I guess I don't get it. It's still constructed of aluminum.
I don't care, I like the concept. In fact, I've been hoping for something like this in the budget category. I suppose we could just go with more knurling instead Instead of more cowbell, it's MORE KNURLING! (I hope people get that reference, haha)
Ah Cristopher Walken fan.... eh? ;-) The inner part is out of alu and the outer part out of glorified plastic. So at first heat distribution is done by the alu, but at some point the heat contained has to go somewhere, normally that would be air and through movement and convection the heat transport is better than the medium air alone. The "plastic" walls in the heat and you have an additional material layer to cross with worse heat transportation coefficient. The ventilation grooves in the main body are supposed to help, but they are still inferior to a completely bare knurled aluminum surface on other lights.
The most used light for me is a 1Amp XPE R2 in a 502b host. I'm living a comeback on XPE and XRE Emitters. A 1.5 Amp driven XML is more than enough for me, multimode the better. There are times you look for power, one day you get it and realize that you don't need that that much. Believe or not, I'm building 2xAmc, 700mA single mode p60 modules for simpler action and better battery life. I'm sure these will be good hosts for those.
I do get the heat dissipation thing, but then it also doesn't have to be a pocket rocket. However, I was already wondering if the plastic layer would almost act as an insulator, which isn't good. And c'mon now, is it really "glorified plastic?" It's heavily used in the construction industry and is heralded for its strength to weight ratio. We could also say polycarbonate is glorified plastic but it helps keep rappers safe in their armored cars haha
I'm with you, man. The surface brightness of an XR-E makes it a knock-out thrower. It'll never win the lumens war but the WC/R2 will be around for a long time and is the brightest torch most non-flashaholics ever need.
I was talking about the thermal attributes when referring to GFRP as "glorified plastic". Of course it is a nice durable material and good for holding a light in winter without gloves, because it insulates well, but I don't want my flashlight head covered with that stuff. Jetbeam has shown us how it can be done and used similar materials in a superior way on the PA40. Aluminum head and carbon fiber body... that's a design that gets my vote. Covering the head in an insulator and the "cooling grooves" on the body that will be blocked by a hand? Come on Solarforce ... I know that you can do better.
i've almost bought that so many times - but each time I held off because I'd probably just pull that orange rubber thing off to put on a better light and the rest would end up in a drawer
