Anything that will replace NiMH soon?
Nonsense. The driver is essentially an impedance matching network, matching the characteristics of the cell, with those of the LED. It has to be looked at as a system.
A FET driver isn’t really a driver at-all, just an on-off switch, performing no useful matching function, leaving the cell+LED system mis-matched and mostly operating at it’s least efficient point.
Fortunately it mostly works quite well, but there are much better (more efficient) ways of doing it instead.
Watt-hours in, lumen-hours out, (Edit: integrated over the cell duration) is to my mind the best measure of efficiency, but not easy to characterise. That’s why HKJ’s cell measurements and djozz’s LED measurements are so useful for those curious to get a grasp of what’s really going on.
That depends on what efficiency you look at, I like the lumen/watt definition and mostly direct drive is fairly bad at that, because it either overdrives the led or looses a lot of power in series resistance (And it is way worse than 99.9%). Overdriving a led may get slightly more brightness, but the price is much more heat and much lower efficiency. Some may believe that it is a good trade off, I prefer much longer runtime and a bit lower brightness. Reducing brightness with pwm do not improve the efficiency!
I didn’t say anything about PWM. Read the post.
Nobody was talking about luminous efficacy, only driver efficiency.
If you’re going to mix both the LED and driver efficiency into one then you’re never going to have anything that makes sense, because LEDs aren’t even 50% efficient.
So it would make 0 sense for you to say 90% efficiency a few posts up.
Direct drive is literally just a wire with an on/off switch on it.
That’s why it has 99.9% efficiency.
There is near 0 resistance.
That do not exclude it.
Burning a lot of power in the led is not very efficient, you always have to look at the total solution, i.e. from battery to light. Using the led as a heater is usual a very bad idea, only exception is if you are trying to break the record for the brightest light around.
Anyway direct drive is a wire with some resistance, I have not seen any good explanation why it has to be 0.01ohm or 1ohm or 1000ohm or why/why not you can switch the led on/off at a fast pace, before it stops being direct drive.
FET drivers are certainly not efficient. If I compare my BLF A6 (which uses a FET at high levels) to my ZL SC600w (which uses a boost driver), I can get twice the runtime from my SC600 at about the same brightness as the A6. And the SC600 has the advantage of a regulated constant output, whereas the A6 decreases as the battery drains.
Boost drivers win by a huge margin.
You can argue semantics about where the inefficiency comes from, but as a whole system, FET sucks in every way except the simplicity of the design. Which is why it is so popular for high output budget lights.
See? This is the problem. You’re now trying to bring an LED into the equation.
Unless you know exactly the Vf and current-lumen curve of the LED, the temperature it is at, the colour of the LED, the colour temperature, etc it is impossible to determine the efficiency.
This is no longer about the driver anymore, now you have another 20 variables you need to know in order to compare.
Having an XHP70.2 running at 200mA will be far more efficient than the typical XPL at 3 amps.
Having a green LED will be more efficient than having a white LED.
Having 100 LEDs will be more efficient than having 1.
Now you’re bringing subjectivity into it, do you want extremely high efficiency or usable output?
This is why when you look at driver efficiency, you do not just assume that “oh direct drive is always worse because the LED will run at higher output and less efficiency”
Driver efficiency is ONLY power out / power in.
Driver efficiency (a real driver, not a FET or a bit of wire) is how well the driver matches the cell to the LED at the desired operating point, improving the efficiency of the system.
It can either burn the excess voltage off as heat in the driver (linear), or convert it efficiently as a buck or boost circuit can, with switching, copper and iron losses.
To my mind, a FET, or bit of wire, is zero percent efficient. It does nothing, except connect the cell to the LED. Whether it is fully on (Turbo), or PWMed to lower light levels, it contributes nothing to improve efficiency of the system, and generally runs the LED very sub-optimally, and simply dumps the surplus inefficiently as heat in the LED, and in the internal resistance of the cell. Better cells (lower internal resistance) simply move the heat more into the LED, which as HKJ said, is not a good thing, except for those only interested in headline short-term output numbers.
What you say is 100% true, but also 100% irrelevant. What does it matter if a short wire is 100% efficient? The whole purpose is to measure the efficiency of a total solution.
If you have a real-world example of an efficient light that uses a FET driver, let’s see it.
…bad news for Duracell and Energizer users. :expressionless:
Light output and efficiency is not subjective, but is easily measured and is a very important metric with lights. With a driver one of the important parameters is how well it drives the LED and the “well” covers brightness and efficiency.
Efficiency of direct drive can be anywhere from below 1% to near 100%, this depends on what you include in it and how you define it, but it do not say how much battery power get converter into light.
You’re right, and that’s sad. (Umm, that 14500s are dead-ended, not that you’re right.)
14500s are not AA drop-ins, ’cause a lot of things won’t take well to being hit with 4V when they’re expecting 1.5V. Certainly not with series-connected cells. Motors (shavers, etc.) will run obscenely fast, hotwire bulbs will have a short fraction of the lifetime, Si-based goodies can let out the Magic Smoke™, all sorts of bad things can happen if the doodad in question isn’t designed to tolerate Li cells.
Joe Idiot who buys 14500s and pops everything he puts them in, will badmouth 14500s like crazy. WallyWorld isn’t stoopit enough to sell 14500s because of all the Joe Idiots running around loose. At least 18650s won’t fit into anything that’s not designed for them. 14500s? The Silent Killer of AA-based electronics…
Now, maybe flat-top 14500s would sell, doodads can be designed to have built-in protection that only cells with a nipple on top would make contact. That might work. But button-top 14500s are a specialty item, and no mfr is going to put too much effort into them except for niche markets like flashlights and… ummm… whatever else might use 14500s without damage.
