Check your Candela, from 20m to 25m it jumps back up…Lux to candela (cd) conversion calculator
Google Drive file.
All distances give a similar throw, under 1Mcd.
And I think that given how often he does lux measurements that ZozzV6 has an idea how well his numbers compare to other numbers around, so a faulty luxmeter or one with calibration way off can also be ruled out.
I noticed the hotspot of my GT is smaller than the hotspot of my Palight Boss. Strange, the GT has a dedomed XHP 35 and the Boss has a dedomed X-PL. I bet it is out of focus, but it is impossible to unscrew the head of the LED section. I will post an update IF I ever manage to unscrew it and change the focus height
I know most of this thread is geared more towards drivers and LEDs, but for a filthy casual type like myself… I’m going to ask the obvious - has anyone made an adapter to put a BLF Q8 on the ass end of the GT? The diameter and thread pitch are obviously different, and there’s no real need for it other than having a long range focused light on one end and a monster floodlight on the other. Forgive me if this is totally ridiculous, my GT showed up yesterday and when taking pictures next to my Q8 for comparison the idea punched me in the back of the head. Or maybe it’s the pain meds from a recent surgery to reattach a muscle, not sure.
That’s what happens when you put a larger reflector in a flashlight.
I tried adding spacers under the centering disc. All it did was a donut hole in the beam, without making it bigger or more focused.
It still seems to me the GT hotspot is not as focused as it could be. There is simply too much light wasted around the hotspot. Or at least I think so. Can it be changed or not?
Has anyone tried a thinner centering piece?
It still seems to me the GT hotspot is not as focused as it should be. There is simply too much light wasted around the hotspot. Or at least I think so. Can it be changed or not?
The hotspot of my GT looks pretty focussed but when over 10 meter it is slightly darker in the middle. I’m not sure if that is the nature of the XHp35 Hi led or that the focus is less than perfect, in which case the centerpiece should be a bit thinner. I dare not sanding it down yet in case it makes things worse instead of better.
Btw, on the list of parts that would be welcomed to be sold separately should be the centerpiece IMO.
And apart from being slightly darker in the centre there is a lot of light around the hotspot that could be used in the middle. If it is even possible.
To be precise, I made 3 shims with a total height of 0,5mm and tried adding them under the black centering disc one by one, but the donut hole was bigger with every added shim.
Someone should make thinner centerpieces, I don’t have guts to sand down mine.
Here is a great thread on how to easily check your light for focus:
https://budgetlightforum.com/t/-/46601
I remember DB Custom thinned his center piece a bit by sanding. He posted about it, with pictures; back somewhere in all the massive & many GT threads & posts. If I can find it, I’ll post a link.
IIRC, he said in his case it helped tweak the focus a bit tighter.
DB Custom can work miracles in comparison with me, I already got the idea of sanding the centerpiece down, but it is beyond my skills to do it properly. My centerpiece would be thinner on one end and thicker on the other, apart from many other blemishes I would cause, and that would not help the focusing at all.
Hi. Is your palight boss have a ring around the hotspot?
All you have to do is put a piece of very fine grit sandpaper on a flat surface, place the black centering block on it, & rub until you remove a bit from the bottom of the block.
It should be/is very easy to do that in an even fashion. As far as causing any other blemishes, I cannot understand how that would be possible using this method.
I did it with one of mine & it was simple as well as straight forward. Seemed to tighten the hotspot a bit also.
@ johny723
Here are some links where people sanded their Centering Ring. JasonWW states he tightened his hotspot considerably.
Do some reading on either side of these linked posts & there is a bunch more info.
I cannot find the photo’s I mentioned by DB Custom, but I did find several by KawiBoy1428.
My theory is that Lumintop calculated the exact thickness of the black spacer just right, but with a warped bottom, it’s a tiny bit too tall. I sanded down the bottom of mine until it was flat. I carefully cleaned it with a brush and a metal tool to get rid of any black pieces of plastic on the edges and in the holes. Now I’ve got a 6” hot spot compared to an 8” (at 9 feet). That’s sounds better to me. Tonight I’m gonna take identical distance photos that I did in the past and compare the hot…
Here is a comparison of my light from the same distance before and after I sanded down the black spacer. Ignore any differences in color or brightness. At 9 feet, the hot spot went from 8 inches to 6 inches in diameter. At much longer distances, it looks like the hotspot size stayed the same. [image] I had to measure based on the sheets of tin on the building. Both hot spots look like they are 3 sheets wide. The coronas look the same as well. Maybe the new one has a slightly better defined hot…
Both of my GT’s centering ring bars were trapped by the hold down screws to the point that they had to be pried off. I opened them up till they floated on the hold down screws. As you can see in this picture, the hold down screws are narrower as compared to the centering ring bar clearance holes. This could cause the centering ring detail, not to sit flat due to the interference, how is it supposed to sit Flat when it’s trapped between the screws, this thing should float to allow the reflector t…
The black centering piece is machined from Delrin, oddly enough it isn’t perfectly symmetrical… if it’s touching the emitter it needs to be flipped around. All 4 that I have seen this has been true on.
The light is well made Teacher, reassembly with the Bezel still snugged down is painless. However… I find it more optimum to NOT have the bezel so tight. I also removed some material on the underside of the Delrin centering block, it was cupped underneath and held the reflector a bit too high for my liking (agree with Kawiboy on this). Putting the bezel back on it seems to do well for the definition of the hot spot to not snug it too tightly. [my Delrin block was 2.8mm thick, apart from the cen…
Thanks, I will read through the links.
Your welcome, my pleasure. :+1:
To make clear what I mean I took a photo of both the GT and my Boss. The first photo is the GT. It clearly is brighter, but there is a lot of light around the hotspot. IF it was possible to concentrate that light, it would improve the beam.
Google Drive file.
This is a beamshot of my Palight Boss with a dedomed XP-L V6 1A. There is very little light around the center. If only I could make my GT throw the same.
Google Drive file.
@ johny723 ……. OK…… I think I now understand what you are saying. I do not think this is possible with the GT reflector / LED setup. It was designed to spill this amount of light so as to be a more “”useful”” light.
This is what I remember anyway.
Thanks… i bet dedome xpl will give some green tint…
