Someone said it above. When you’re looking to spot something far away, nothing really matters except that you get light on the person/place/thing that you’re pointing at. Usually, the more light the better, which is why cool whites are used a lot for throwers.
And what I think everybody’s overlooking, because no one mentioned it yet, is that in a reflector light, any kind of tint-shift will of course skew the color balance. Bad enough in a fried-egg beam the hotspot is yellower and the spill is bluer, and who knows what hideous color the corona might end up being.
For a high-CRI LED to be used to its fullest, you need at the very least a TIR lens to blend/mix the colors better and more consistently, or use an aspheric lens or just plain use it as a mule to get a nice even dispersion of light.
That almost certainly means a flooder (narrow-angle TIRs being the exception… maybe), which would usually mean the light would likely be used for close-in work where color rendition matters.
Haven’t had much free time since I started the poll, but really appreciate the votes and responses so far. Lots of interesting perspectives and factors to consider, thanks all!
Also, Maratac and Reylight make some lights with Nichia emitters as standard, but afaik they’re both limited to AA/AAA (maybe 14500/10450?). I have a Xeno E03 with Nichia as well, but I think it was a limited run and mine crapped out.
Kinda underscores my point. The vast majority of mfrs primarily cater to lumen-hounds, and secondarily to those who’d insist on warmer CTs (or at the very least not Angry Blue™).
As for high-CRI… I doubt very many than the handful listed would even know what a “CRI” might be, let alone pay a premium to use a high-CRI chip.
The only Mankers I own (E02H and E03H) are un-modded with high CRI nichia emitters. Those might be the only high CRI lights they sell, I dunno. Hmm. Nope, E01, maybe MK34.
A good point Lightbringer, i have noticed with the same LED (not always literally )used in a reflector, optics and mule to produce different tint flavours. Now i admit i have not got it to a point of X LED in X type engine= X tint. But for example, the 219c 4000k is nicer to my eyes in a reflector than in a triple optic. By that, still towards yellow, but not as yellow……….quite yellow!
I mostly don’t. When I get review lights or buy something based on other features and it’s not at least 80 CRI, it gets modded. Those other features usually do have to do with the host or driver.
This XHP70 and this XHP35 HI are recent favorites for applications where Nichia doesn’t really have anything for us.
Makes sense. My ZL SC600w HI has an 80 CRI emiter and the color rendering is still very good.
My personal preference is still higher CRI if a good option is available.
If getting as much light on the target is the main goal, low CRI for increased output makes sense.
I have
Maratac AAA High CRI lights, some modded to warmer CCT, some stock w Nichia, some with 9080 nichia swaps.
Mecarmy PT16 and PT18, modded to High CRI 3000k and 4000k Nichias
Olight S1 Mini High CRI
Lumintop Worm, and Tools w stock High CRI Nichias
in Cool White that I only use for comic relief I have Fenix E01, Thorfire TK05 and Olight Copper S Mini (planned to mod to high CRI)
For me High CRI is required. Neutral tint or below the BBL tint is required. Depending on the white balance of my brain at different times of day and night I use 3000k, 4000k, 4500k, 5500k, All High CRI with good tint.
Sometimes I use Lee Minus green filters to improve tint and move it below the BBL
I dislike tint above BBL, I dislike NW low CRI lights with negative R9 values.
tint matters, CRI matters, CCT matters
using CW after dark disrupts melatonin, promotes cancer… see
I find blue light keeps me awake, warm light helps me relax and go to sleep
otoh, to prevent falling asleep at the wheel on long night drives, CW might be stimulating to keep alert till safe arrival, and
CW is good for working on cars during the day, when green tint wont be noticed, but I still want High CRI
the reason there are not more High CRI lights is because consumers are not aware of the details regarding spectrum, tint, and color temp, they just buy the brightest specs, out of ignorance
and,
majority of posters hype up their low CRI, high brightness lights, which makes others follow the Piper
Totally agree with this, it’s the most important thing to me. I don’t like Blue/Green or Orange/Yellow emitters either. Have a couple high CRI EDC lights I built and 80 CRI XHP35/50/70 high performance lights I built and I’m not that impressed with them. But that’s just me.
I have a handful of Nichia lights (triple 219c in S2+, BLF-348, Reylight Pineapple, other Convoy host with single Nichia 219B) and I just dont like them. I much prefer a warm/neutral light for actual use (my favorite is an XM-L2 U3-3D)
Tint and beam pattern are far more relevant to me than CRI. Not only that, but high CRI usually means more heat…and I use my lights for work too much to deal with a light too hot. I bought my D4 with the XPL-Hi emitters not because of the increase in output…but because it runs cooler (if you can even call it that)
I kind of don’t get some of the talk about temp, tint, beam, etc., as if they’re somehow mutually exclusive from high CRI?
Certainly those are all important factors, but it’s not like Nichias or other high CRI emitters only come in one take-it-or-leave-it awful temp/tint combo…
I’ll also add that I find some “standard” emitters quite nice if the other attributes are otherwise lined up with my preferences. But all else being equal, I’d still take the better color rendition as well if I could get it.
There are no “wrong” answers here though imo. Tastes, needs vary. I was a little confused why they aren’t the standard insisted on by enthusiasts, but the responses are helping to inform on why that isn’t necessarily the case.
I can deal with that opinion, but it’s a silly one, imo. CRI is a real, measurable property; not some kind of trickery. That’s like me saying Neutral White emitters are just a marketing gimmick. -???
