Try future electronics
Thanks for the test! Also, a nice mod!
I wish there was a version with only a single die in the center. That would be great for my old 2xAAA Minimag with a Terralux Drop-In. It has a really old, similar looking mid-power LED and a suitable smo reflector.
djozz, do you think a typical OP reflector is forgiving enough to produce a good beam off a single Optisolis LED without any further messing with a lens? The options that I have in mind are aleph LE with either the triple Optisolis board I just gor from Clemence for a med power mule only, or with a single Optisolis board good for both a low power mule and, say, a Haiku.
I do not think that a single led in an OP reflector will produce a good beam. And especially from a flashlight that is made for a good tint, you want the beam to be smooth as well.
I tried to EDC the Optisolis S2+ for a few days and my conclusion is that it is not good for that, and everyday light source needs to be a bit throwier than this. But (apart from truly appreciate art works and nature) it is great to check which of my socks match (all my socks are dark, from blue to brown to several tints of black).
Looking forward for the results. Maukka =)
Although they’re just engineering samples but should give us more than just a ballpark figure.
Jos, thanks for passing through those LED to Maukka.
- Clemence
We did a blend board with 3,4 and 5k Optisolis and managed to get 99.4 CRI, very nice leds, we used our 10mm Square MCPCB
Cheers
Mark
djozz, As always, very nice! Thank you for doing this….
Something like this is begging for an aspheric.
Pure flood…
Where can I buy some of the 5000k?
Try Cutter.com.au. Mine sold out already, only sm305 (3000K, 5 steps) Rfg00 left.
- Clemence
I have around 3000 pcs left in stock, email me for details
Cheers
Mark
Count me in!!!
Is the footprint for this emitter the same as some pre-exsisting led?
The footprint as far as I know is pretty standard for 3030 midpower leds. But those are never before used in flashlights so for us it is very uncommon. (in the picture are for example Osram Duris leds).
The footprint is the standard Nichia 757 or 3030 led footprint that is industry standard
Cheers
Hey Jos, you just mentioned this LED in another topic, stating 400 lumen for a quad, so i HAD to go look up this topic, which i hadn’t seen yet.
That’s all pretty amazing!
Low Vf for a purple / UV pump chip too !
Amazing overdrive capabilities !
Who would have thought these could do 100 lumen ?
They’re rated 0.2 Watts, aren’t they? lol
I’ll have a look in the Virence webshop, see what he’s got in stock.
By the way, may be interesting to look for “Laird” thermal pads, to electrically insulate the LED boards from the pill / shelf.
Not cheap, but probably one of the best pads.
Various thicknesses available, from 0.125 to 2 mm.
I bet Clemence knows what the best brand thermal pads are though…
Various thicknesses available, from 0.125 to 2 mm.I bet Clemence knows what the best brand thermal pads are though…
I have a little sample thermal pad (0,5mm version) of this: http://www.tglobalthermal.com/tg-x-ultra-soft-thermal-conductive-pad.php
I will include some if you’re interested. It’s very soft and easily torn. I bet you plan to insulate an XML copper board for those Optisolis, right? The easier way is to just use whatever thermal paste you have with several points of super thin support. It’s to keep the MCPCB from tilting and breaking the paste (and touched the base). In my case I use SiC powder or very thin sellotape (only at four outer points and the center).
- Clemence
As I remember, if you decide to use them, Virence boards are non-DTP (but with extreme thin dielectric layer, so performance is as a DTP board) so no electrical insulation of the boards are needed.
