’s another one in that price range to consider: Acebeam H15 (XHP70.2)
Also, for a lower price (and if NW is not a requirement) you could also consider the Nitecore HC33
I don’t own any of these lights yet but I was basically in the same shoes as you on this, so I’ll relate the findings of my somewhat extensive research for the decision.
I also had an H03 NW but it went kaput over a year ago and I replaced it with a Nitecore HC30 NW. The Nitecore is similar to an H03R in that it has a clear lens over the reflector, so better throw than the H03. I’ve also come to prefer the top mounted switch of the Nitecore much better than the side mounted switch of the Skilhunt.
Like you, at some point I decided to look into a newer higher output angle light, and had considered the Wizard Pro, H2R Nova and Acebeam H15.
Runtime on turbo wasn’t an issue for me, I’m happy to use short bursts for that.
  • 1st place:
    My favorite was the Olight, mainly because I really like the optional magnetic charging dock base. Even though I have 3 chargers, tons of cells and I never us the USB charge feature in several lights that have it, I know I’d use the Olight base because it’s just so dang convenient. Plus the top switch, NW option and great UI.
  • 2nd place:
    Second place was the Acebeam, and nearly a toss up between it and the Olight. I REALLY like the magnetic mode selector ring. There’s a NW option and it has a top mount switch, but no magnetic tail. And although it does have a clear lens, I believe it’s the most floody out of the three due to the XHP70.2 emitter.
  • 3rd place
    Although it does have a magnetic tail, the wizard pro was my least favorite, one reason was the side switch instead of top. There’s no NW option, however I’ve read the WW is slightly above 4000K and quite nice, but it reportedly has the lowest max output of the three.
  • Nitecore HC33:
    Since the above three are quite expensive, I’ve also been considering is the Nitecore HC33, It can be had for far less money than the others, however there isn’t a NW option. I have read the tint is pretty close to NW though. It does have a magnetic tail, which is important to me.
The Armytek, Olight and Acebeam are all a bit longer than what I’m used to with my Nitecore (110-112mm vs 98mm)
The HC33 (105.3mm) is a lot closer in size to what I’m used to. (for reference the H03 is 100mm)
There’s plenty of reviews on all of these but here’s some of the (non review) discussion threads I was reading:
http://budgetlightforum.com/node/45819
http://budgetlightforum.com/node/57709
https://www.candlepowerforums.com/vb/showthread.php?443659-Need-recommen...
I haven’t made a decision one one of these yet because I’ve come to the realization that before needing more brightness I need more angle flexibility, so I was waiting for the recently released Rofis R3. with multi-adjustable angle head. I need to get one of those next.
tatasal
Last seen: 2 hours 58 min ago
So you thought posting a thread for which light to buy will make your decision easier?
You are terribly mistaken ! Beer
beam0
beam0's picture
Sportac PH10LC2
Sales page
13,100cd / 229 meters is quite impressive throw in a angle light, I forgot about these Eagtac/Sportacs thanks for posting!
Possibly the next best throw in an angle light is the XHP35 Nitecore HC33
“Precision Digital Optics technology” with Peak beam intensity 8750cd, and throw distance up to 187 meters.
“Flood Lighting System” produces a wide 100 degree beam angle.
Kind of a contradiction in terms, I guess it has both a wide spill and good throw.
It does have a SMO reflector and clear lens, I’m thinking with an emitter swap to a (NW) XHP35 HI it could be quite the thrower.
mcfarlie6996
Actually it’d be the Imalent HR20 with 225m of throw. Those XP-L HI emitters really help in that aspect. The HR20 is actually pretty cool because of the infinitely variable output where it has a rotating knob to control output between 1 and 1000 lumens.
beam0
beam0's picture
Thanks, yes that would be the next best, and I agree the variable output (actually very small steps) is a cool feature. Now I vaguely remember coming across it before and reading that review, sounded great but there seemed to be some random quality control issues, same with their DM21 (non angled light) with that same rotary switch setup. Hopefully they’ve got any issues worked out in the current production.
