Review: ThruNite Neutron 2C V3 with Ramping Firmware
94mm with the short tube.
My 2+ year old 1000lm nitecore HC30 is 98mm w/18650. When is someone going to make a decent NW/WW 18350 light w/reflector that is actually small?
Thanks guys for the measurements!
Eagtac DX3B Mini:
(Been out for over a year)
  • Length: 3.2 inches (82 mm)
  • Smooth aluminum reflector
LED Options:
  • CREE XHP50.2 K2 Cool White LED
  • CREE XHP50.2 J4 Neutral White LED
  • CREE XHP35 HD E4 Cool White LED
  • CREE XHP35 HI E2 Cool White LED
  • CREE XHP35 HD Neutral White LED
  • CREE XHP35 HI Neutral White LED
Also:
Eagtac DX3B Mini Pro
  • Length: 3.4 inches (86 mm)
  • Adds tail magnet / black clip / 18650 ext. tube
    (Same LED options)
My 18350 flashlight thread: List of 18350 flashlights (currently available)
Thanks for the suggestion (and I’ve been following your 18350 thread). But, alas, the eagletac has a lowest mode of around 20lm, complete deal breaker for me. Guess I should’ve included need for sub-lumen mode (or something close) in my post…
Even without your sub-lumen mode requirement being reveled in your post I would have still wanted to make it known there are decent smaller NW reflector18350 lights. The main attraction of the Eagtacs is having XHP emitters and outputs up to 2480lm (1830lm ANSI) from such a small light.
Since you’re following the thread I’m sure you’re aware of these Jetbeams, but I thought I’d mention they’re even shorter than the Eagtacs, with low modes of 1.1lm & 5lm, although there’s no NW/WW option. I’m not sure how difficult it would be to swap LED’s on a Jetbeam.
The EC-R16 in particular is incredibly small for a reflector light.
(Note they’re listed by Jetbeam as 16340, however it’s been confirmed they also can accept 18350)
Jetbeam E20R
  • 76.45mm length
  • SST40 N4 BC
  • Lowest mode 1.1lm
Jetbeam / Niteye EC-R16
  • 71mm length
  • Cree XP-L
  • Lowest mode 5lm
Does this have the exact same knurling as the TC20?
It is pretty darn close…………….
Wow nice close up pic. It looks the same to me, does it feel any different?
The TC20 knurling is about the best of any light I own, on par with DQG. It prompts me to consider other Thrunites.
Same with the UI.
They feel pretty much the same also , like the regular Thrunite knurling usually feels on both really.
Does this have LVP?
Charts with amperage missing?
There is NO tail switch on this new model and ALL functions are through the side switch , which is a nice looking metallic one. There is also a small indicator light in the very center of the switch button that is a constant on , blue in color , when the light is powered on. This same indicator light is also a Low voltage indicator and RED in color when the battery voltage starts getting low. The Low voltage warning will start blinking at first and when the cell is more near depleted , then the indicator light is a constant red , until the Low Voltage Protection will turn the light off when the cell gets to the low voltage level
Something going on with the server on Postimage……heres the charts…………
Okay thanks, so it has LVP (shut off)
I wasn’t sure because I don’t see that in the description on Thrunite’s website, It’s probably in the user manual which I think can be downloaded there. EDIT: no user manual downloads there.
Not sure why you mentioned in your reply about it not having a tail switch?
that was actually a quote from the above review.
OK I see, :+1: was wondering why you were telling me that! :person_facepalming:
I tried to find about the LVP in the review but read too fast and missed it :person_facepalming:
The Neutron 2C is one of the most recommended lights over at reddit/flashlight. Especially to FL newbs.
It’s at the top of my wish list right now.
I’ve never been to reddit/flashlight, maybe read one or two reviews from there before.
I wonder why it’s getting more attention there, and not much here (as robo pointed out)?
I don’t know. Maybe just a lot more FL newbs over there from elsewhere on reddit. Pretty huge platform with 40 million user accts.
