Ok, starting work on Keepitsharp’s V1 MT03. I have to agree the V1 is a step up in quality, the ano appears to be HAIII and it just feels a step up.
Before measurements with the stock xhp70 (not70.2) was 11k lumens.
I also realized this is my last 70.2 driver for the moment. I already have the components for 30 more here and the PCB’s are supposed to arrive early next week. So it should work out well with the next batch from Terry that should be arriving about the same time.
Thank you! Looking forward to the* after *numbers! This light was an early pre-order and some of the first had a few flaws. They did try hard to put a good product out.
Yes, as soon as I opened it up I noticed said flaws. Not major but existent none the less.
The biggest of which is the too short battery tube, obviously you have to be careful to get good contact with the cells but not crush them.
Ok, I just finished it up, and final numbers with 4000k 80cri LED’s, TA driver and bypasses are just under ~21k lumens, much improved from the factory setup for sure!
I think the slightly lower numbers are from the very subpar solder used on the mcpcb connection, I tried to clean it up but it has a lot of flux mixed in and I would of had to completely strip the mcpcb and clean it and then redo it from scratch to make any real improvements.
I did not figure it was worth that much hassle for a few hundred lumens but if you want me to I can do it.
Thanks… i knew already this mt07s was under driven from the factory. I have single xhp70.2 light but max output is 6700 lumen… this is a game changer… i cant wait to try it out…
Although you can also really see the efficiency drop off pushing it to that level. The 50% top of the ramp mod was doing almost 7500 lumens and going to 100% turbo only bumped it up to 10k but it sure got hot faster!
Needless to say I would only use turbo for short bursts as it is just a lot of extra stress for not much gain.
Now, with better cells, like 20700/21700 cells and lower resistance contacts, do you think it would be possible to hit the max lumen output, being about 27 000-28 000 lumens?
Further improvement should become reality soon when the 8x18650 tube is available. I think this should have a more positive effect on output than 4x21700.
With the P2 bin emitters there is some room for improvement if you could feed them more power. 25k lumens should be within the realm of possibilities I think.
The 80cri 4000k LED’s are already basically maxed out, I would not want to feed them much more power if I could. They are already being driven very hard indeed.
You would need to determine how much amperage you would need to max out three of the 70.2. In the L6, which uses a pair of 26650 cells, people tend to get around 18 amps. In a custom GT using 4 18650 cells you can get 21-22 amps.
So if we say 20A is what we want, then with 3 emitters we would need 60 amps (at 6 volts, not 3 volts). I don’t see that happening with 18650 celks, even with the extended MT09R battery tube. I’m sure it will increase current and output, but I don’t think it would give 60 amps.
On the other hand, we might be able to get 60 amps using 4 21700 batteries.
DBCUSTOM has a custom light using 3 xhp70.2 and he tried 2 of the new Samsung 30T cells in it (in series to provide the proper voltage). It pulled about 48 amps! That’s pretty crazy right there. Each cell has about 10 to 12 milliohms of internal resistance and are capable of 40A continous. I bet 4 of them in a 2S2P setup could get us there assuming the springs and driver could handle the current.
So to answer your question, Yes.
But why do that when you can build a 4 emitter light and run them at a more efficient level? 4 emitters at the same 60 amp level (15A each instead of 20A) would put out 34,400 lumen!
It depends on the cell. 4 of the new 30T cells should outperform 8 30Q as far as amperage. I think about 25% more amperage, but you trade off run time.