Here’s some product links:
https://www.gearbest.com/headlights/pp_1621963.html?wid=21
https://www.banggood.com/IMALENT-HR20-XP-L-HI-1000LM-18650-Outdoor-LED-Headlamp-Flashlight-p-1078339.html?rmmds=search&cur_warehouse=CN
beam0
beam0's picture
Looking at the Imalent HR20 thrower angle light mcfarlie6996 pointed out caused me to come across another (High output) option for the OP to consider:
IMALENT HR70
  • XHP70.2
  • 3000lm max
  • 103mm length
  • Top mount switch
  • Magnetic tail cap
  • Magnetic USB charging adapter
  • Great UI (non rotary)
  • Great mode levels:
    Low – (30 lumen – 50h)
    Mid Low – (300 lumens – 4h 15min)
    Mid – (700 lumens – 1h 36min)
    High – (1500 lumens / 3min) -> (1000 lumens / 69min)
    Turbo – (3000 lumens / 1.5min) -> (1000 lumens / 66min)
Great features and a good competitor of the Acebeam and Olight, however I’m not sure there’s a NW option.
Review: http://budgetlightforum.com/node/59927
Product Links:
https://imalentstore.com/product/hr70/
https://www.banggood.com/IMALENT-HR70-XHP70_2-3000LM-Brightness-Magnetic...LED-Flashlight-Hiking-Headlamp-Torch-p-1258231.html?rmmds=search&cur_warehouse=CN
Blackdragon1230
You are quite right, now i have 2 more to consider. I seriously need to win the lottery….lol.
Blackdragon1230
Beam0 thank you so much for all the info. I think the Imalent might end up being the one i get. I find anymore i prefer to use headlights so i can be hands free. I’m glad they are finally pushing headlights along like they did some of the multi emitter lights.
puglife2
puglife2's picture
Last seen: 10 hours 54 min ago
i like the tint on the wizard pro (warm), but i don’t know for the olight
the magnet is good too
edit : i don’t know why the second pic is reversed.. oh well Beer
Blackdragon1230
Wow there is quite a difference in those tints. The Wizard Pro also looks like it has a slight bit of a hot spot. In general i prefer a slightly warmer tint though.
puglife2
puglife2's picture
maybe in this picture at 6” from the wall, but in everyday task not at all Party
beam0
beam0's picture
In the second pic it appears the v2 CRI90 warm was moved to center? And v3 is now to the left << ?
beam0
beam0's picture
You’re welcome, thanks for starting the thread, it made me rediscover all these options again.
I agree about the Imalent, it checks all my boxes too, except the most important one. As usual when I find a light that has all the best features there’s no neutral option, this continues to happen again and again. If I’m going to have to live with CW I may as well just get the Nitecore HC33 for half the price.
In the Imalent I really like how it has 1500lm & 700lm modes below the turbo, and also the Zebralight type UI with 1-click on/off, plus it’s a bit shorter than the others. If I’d ever see it on a really great deal I’d get it and try an emitter swap.
puglife2
puglife2's picture
yes and yes Beer
Blackdragon1230
Perfect agreement with that cold white emitter. I will do a emitter swap and put a 5k neutral white in it. One of my biggest requirements for a right angle light is the magnetic base. There are lots of times when im working on something and find it convenient to stick my light to something. I think one of these days im going to sit down and design and sketch up my perfect headlight. I have a few ideas :).
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 30 min ago
@Blackdragon1230, perhaps you should do an emitter swap with the Nichia 319A. Very low forward voltage, meaning better efficiency and less heat.
beam0
beam0's picture
Isn’t that a 3V emitter? He’s replacing an XHP70.2, so maybe he could use the 144AM 90+CRI (6V)?
https://www.virence.com/product-page/nv4l144am
You suggested the 144AM in a different thread about modding an S2+: http://budgetlightforum.com/comment/1302881#comment-1302881
BlueSwordM
Ohhh, I didnt notice he wanted a 6V emitter in his Skillhunt H03.
How is he going to fit a boost driver in it though? Headlamps are even tighter compared to normal lights.
beam0
beam0's picture
He was referring to buying the Imalent HR70 (see post#26 above)
BlueSwordM
If he was referencing to the HR70, then go for it!
The 144AM is absolutely beautiful with an OP reflector.
If I didn’t damage it by mistake, then I would have posted some beamshots already.
