Thanks. Added to the list. PM replied.
There are still a couple of TO46R and some TO10R left for latecomers (or in case anyone in the GB wants to reserve some extras) => PM me to secure your spot.
hi the are the lights shipping around May 21st or is that when the batch will be secured for testing?
We are doing our best to get a sample tested already before May 21st. Hoping the best.
Interested in group buy, PM sent
PM replied.
I’m assuming no LVP in the T046R, hence the included protected Wuben cell??
Anyone want to suggest an alternate cell that they know will fit? Is the Wuben cell a known and trusted rewrap?
I’ve tried out the Wuben LT35 and Wuben L50 flashlights which include a Wuben ABE2600 protected 2600mAh 18650 in the flashlight package.
My guess is the TO46R will also come with the same Wuben ABE2600 18650 (I’m not sure about the TO10R, what kind of battery will be included though).
From my previous tests of the Wuben ABE2600 (using MC3000, discharge @ 0.50A to 2.50v cut-off, I got 2600+ to 2700+ mAh capacity, so it seems to be pretty accurate). The protection circuit of the Wuben ABE2600 trips at around 6A (similar to the Liitokala protected NCR18650B that I also have).
(Now it’s unlike the Sofirn 18650 — I’ve also bought Sofirn flashlights with packaged 18650 from the AE store, there are 2 types of Sofirn 18650s bundled with their flashlights, I can’t seem to determine when they’ll send one or the other — I’ve gotten Sofirn 18650 that’s labeled “2800mAh” and is a protected 18650, and I’ve also gotten Sofirn 18650 that’s labeled “3000mAh” and is an unprotected 18650. (The Sofirn protected “2800mAh” 18650 also trips at around 6A current)
Doing capacity tests of those Sofirn “2800mAh” protected and “3000mAh” unprotected 18650 batteries, using the same procedure above, MC3000 discharge @ 0.50A to 2.50v cut-off; I’m only getting 2600+ to 2700+ mAh capacity — practically similar capacity as the Wuben “2600mAh” 18650s, which are at least labeled properly and correctly).
There’s LVP at 2.4V.
Hoping these start shipping tomorrow
I’m pretty sure we’re still waiting to get a sample tested?
Last update:
Yes, I would definitely like the lights to be tested prior to being sent. I am concerned about the lack of updates regarding the testing especially since the expected May 21st ship date has arrived.
Right!
I guess it’s time for a short status update…
Samples:
First lights are coming out of the factory and the samples will be shipped to me tomorrow morning. They should arrive here at the beginning of next week. Hope maukka is available to test them very soon after that.
I asked Wuben not to ship any lights before maukka verifies the samples => Current estimate for the shipping date is late next week.
Payments:
Wuben told me they have received roughly half of the payments. If you haven’t paid the lights you reserved, please do so before next Monday!
Remaining lights:
There are still some lights left: Anyone can still join the GB and existing participants can reserve more lights. “1st come, 1st served.” => PM me to make the reservation.
Thanks for the update =the= and we’ll be looking for those tests
I hope the rest of the process is going well :innocent:
Samples:
No travel plans next week.
Just curious (this may have been brought up before) Since the TO10R tube will fit the TO46R head can Wuben sell some TO10R tubes as an add on accessory?
In order to make a good long/shorty “convertible” light we’d have to buy both lights and then have a pretty much worthless TO10R head. Buying both would be cost prohibitive anyways.
Since they were nice enough to sell the MCPCB w/LEDs as accessory, have they been asked about the shorty tubes?
I understand they made the TO10R driver different to suit 16340, but we can bore the shorty tube for 18350 and use Aspire/Vapecell, probably too much to ask but even better if Wuben would bore them and do a special run of the bored tubes as an add on accessory, otherwise at least offer the stock TO10R tubes separate and we can bore them ourselves.
is this still going? would be interested in a T046R
Yes…
Quote yesterday by the organizer (Post #340, 4 posts above yours)…
Remaining lights:
Unfortunately, this is not possible. I tried, but Wuben won’t agree on selling “incompatible/unsafe” tubes.
46r charge and discharge current are a bit too much for a non-IMR 16340, causing a risk -> they also glue the head of 46r to prevent body swap.
If we buy both lights, crack open the glued head and bore the tube for 18350, Wuben won’t be held accountable if anything bad happens…
OK thanks for the answer.
So, when can we expect to see our wooobins