Being extra pedantic, make a distinction between direct-drive and FET-drive.
DD is just crowbarring the LED right across the cell.
Sucks for Li-ion, but works beautifully for LiFePO4 cells. :smiley: 3.2V from shortly out of the charger to right before giving it up completely.
Here are a couple of pointers:
Edit: and one more: Drivers, how leds are adapted for different battery voltages
Yeah, DD is literally turning the driver into just a wire that lets all power through.
Seems like the people above are having trouble understanding that.
Now they’re trying to bring LEDs into the equation and say “oh it’s not efficient because LEDs are less efficient at higher current” Well yeah but that obviously completely depends on what LED and power source you use and has nothing to do with the driver anymore.
The driver itself, just like a wire, has minor resistance losses and that’s it.
Anyway, the thread is derailed enough so I’ll stop trying to argue with those people :stuck_out_tongue:
Well, not really. They acknowledge that just crowbarring an LED across a cell can result in too-high current, pushing the LED into a low-luminous-efficiency point. There’s little dissipation in the “driver” (wire), but it’s Hell on the LED, and hardly efficient as a system.
Even PWMing it with a bang-bang FET ain’t a picnic, either, ’cause each current spike will still be Hell on the LED.
And trying to “direct-drive” a red LED, or worse, an IRLED, with a right-off-the-charger Li-ion cell will glow red all right, at least for a short time, but probably from incandescence. :smiley:
Whereas a UVLED with relatively high Vf would be perfectly workable.
So youse are both right, but arguing that the other’s wrong. :smiley:
Which can be pretty efficient (most efficient, even) if it’s matched to the load. If not, then the overall system efficiency would stink.
Ie, you can’t take a 100W 120V/220V bulb, crowbar it across a Li cell, and get it to even glow. It might be the most efficient driver to dump its current into the load, but without even glowing a dim red, it’ll stink as a lighting system.
Whereas an LFP cell matched to an LED which’d put out decent light at exactly 3.2V would be an excellent DD solution. In fact, that’s what newer “solar lights” use, vs NiCd/NiMH cells and boost-drivers.
Unless you’re running the LED at about 50 or 100mA, it’s just continuously downhill in terms of efficiency.
You add more current, you get less efficiency.
There is no “pushing the LED into a low-luminous-efficiency point”, unless of course you set a subjective, arbitrary “bar” where you decide you won’t let it go below.
Also the “sweet spot” (usually around 100mA) completely depends on what LED you’re using.
Who makes the cheapest 18650 / AA lights that use boost drivers instead of direct drive?
Zebras are nice but at 4x the price of other lights I feel like there has to be something in the middle.
Hmm to answer the OP. No, Not at this time.
Now please continue the argument.
By DEFINITION, driver efficiency is output power divided by input power.
When you go to mouser.com and look at LED drivers, that is what the “efficiency” specification is.
Efficiency is this line right here, which you can see in blue.
This is literally what the word “efficiency” means, there is no arguing the facts.
Just because “in your mind” a wire is 0% efficient does not mean that that’s how the rest of the world is calculating efficiency.
PS- if you want to take total “system efficiency” into account, aka both driver and LED, then what you said in this post here means absolutely nothing unless you state what LED you’re talking about, since every LED will have a different luminous efficacy depending on their current-lumen curve, colour, cooling and temperature, etc. etc.etc.
I assumed you were talking about driver efficiency, just like the guy who mentioned 90, because there is no way that an LED and driver combined will get 90 luminous efficacy, more like 5% to 20%
Please inform yourself before trying to twist your argument in order to avoid admitting you were wrong.
Luminous efficacy - Wikipedia
Any single AA torch (Edit, or 2 AA, even a Maglite LED, efficient but horrible choice of LED) will be using a boost driver. Lots of them out there, but nobody tests overall efficiency in reviews, the nearest you might get is comparing run-times, factoring in output lumens, with who knows which cell, then treating it all with a good pinch of salt.
I still like my Olight S15 which has a boost-buck driver that can run on one AA NimH (1.2V), or 2 AAs with an extension tube, sadly no longer made, or a 14500 (4.2V or more). But no point in using 14500, as I have previously explained. It lasts very well with an Eneloop.
Generally Olight make very good drivers, but they are not usually budget priced, except when on offer.
I also like my Nitecore MT22A, it’s a 2AA side-by-side design, using a boost driver, works very well. It is now my backpacking torch, together with a Mammut headlamp running off 1 AA. Not glamorous, but these work. And are powered by AA, rather important to me.
Edit: and they are very light, being made of good quality engineering plastics rather than dumb cylindrical bits of aluminium alloy, like almost everything churned off a CNC machine, where tooling costs are zero, and work can be shopped out to the lowest bidder, and copied.
18650 torches would usually need a buck driver (except for the ones with high voltage LEDs). The only two I have at the moment are a Thorfire C8S, which can run on one 18650, two CR123 or 18350s or 16340s. It seems pretty efficient too, far ahead of e.g. my BLF A6. And a Nitecore EC4S (Cree XHP50), which runs off two or four cells of similar variety, likewise far more efficient than the A6.
Edit: the Nitecore EC4s is also an example of an un-copyable lightweight design, being moulded from magnesium alloy. The tooling for these ultra-light torches must cost a fortune, surprising they are so affordable.
Many P60 drop-ins use buck drivers to cope with many combinations of cells, Kaidomain is probably the best place to look for these, and their hosts. Probably sneered at by BLF as being old fashioned, but they still work well, and make for a very flexible modular system.
