Please put me on the list for possibly 3. Thanks!
in for two
I didn’t see it mentioned, but how about a steel or delrin base plate to protect the bottom from rocks and rough surfaces. Using this outside did you see any wear on the base? Might be able to 3d print a piece the base sits into. Even a wider base with more lateral stability. Like the pancake bases on some lanterns.
Another idea I had was a place at the center of that base with a tripod mount. For a mini three legged flexible tripod, to use on uneven surfaces. The base would need to be a good deal thicker to thread into, as there’s not much material on the q8. Machined delrin would probably be much cheaper than stainless.
I know these would add cost, but as optional additions, I’d be willing to pay for them, for the added benefits.
Interesting idea to add a removable base. The V1 prototype has some scratches & nicks on the bottom form ground & rocks.
I was thinking one decent drop and the q8 tailcap might not screw on all that well. Even just a protective cup (like plastidip) might be worthwhile.
Screwing it to something like this might be really beneficial too:
It’s just that you’d need a few threads to bite into it, from the bottom.
Also, not sure what this little tripod would do with the weight of 4 18650s and the light on it.
That link don’t work for some reason.
It worked earlier strangely.
They must be in maintenance, like earlier BLF was.
Just checked their site and it’s down for the count.
link and pic are dead
sorry
One of the plans is to add a 1/4”–20 threaded tripod mount hole in the bottom of the lantern for those reasons, and to give it the option of mounting it on a tripod to illuminate a larger area when needed.
I want one, thanks
That’s awesome. Thanks. I tried searching this mega thread to see if I was being redundant. Sorry about that.
Can you add me for another lantern? Thank you.
Put me down for 3 more please.
added
Will the lantern require button top cells? I just recently realized the BLF Q8 does, and since this lantern is using may identical parts, I am suspecting it will also?
Thank you!! This just keeps getting more impressive…… :+1:
DBSAR… I don’t know how important it is, but my total should be ‘5’.
Thank you……
502 g_sintornillos
503 teacher
504 teacher
505 Kodachrome40
746 Torre246 (2)
747 teacher
748 teacher
749 teacher (total 4)
750
Most likely as the four cells are in parallel and button tops are required to contact the positive driver ring when threading the battery tube on the head.
Thank you……
502 g_sintornillos
503 teacher
504 teacher
505 Kodachrome40746 Torre246 (2)
747 teacher
748 teacher
750
sorry i fixed that its easier i put the total number after the last list request then it is to move every one else down. Either way Thorfire has expressed lots of interest in this project as it approaches 1000 lanterns interested.
Thank you DBSAR!!! I am looking forward to this……
