*BLF LT1 Lantern Project) (updated Nov,17,2020)
11436 posts / 0 new
nkresho
nkresho's picture
Last seen: 3 weeks 1 day ago
please add me to the list for one
Thanks for your work on this. It’s going to be amazing and blow the competition from the big-name brands out of the water.
candor
Last seen: 10 months 3 weeks ago
I’m getting excited about this project! Please put me down for two more. Thanks!
deathless
Last seen: 1 week 7 hours ago
Put me in for one. Thanks!
byarnell05
Last seen: 1 day 7 hours ago
Please put me on the list for possibly 3. Thanks!
wheremydonky
wheremydonky's picture
Last seen: 3 weeks 4 days ago
in for two
nkresho
nkresho's picture
I didn’t see it mentioned, but how about a steel or delrin base plate to protect the bottom from rocks and rough surfaces. Using this outside did you see any wear on the base? Might be able to 3d print a piece the base sits into. Even a wider base with more lateral stability. Like the pancake bases on some lanterns.
Another idea I had was a place at the center of that base with a tripod mount. For a mini three legged flexible tripod, to use on uneven surfaces. The base would need to be a good deal thicker to thread into, as there’s not much material on the q8. Machined delrin would probably be much cheaper than stainless.
I know these would add cost, but as optional additions, I’d be willing to pay for them, for the added benefits.
DBSAR
DBSAR's picture
Last seen: 3 weeks 5 days ago
Interesting idea to add a removable base. The V1 prototype has some scratches & nicks on the bottom form ground & rocks.
nkresho
nkresho's picture
I was thinking one decent drop and the q8 tailcap might not screw on all that well. Even just a protective cup (like plastidip) might be worthwhile.
Screwing it to something like this might be really beneficial too:
https://www.monoprice.com/product?p_id=10272&gclid=Cj0KCQjwodrXBRCzARIsA...
It’s just that you’d need a few threads to bite into it, from the bottom.
Also, not sure what this little tripod would do with the weight of 4 18650s and the light on it.
DBSAR
DBSAR's picture
That link don’t work for some reason.
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 19 hours ago
It worked earlier strangely.
They must be in maintenance, like earlier BLF was.
nkresho
nkresho's picture
Just checked their site and it’s down for the count.
link and pic are dead
sorry
DBSAR
DBSAR's picture
sorry
One of the plans is to add a 1/4”-20 threaded tripod mount hole in the bottom of the lantern for those reasons, and to give it the option of mounting it on a tripod to illuminate a larger area when needed.
SebaZ74
SebaZ74's picture
Last seen: 1 month 14 hours ago
I want one, thanks Smile
nkresho
nkresho's picture
That’s awesome. Thanks. I tried searching this mega thread to see if I was being redundant. Sorry about that.
Torre246
Last seen: 1 year 6 months ago
Can you add me for another lantern? Thank you.
teacher
teacher's picture
Put me down for 3 more please.
DBSAR
DBSAR's picture
added Smile
sbslider
sbslider's picture
Last seen: 1 week 4 days ago
Will the lantern require button top cells? I just recently realized the BLF Q8 does, and since this lantern is using may identical parts, I am suspecting it will also?
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
teacher
teacher's picture
DBSAR wrote:
added Smile
Thank you!! This just keeps getting more impressive….. Thumbs Up
teacher
teacher's picture
DBSAR… I don’t know how important it is, but my total should be ‘5’.
Thank you….. Smile
502 g_sintornillos
503 teacher
504 teacher
505 Kodachrome40
746 Torre246 (2)
747 teacher
748 teacher
749 teacher (total 4)
750
DBSAR
DBSAR's picture
Most likely as the four cells are in parallel and button tops are required to contact the positive driver ring when threading the battery tube on the head.
DBSAR
DBSAR's picture
teacher wrote:
DBSAR… I don’t know how important it is, but my total should be ‘5’. Thank you….. Smile . . 502 g_sintornillos 503 teacher 504 teacher 505 Kodachrome40 ~~~~~~~~ 746 Torre246 (2) 747 teacher 748 teacher 749 teacher (total 4) 750
sorry i fixed that Smile its easier i put the total number after the last list request then it is to move every one else down. Either way Thorfire has expressed lots of interest in this project as it approaches 1000 lanterns interested.
teacher
teacher's picture
Thank you DBSAR!!! I am looking forward to this….. Smile
shirnask
shirnask's picture
Last seen: 1 hour 20 min ago
Please add me for one more (total of 4)
Thanks
DBSAR
DBSAR's picture
I am adding the base tripod threaded mod tomorrow to the prototype, and will do some beam-pattern ( beam shot) comparisons between the new V2 versus the V1 and some other modified lanterns i have. So far the V2 is very impressive with the new head design, with a smoother, wider field of illumination than any other lantern i tested or have, with the least lantern glare effect of them all. I can;t wait to field-test this (with photos) on our first 3-day camping trip in 2 weeks. I hope to get the USB TP4056 based charging circuit added to if i can in time, to test its off-grid sustainability using a 10-Watt Eceen folding solar charger.
teacher
teacher's picture
Wow!!! Like I mentioned above… it just keeps getting better & better. Thumbs Up
Thanks for the info….. Smile
Dioda
Last seen: 1 hour 52 min ago
Interested, it would be great if this lantern-head could be bought separately as an add-on to my Q8.
Roobarb
Last seen: 5 months 1 day ago
Put me down for one if possible please
Seeker1
Last seen: 1 month 1 week ago
Please add me for a 2nd. 2 total. I am #518 on the list already.
Thanks
Rylee900
Last seen: 6 days 18 hours ago
Please put me down for 2. Great idea and lots of great R&D….
Brighter every day!
