A hole through the middle of the shelf. Press-fit plastic ring with a large brass button in the middle.
Fat wire (AWG 16? Gross overkill but why not?) from the button to the positive pad on the driver.
That’s just the first thought. There are surely other ways.
Here comes A1, a thrower sized between C8 and Emisar D1.
The host has the same basic architecture as A3. And the same major features.
It’s just 1 LED and a reflector instead of 3 LEDs and a TIR.
Reflector has exactly the same dimensions as Phoenix Electroforms PA19.01, so for the big budget users there’s an easy upgrade path.
This part costs $45 when buying 1 piece or $35 when buying 100. So manufacturer could offer it together with UCL2 window as a $50 option. Expensive…but I’m sure there would be buyers willing to pay so much for ~15% higher performance.
I got troubles picking LED for it, there are quite a few good options.
1. Dedomed LH351D:
- Cheap, especially considering that it’s a part of A3 / A7 lineup already
- High CRI throwers is untapped niche. LH351D enables the use of this LED
- Available in warm white
- untested throw
- probably OK, but worse than any other mentioned here
2. XHP35 HI
- very high efficiency at medium-high currents
- possible high-cri
- possible warm white
- expensive
- requires expensive driver
- and actually a different driver, adding R&D costs
- at peak power it’s going to oveheat quickly
3. Dedomed SST-40
- quite cheap
- good throw
- quite efficient
- only cool white
4. Osram Q8WP
- moderately priced
- extreme throw
- low efficiency
- only cool white
My choice would be to offer both Q8WP and LH351D. Q8WP is a really great thrower LED. LH351D covers the cases where it can’t do for minimal additional cost to the manufacturer.
Doing some performance analysis…let’s drive Q8WP to 7.3A to get round 1500 LED lm (note: this is Turbo mode, the light won’t sustain it). According to Enderman’s calculator with the upgraded reflector and UCL2-class lens this light gets 190 kcd and 1410 OTF lm. OK, minimal amount of dust and regular manufacturing tolerances will reduce it. Is 150 kcd and 1300 lm conservative enough?
With cheap alu reflector and regular AR coated glass calculations show 170 kcd and 1290 lm. Because of machining defects, the difference between calculations and reality is likely to be bigger for this one.
Dedomed LH351D should offer very roughly the same lm and half cd.
BTW, that may make no sense…
but here’s A1W. It’s just A1 with addition of thin rubber bag around reflector. The bag is filled with paraffin wax.
Today I drew an optional clicky tail switch, here presented with A1 but compatible with the other A* variants:
Technically the switch construction is based on GFS16 - FET (a necessity with 30T driving 7 LEDs), power indicator, its own li-ion battery.
This is not merely a mechanical lockout - UI should support changing modes with the clicky too.
If UI designer finds it beneficial to do a different UI for dual switch - it’s doable too as the driver can detect whether it’s powered with the switch or not.
How?
When turning on, the switch makes a quick pulse of power before actual full-on. This pulse can be detected by the driver (though this feature may somewhat increase the price).
A remote switch based on this one could be available as well.
Note: doing e-switch which would work like a clicky would make it like 4 mm shorter. But I guess dual-switch people don’t really want it.
I did some performance calculations for A1.
And received a quote for the electroformed reflector.
I’ll start with the latter…$45 one piece, $35 when buying 100. So manufacturer could offer it together with UCL2 window as a $50 option. Expensive…but I’m sure there would be buyers willing to pay so much for ~15% higher performance.
As to performance…let’s drive Q8WP to 7.3A to get round 1500 LED lm (note: this is Turbo mode, the light won’t sustain it). According to Enderman’s calculator with the upgraded reflector and UCL2-class lens this light gets 190 kcd and 1410 OTF lm. OK, minimal amount of dust and regular manufacturing tolerances will reduce it. Is 150 kcd and 1300 lm conservative enough?
With cheap alu reflector and regular AR coated glass calculations show 170 kcd and 1290 lm. Because of tiny machining defects, the difference between calculations and reality is likely to be bigger for this one.
Dedomed LH351D should offer very roughly the same lm and half cd. Hmm…maybe that option doesn’t really make sense?
I drew revision 2 of A7.
I didn’t like how it lacked the powerbank function, but was not sure if all components would fit on the MCPCB.
I did better calculations now and they should. But just to get extra headroom I increased the MCPCB size slightly.
Features (mostly repeated):
- 7-up TIR lens
- either clear or pebbled (if there’s demand, frosted is not a problem either)
- 7 LEDs, XP sized.
