Looks like StandardBattery got one (post #33): Review: Manker U12 (EDC, 20700, Rechargeable, XHP50 II) - #33 by StandardBattery
Hi someone asked me to comment on my U22, so here are some initial observations. First I’ve only played with this light a few times over a couple weeks, and I just took it outside for it’s first side-by side comparison.
I bought this light first and foremost because it ran on a 21700, second because it had USB-C charging, 3 because it was a bit of a thrower and I tend to not have many of those; I’m more of a nice clean flood beam person. Lastly I don’t need this light for anything in particular so I can’t judge how it does, or does not, meet any specific need.
First maybe the obvious; this style of light tends to be a bit front heavy, and this one feels similar, but it does balance just behind the switch so it’s a bit more comfortable to use than I expected. The light is quite small so you can easily pocket this thrower in a coat pocket.
As mentioned earlier in this thread I believe, the button is quite sensitive so you’ll want to secure the light during carry so the button cannot easily be activated, or unscrew the tailcap a bit to serve as a lockout. Having to lock it out can be a deal breaker for some use-cases.
The Manker UI is what it is, love it, hate it, I can get along with it if I need to, but long-press for off is not something I really like.
The construction of the light seems fine, I purchased mine without the Manker battery, and just use a bare Samsung INR21700-48G flat-top and it works fine. I have not tried the USB-C charging yet, but I will soon just for a test. I won’t use the internal charger on a regular basis unless I get a protected battery for the light, and that is not likely to happen. Overall a nice looking light.
For a quick test i decided to put it side-by-side with a Convoy L4 I have. I don’t remember buying that light, but someone on here must have convinced me to try it.
The light is roughly 1.5cm shorter than the L4, I didn’t measure it, but I like that it is more compact. The inner diameter of the bezel is almost equal to the outer diameter of the L4 bezel. Makes for a nicer looking light and a cleaner beam.
Just looking a the U22 High compared to the top level on the L4, the L4 has a slightly tigher beam and it throws farther. With the U22 on Turbo I found the throw to be essentially equal for visual purposes. This test was not too detailed, but I was surprised that there was not a larger difference between the U22 and the L4 XM-L2.
The color temperature of my Neutral-White U22 was cooler than the XM-L2 in the L4; the L4 tint was slightly nicer outdoors imho, but the U22 was still very acceptable to me. And the clean beam was overall nicer.
Thanks, I assume then you have the CW version?
How’s the spill beam, would you say it’s a good combination of throw and flood?
No my light is the Neutral White version.
Well I’m a flood type of guy, so I don’t know that I would say this light has a good combination of throw and flood, but there is some flood that hit the ground just a few feet away, far enough to still give a bit of that tunnel look, but it was pleasant enough. Quite clean, not a lot of rings that can typically be distracting in the near field. the business end of the light is a good design, better than the L4.
It’s by no means a pencil beam so I think most would say a good balance, but for me a light like the TK35 has a balance more to my liking with the reach powered by pure lumen output.
Sounds good , thanks!
Is there a chance of someone orchestrating a GB?
Manker does not do GB’s.
Is there a point in waiting for a deal or should I just buy it?
I would PM Freeme or Madmax just in case they have a coupon.
I think the best we could hope for is $55 with the cell included, I believe that was the presale price when this thread began, that package is now $69.95, however we can still get the light without battery for $55.95
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20180426201828&SearchText=u22+manker
I’d be great though if someone had a deal w/o the cell for $40-$45. Checked MadMax, nothing on this one yet.
Oh well, I missed how that was a pre-sale price. The price hike is bad.
I PMed M4D M4X and Freeme, the former said he’ll see what he can do. He has some codes for other Manker lights…
I got no further info from M4D M4X yet, but noticed that he has a general code for flashlights on HKE which drops the price by 8%. That’s still over my budget though…
If only there’s no long press to turn off…
Regarding the battery from a non fanatic. just an old collector.
18650’s do 99.9% of all battery requirements,
up to the real high output hand held torches.
Those. would be better served (I think) with the existing 26650’s.
Which I also prefer with a larger? stronger light.
Hand gripping wise.
They give Higher capacity. Longer life. With a more comfortable grip in my hands, which are average sized.
WHY go backwards for some novelty?
I can’t see there being much actual extra power\longevity in realtime from a 20700. over a top quality, high capacity\output 18650 cell 3600 to 4000ish, on paper, (with 5500mA in a 26650)
for the costing it would take for a changeover to.
IE Not enough extra anything.
ALL I do is take a spare battery in my pocket. (simple).
With a clear S2+ or little Jetbeam Pro as backup in other pocket.
On longer walks I have the choice of 3 x 26650 cell torches.
2 of them are optional battery 18650\26650.
This is not 20700 but 21700.
The top of the line 18650 are actually like 3200 mAh at reasonable current (3A to be precise).
The top of the line 21700 are actually like 4600 mAh at reasonable current (3A to be precise).
The top of the line 26650 are actually like 5600 mAh at reasonable current (3A to be precise).
21700 light weighs much less than 26650 making a nice middle option.
And, BTW, I tend to think that lights smaller than 18650 are more than 0.1% of the market.
As far as I know, this 20700 (later changed to 21700) was first made based on Tesla’s huge order. The engineers at Tesla found 20700 to be the optimum size with less total empty spaces between battery magazines. The idea is to make it easier to produce at cheaper manufacturing cost using existing cylindrical form factor from existing manufactures. Cylinder also much stronger than square design in regards to safety.
I read about this somewhere in the net about two years ago.
So, I think it’s driven by Tesla’s huge demand, not necessarily because 18650 getting obsolete. I predict we’ll see 18650 and 21700 to be the most popular battery size in the future.
- Clemence
20700 and 21700. These batteries are for electric vehicles, power tools and powerwalls. But since they make them we use them.
That’s some really nice spacing.
We talk about the 21700 quite a bit over here.
There is no magic to them, it’s just bigger and made by major battery companies. The 26650 size is not.
Just some notes:
The volume of the 21700 is right around 50% larger than the 18650, yet it doesn’t seem that much bigger.
The Samsung 30T is a beast of a cell. Only 3,000mah, but it’s internal resistance is about 10 to 12 milli ohms and can do 40A continous!
On the other extreme, the Samsung 48G is 4,800mAh and can do 10A continous (although for max life span they recommend 5A continous).
Cells like the 26650 Liitokala 5000mah blue and black can match the 48G in mah, but it can deliver 20A continous.
BTW, the 26650 volume is around double the 18650, but it’s not made by any of the big battery companies which is why we don’t see the same high level of “power density” such as a 7,000mah version.
It’s not going backwards, it’s going forward in a thinner cell.
Besides better capacity than an 18650, hand gripping wise it will be a more comfortable grip in my hands (vs 26650)
On some lights with a smaller head 26650 feels okay in the hand to me, (Thrunite TC20, EagleEye X7) but for lights with a larger head I usually prefer a thinner tube, I don’t hate 26650 on larger head lights with, but I think 21700 will be about perfect because 18650 is a bit thin for those.
So the “hand gripping” element is quite subjective and depends on personal preference, since there’s not many 21700 lights (yet) I’m happy Manker made this for 21700.
