Test/review of Shockli 26650 4300mAh (Green) 2018
8 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 1 day ago
DSC_6889
Official specifications:
  • Type of Battery: Shockli 26650 4300mah IMR battery 40A
  • Size(mm): 26.2±0.2mm(Diameter) x 65.2±0.2 mm(Length)
  • Weight(g): 98±2g
  • Nominal Voltage: 3.7V
  • Nominal Capacity: 4300mah (0.2C Discharge)
  • Discharge Cut-off voltage: 3.0 V
  • Standard Charge: 0.3 A~3A (Recommend 0.5 A~1.5A) /4.2V±0.05V
  • Maximum charge current: 3A
  • Continuous Discharge Current: 30A
  • MAX Discharge Current: 40A
  • Initial Impedance:
  • Cycle Life: 300 times to 70% capacity
  • Charging Time: Standard charge: 4.5hours at charge current: 1.0A
  • Operating environment: Charging: 0°C ~ 45°C, Discharging: -10°C~60°C
Shockli%2026650%204300mAh%20(Green)%202018-info
This is a high current 26650 cell
DSC_6887
DSC_6890 DSC_6891
DSC_6892
DSC_6893
DSC_6894
Shockli%2026650%204300mAh%20(Green)%202018-Capacity
The two cells are nearly a perfect match and capacity is constant up to 20A discharge. At 30A the cell has trouble keeping up the voltage (It need to heat up first) and the capacity goes a bit down.
Shockli%2026650%204300mAh%20(Green)%202018-Temp-20.0
Shockli%2026650%204300mAh%20(Green)%202018-Temp-30.0
The batteries get very warm at 30A.
Shockli%2026650%204300mAh%20(Green)%202018-CapacityTimeHours
Shockli%2026650%204300mAh%20(Green)%202018-Energy
Shockli%2026650%204300mAh%20(Green)%202018-PowerLoadTime
Shockli%2026650%204300mAh%20(Green)%202018-TripCurrent
Shockli%2026650%204300mAh%20(Green)%202018-Charge
Conclusion
These batteries are good at high current, but are not the best in capacity. This make them good for high current application where the most capacity is not that important.
Notes and links
The battery was supplied by shockli.com for review.
Compare to 18650 and other batteries
SKV89
Last seen: 1 week 19 hours ago
Wow continuous 30A is really good. Is this the highest current 26650 on the market?
Nicolaas
For vaping? Probably, same cell as the famous Golisi.
For use in flashlights? Probably not, then thjis would probably be a better option: HKJ’s website: Shockli IMR26650 / 5500.
It uses the same raw cell as the Keeppower IMR 26650 / 6000
These cells are sold on Aliexpress under the “brand” name Dolidada. (No, I dod not make that up)
Cheers,
Nico
shadockan
shadockan's picture
The most powerful 26650, are the
Aspire 4300
Golisi 4300
(I think they have the same battery under the cover))
The manufacturer is YDL
Third battery with almost the same performance
Ijoy 4200.
I do not know … the mother …
But these three batteries can show their power with more than 20 Amps compared to the Shockli 5500 55A.
The manufacturer is PLB.
But I think there are other companies that use these batteries under their covers …
I know that at least … mainly based on Henrik’s measurements
volchyonok
volchyonok's picture
Last seen: 1 year 11 months ago
Hi guys. It is believed that the analogue of this model Shockli-4300 is Turmera-4300. What do you think? Does anyone have a normal high-current tests for this model Turmera, in order to compare its bit characteristics with data Shockli-4300?
HydrAxx
HydrAxx's picture
Last seen: 2 weeks 4 days ago
When I see the aspect of the positive pole, it seems to me that this is the same cell used by Ijoy, Aspire, Golisi and Vapcell, ie the YongdeLi 26650 4300mAh 40A (which makes 30A continuous in reality, because at 40A it overheats in continuous discharge), these are the best 26650 power cells on the market today, we do not find better in this format in terms of power cell.
http://www.ydlxny.com/index.php/work1/show/17.html
http://www.vapcelltech.com/index.php/Show/index/cid/37/id/35.html
Can a single flapping of a butterfly's wings trigger a tornado at the other end of the world?
volchyonok
Yes, of course, i hope so too, so this version 4300mAh in the guise of the littleknown “Turmera” interested me. However guarantees are needed that can give us only the same full-fledged and concept-friendly tests that the undisputed leader in this field, HKJ, performs. Unfortunately, i didn’t find any Turmera in his research trunk, so I need to find at least some other tests from another professional. Does anyone have such information with vivid graphs about these high-current Turmera-4300?
hasddie293
hasddie293's picture
Last seen: 9 months 2 weeks ago
So this one is the highest current 26650? I thought it was shocklii 5500mah…uhm
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