- Samsung LH351D
- dedomed Samsung LH351D
- Cree XP-L2 (pebbled lens only)
- 10 000 lumens for 5 seconds
- 21700
- magnetic charger / powerbank
- Texas-Commander / LD4 style driver integrated with the LED MCPCB regulating the light to 10+ amps. With Turbo above that.
- Unibody
- E-switch, ramping UI
- DQG style tail cap
- optional clicky tail switch. Also DQG style.
Thanks Agro.
I’ve been thinking about it for a while…and now I decided this is the way to go for the A family.
Let’s not make them 21700. But rather 21350.
Pros:
- smaller by 1/3
Cons:
- there are no 21350 batteries
So…it needs a little explanation.
First, there are no 21350 batteries now. But there are 18350 and 20350 now. And 21350 are likely to arrive eventually.
Why 21350 and not 18350 or 20350 then? Because it enables us to use extension tubes for 21700. And 21500 if they eventually arrive (18500, 20500 is available now).
21700 have 4600 mAh.
18350 and 20350 have 1100 mAh. And higher internal resistance which reduces performance.
Quarter capacity for 1/3 smaller size. Is that a good trade-off?
It depends.
If you don’t need more than 1100 mAh anyway - yes, it is. And seeing how many people EDC lights smaller than 18650 - I believe there are quite a few who don’t. On a twist, capacity reduction turns it from good powerbank to bad powerbank. So for those who EDC powerbanks and tiny lights - they would still prefer 21700.
So the real pros:
- smaller by 1/3 for those who don’t need more than 1100 mAh
- (optionally) smaller by 1/5 for those who don’t need more than 2000 mAh
- just as large for those who do need more energy
Cons:
- slightly costlier
- worse thermal transfer to the tail
- stylistically challenged
- when using smaller batteries - slight to moderate performance reduction (depending on model)
I added a rough outline of Emisar D1 to the pic.
Is it just me or has this thread seem to have turned more into “agro’s future projects” rather than “BLF future projects” ?
No, it has not.
It has not because I neither have the capabilities to turn these drawings into real lights nor will have them in the future.
So these are just drawings and will remain so unless someone different from Agro will decide to make them.
Seeing how little response they generate I conclude there’s little interest. And find it extremely saddening. Because few times in my adulthood I was as convinced I did something right as with them. And if there’s no interest, they will never be made.
That said, I almost monopolized this thread. Again. The reason is that there are apparently few people willing to discuss the topic.
Is it right? Is it wrong? I don’t know, it is what it is.
I am willing to discuss and I intend to continue. Because even if I’m mostly discussing with myself - I want this to be public.
Agro, time to buy a lathe and start making your own lights! Lol.
Yeah, these seem like very specific and customized lights, not something that can be mass produced easily and make tons of profit from thousands of buyers.
I would recommend modding or scratch building stuff like this yourself.
Sometimes building the stuff yourself gives more satisfaction than simply buying it
It’s not the time to buy a lathe. 3/4 of the lights which I tried to mod don’t work. Well OK, I broke 1 beyond repair, the others can be fixed, I just wait for tools / parts / motivation.
Anyway, lathe is way off. And I don’t expect I’ll ever be in the position when I’d consider it good.
I’m a bit surprised to read that these are very specific and customized lights.
Because I went out of my way quite a few times to make them more generic.
I did include some controversial stuff in them. This may be what you perceive as “specific and customized”. I pointed it out and presented the rationale. The purpose was to start a discussion. Because my point is not to have them made to my specs but to BLF specs. The discussion didn’t start.
Well first you were talking of a 21700 flashlight, a battery which almost nobody has, and now 21350 which doesn’t even exist.
Why would people buy a 21700 flashlight if they have plenty of 18650s and 26650s already, which are still better (power density) than any 21700 batteries that are available atm.
Stuff like dedomed LEDs, unibodies, magnetic chargers, etc. manufacturers simply won’t do for multiple reasons, the first often being cost.
Unless there is something special about the light, like super low cost, extreme throw, high lumen output, etc. it’s not going to draw in the thousands of buyers needed to create a new flashlight from scratch.
It needs to stand out in order for a manufacturer to jump on board with the idea.
It’s not cheap to bring a new product into production.
There is far more work involved than making a drawing a couple pixels big, and all the work needs to be paid off in sales.
If it can’t make the sales for whatever reason then you’re left with either building it yourself (like I do with my lights) or paying someone a lot of money for a one-off.
Just an off topic note:
Power density of current 21700’s is the same as the 18650 since it’s just a bigger version of it. The 26650 has lower power density since it’s not made by a major battery company.
The highest I’ve seen available is 4800mAh, which is lower power density than a 3500mAh 18650.
