Texas_Ace MT09R Modding thread, 20k+ lumens, 80CRI, can start fires? Yes please.
Ok. I got it. I am happy with the result. Mt09rTA did great.
pic upload
Sent mine Fed Ex this morning, they said it would get there Friday morning :slight_smile: Can’t wait!
Maybe Dale, in holding off on shipping more lights, will have time to ship my charger that I bought.
Back in January.
@Texas Ace, if the package you received is Blue MT09R XHP 70.2, that should be mine
This is not convenient at all!
Lol.
So an N2 bin has 7% less output than an N4 bin “generally speaking”. You would think each bin would have a tolerance of + or - 3.5, but it doesn’t. It’s + or - 7 or 14% total! :confounded:
Here are common 70.2 bins and their lumen range at 2.1A, 6v and 85°C.
K4 1290 1380
M2 1380 1485
M4 1485 1590
N2 1590 1710
N4 1710 1830
P2 1830 1965
With such a large tolerance you can see where an N2 might fit in the range of a M4 or N4. It’s a wide tolerance of 14%.
So an N2 could be anywhere from 1540 to 1760. Basically anywhere from its normal range to the upper half of the bin below it to the lower half of the bin above it.
For example, from 20,000 lumen to 23,000 lumen is 15%. So you could see such a large swing in output from a single bin. (assuming all 3 emitters in one light were on the bottom end of the tolerance and the other 3 were at the top end of the tolerance. This is pretty rare, though. It’s usually in the middle somewhere)
It is only when using FET drivers that forward voltage has a big effect. With most factory drivers the forward voltage has little to no effect at all. I don’t think the 80cri has a higher efficiency, either. It gets its higher output from drawing higher amps which produces more heat and drains the batteries faster. Correct me if I’m wrong TA. The forward voltage stuff is a bit hard for me to understand.
I made a mistake, I meant to say Terry not Dale lol.
I will watch for your light, I know I have several showing up in the next few days, gonna try to knock them out by this weekend before I start on another project that will take my time for a few days.
Very possible, I will go through the mail after I finish SVK89’s last MT03. I have had his lights long enough and want to get them shipped out tomorrow.
Yes, that is more or less correct, there are some highly technical things that can effect it but not enough to matter in 98% of situations.
Higher CRI emitters generally have lower forward voltages in order to keep efficiency up to par. In this case it can handle the extra power so that helps a lot but yes, it will get hotter then the same light built with P2 emitters.
They both get hot so fast I doubt most would notice the difference though lol.
Great info thanks!
Of the three, which one can use turbo the longest? I’m suspecting the x45 due to the largest head? And which one has the most throw….mt09?
Ok… if I want to order and modded where do I start? Do I pm someone or go ahead to the site and order it then pm? and can you do some night shot comparison of different lights and the modded MT09?
I might just get this one and called it the final flashlight I’m going to buy… until I see a 50k lumen fairly compact handheld cannon (yes I set the numbers high so I don’t go and buy another new light (with good UI/CRI) that’s capable of doing 22.1k lumen lol)
Pretty sure my version 1 MT03 arrived at your place today. You are on a MT03 roll… :+1:
Thanks. Can’t wait to see the transformation.
Keepitsharp
Ok, I just got SVK89’s final MT03 modded, this one is the best of the bunch, it is doing just under 23k lumens also with the 4000k 80cri LED’s.
Goes to show how the LED lottery can work, 3 lights with the exact same work, same driver and the LED’s are all from right next to each other on the reel yet a range from 21k to 23k lumens. Just no way to predict it.
I will get SVK’s lights packed up and shipped tomorrow.
You can order the light from Terry and then just tell him you want it sent to me.
Then PM me and we can figure out exactly what you want and get the order in motion.
Very possible, I have one more light I need to finish and I will dig into the new stuff.
Thanks so much!
Gotcha, Terry, Not Dale. I think I read that Dale was at the doctor’s with his daughter? Hope she’s doing alright, and that it’s nothing serious.
And thanks for trying to get to my light!
From one Houstonian to another - Thanks!
Yes, his daughter is doing fine and is back home last I heard a few days ago.
Ok, I got another light finished tonight. This one for Newlumen. He sent me an MT07S that came setup for 4S from the factory. First I had to convert it to 2S which was much harder then I first thought but the results were worth it.
In stock form it was doing 4700 lumens.
Now with a 2S conversion, Spring bypasses, TA driver and 5700k P2 LED it is doing a bit under 10k lumens! (It peaks over 10k for a few seconds)
It legitimately doubled the lumen output. I am quite impressed. This is the most powerful single LED flashlight I have seen to date. I knew that the XHP70.2 P! was capable of this from a cold start from my testing but never actually seen it pushed this hard in a light before.
Holy cow! How does this throw compared to the MT09R XHP35?
Yeah, I was quite surprised as well.
A very quick and dirty throw test has the MT03 pulling ahead in throw by about 24% vs the MT07S.
This is to be expected, even with multi led setups the larger total reflector size is still going to generally throw further. Plus the XHP35 is a much better thrower.
Now with a dedome the MT07S should be on par or possibly even slightly ahead.
