The most used light for me is a 1Amp XPE R2 in a 502b host. I'm living a comeback on XPE and XRE Emitters. A 1.5 Amp driven XML is more than enough for me, multimode the better. There are times you look for power, one day you get it and realize that you don't need that that much. Believe or not, I'm building 2xAmc, 700mA single mode p60 modules for simpler action and better battery life. I'm sure these will be good hosts for those.
I do get the heat dissipation thing, but then it also doesn't have to be a pocket rocket. However, I was already wondering if the plastic layer would almost act as an insulator, which isn't good. And c'mon now, is it really "glorified plastic?" It's heavily used in the construction industry and is heralded for its strength to weight ratio. We could also say polycarbonate is glorified plastic but it helps keep rappers safe in their armored cars haha
I'm with you, man. The surface brightness of an XR-E makes it a knock-out thrower. It'll never win the lumens war but the WC/R2 will be around for a long time and is the brightest torch most non-flashaholics ever need.
I was talking about the thermal attributes when referring to GFRP as "glorified plastic". Of course it is a nice durable material and good for holding a light in winter without gloves, because it insulates well, but I don't want my flashlight head covered with that stuff. Jetbeam has shown us how it can be done and used similar materials in a superior way on the PA40. Aluminum head and carbon fiber body... that's a design that gets my vote. Covering the head in an insulator and the "cooling grooves" on the body that will be blocked by a hand? Come on Solarforce ... I know that you can do better.
i've almost bought that so many times - but each time I held off because I'd probably just pull that orange rubber thing off to put on a better light and the rest would end up in a drawer
Well put. I'm not familiar enough with the Surefire G2. Is this design essentially copying that or did Surefire do something better that Solarforce isn't catching on to? Or was the G2 Nitrolon a flop?
It's a perfectly suitable host for an incandescent dropin, which are still widely used in Surefire-land and often bundled with a G2. On incan dropins the fast heat build up is actually wanted, as the inert gases like Xenon can only do their job at protecting the filament at high temperatures. The whole P60 lineup were originally designed for incans. I think it is time for Solarforce and others to leave the path that Surefire has taken and to give the end-consumer a new screw-in based light engine carrier especially designed for high power LEDs. I think most of the private end-consumers are more interested in a new form factor, that would allow legobility and highly efficient heat dissipation at the same time. Solarforce would be a prime candidate for introducing such a new style of lights at a competitive price. They certainly have the knowledge and machining capabilities. Surefires main target are the military and police forces that may have a different demand.
Thanks for the very informative and in-depth explanation! I never really thought about the origin of the P60 being incan, which is very true and makes a lot of sense considering the design. Now I'm really curious how this new marriage of metal and plastic will pan out. Maybe I'll just stick with the all metal designs since I always want the option of high output.
I agree, we need a P60-type form factor for the powerful LED's of today. I still want Solarforce to make the C8 size head a popular lego addition to the P60 family. All we're doing is making a bigger reflector since we're using the same battery and thus same battery tube size.