Also 26650s still have much more capacity than a 21700, so unless the goal is a super compact flashlight, if you care about runtime you will go with 26650 over 21700.
If you care about power density more than runtime then you would get an 18650.
I looked for 2 fairly new cells with the same continous discharge rates in order to make it as comparable as possible. Apples to apples, so to speak.
Samsung 48G – 4800mah 10A
This 21700 cell has a volume of 24.25mm3.
This equates to 198mah/mm3
LG MJ1 – 3400mah 10A
This 18650 cell has a volume of 16.54mm3.
This equates to 205mah/mm3
So they are pretty much the same – power density wise. The 21700 is about 47% bigger and has about 41% higher capacify. It’s not an exact scale up, but almost.
It seems Tesla is predicting their new 21700 will have a capacity of 5700-6000mah! I have not seen any batteries with that much capacity. Not yet, at least.
If this turns out to be true, then the power density will definetly exceed the 18650.
So far, I really like this quote from John Peterson.
“Batteries are chemistry in a can and changing the size of the can does not change the energy density or cost of the chemistry inside the can.”
In looking at my older quote above, I checked HKJ’s review of the MJ1 3500mah and it seems it’s capacity is closer to 3200mah and it’s max continous discharge is 7A.
His test of the 48G shows a capacity of around 4650mah and 10A continous.
These may not be the ideal batteries for comparison, but the power density is pretty much the same.
48G - 192mah/mm3
MJ1 - 193mah/mm3
OK. I see that these proposals were not taken quite like I meant them to be.
They were meant to serve 2 purposes:
- act as showcase of a certain construction
- be actual, direct proposals
I see that they are seen only as the latter. I’d like to explain the former now.
My main driver when drawing those lights was the goal of having lights that are high-quality, small, powerful, efficient, feature-rich. And cheap.
Do these lights deliver?
Yes and no.
Efficient? They won’t chase Zebras.
Cheap? Not. But not expensive either.
Feature rich? Smart-light makers beg to differ.
Powerful? A mere pop can light delivers way more.
Small? 10180 collectors will laugh.
High quality? BLF has a good track record so far.
Each of the qualities mentioned is relative. But I believe their combination is unprecedented.
Efficient? A bit more than the current BLF lights.
Cheap? There is nothing inherently expensive in those lights. Though features do add cost. Still, I believe the costliest part is R&D. Which is a part of the reason why I drew a family of lights - some costs are shared.
Feature-rich? Charging becomes common. Powerbank is a natural extension, but still rare. Firmware features? BLF shines here.
Powerful? There is literally nothing on the market to challenge them on performance-to-size.
Small? Few lights offer better battery-to-body-size. And all of them sacrifice both features and performance for that.
The key reason why they can pack so much is so little space is a combination of:
- LD4/TC style driver
- delivers lots of current
- delivers lots of regulated current
- takes little board space
- has no high components
- is fairly inexpensive
- is slightly more efficient than other linear/linear+FET drivers. Little less than induction based ones. High-vf LEDs help efficiency.
2. Driver integrated with LED MCPCB
3. Button and magnetic charging port in the front part of the head
That’s it. Every other decision I made when drawing those lights is not a key one.
Though some further decisions seem to come naturally from this:
- Unibody….better heat transfer. Why not?
- You need quite large MCPCB to fit all the components. This means that the head will have much larger diameter than 18650 battery. Therefore I believe going smaller than 21 mm diameter doesn’t really make sense. But going up, to 26650, to 32650, to 4*18650 is just as fine with me.
I simply picked the smallest that I believe was good.
But you said 21700 is not so good at the moment. Is it really?
The top of the line 18650 are actually like 3200 mAh at reasonable current (3A to be precise).
The top of the line 21700 are actually like 4600 mAh at reasonable current (3A to be precise).
The top of the line 26650 are actually like 5600 mAh at reasonable current (3A to be precise).
Yes, I do view them as good. Add to that high-current cells like 30T or 40T for those wanting more fun and it becomes very good. By the time the project is done, they should improve further (f.e. Sony is out of the game still).
21350? It is also a bit of why-not decision meant to increase the potential market to include people who want to go smaller. Anyway, it’s not a key choice.
Dedoming? Shaving domes by the thousand is not really expensive. Shaved LH351D shouldn’t cost more than stock XP-L HI. In fact I expect it to cost significantly less. And anyway, it’s not a key choice.
Magnetic connector? Does add some cost. It is a key choice unless we go further up in size.
Agro, your driver/mcpcb idea is what made me loose interest in your design. It just seems to not make any sense.
