Dale, the single cell light I’m modding isn’t a C8, but it is an old favorite, an original UltraFire HD2010, which already has pretty amazing throw for having an outdated emitter (XML T6) with east-092 driver (DD but crappy mode arrangement)
I have one of these copper pills:
Takes up to a 26mm MCPCB, and a 22mm linear/FET driver.
I plan to use a Maxtoch XP 26mm Copper MCPCB to keep the wires away from shorting on the reflector.
And yes throw isn’t everything in my plans for it, I want good throw, but with some useful spill / larger hot spot / extra output.
It’s one of my favorite lights and one of my first purchases when I got into this, and I’d like to make it into something special and useful, so I thought it would be a good candidate for an XHP35 HI, don’t want to derail too much here but I’d love to hear any other suggestions.
I’m also considering an XP-L2 HD (dome on) I have a few (stock) lights equipped with it and the tint looks fine to me.
I’d use an FET driver from Richard paired with an SST-40, I think. That is a good combination for this C8+ or the HD2010 either one, where the parameters are as you outlined. I think I’d use thermal paste to begin with, try it out, and if the spot was too large I’d pull the pill and remove the emitter then slice/dice/shave the SST-40. Would probably re-flow the emitter/mcpcb into the pill then, might would reinstall it with thermal paste and double check first but I’d probably go straight to the re-flow. (test it first, make sure it isn’t ringy and that it’s to your satisfaction, then go from there.)
I’d use an FET driver from Richard paired with an SST-40…………….
Thanks, then I’ll use a MTN-22DDm.
Versus using only thermal paste, what does reflowing the mcpcb to the pill result in? Better heat dissipation?
I had thought about the SST40 but wasn’t sure I’d be okay with the tint since I’m pretty firm on neutral tints only, and everyone seems to comment on how cold/bluish it is, interestingly just today I received my first SST40 light! (Jetbeam E20R). I wasn’t able to get outside with it tonight but inside it’s not too horrible, I don’t see any bluish tint at all, even on white walls, it looks very yellowish to me, with a hint of green.
I also plan to get the C8+ tan host version and run a MTN-17DDm so maybe the SST40 for it as well. I see Richard offers the Slice LED option, how’s the tint on it after slicing?
The SST-40 doesn’t exhibit the tint shift we’re used to seeing from Cree, it does drop some but not like the XM-L2’s. I’ve found the 40 to have a nice creamy color once the dome is taken off. Richard seals them though, so it’s a bit different than a naked die.
But what about a nude gnu?
- The YKK Philosophy
Gnude Gnu’s haven’t been legalized for power use to date, not in the US anyway. Testing is underway to put them to work under AR confinement but the results are not in… Gnarly Gnude Gnu’s will be next. Mark my words.
I only asked because you mentioned creamy colors and naked dies.
Still though, it’s true, the XM-L2 U4 with a clean de-dome on it throws further and burns less current than a pushed XP-L HI, MaxToch found that out in the Shooter 2X.
The Convoy store also claims “about 1100 lumens”, so it might be true. The output current is listed at 3000mA, which is higher than the previous Convoys that use 8×7135. So, it looks like they’re using a better driver.
If I had to guess, I’d say probably closer to 1000 lumens, but I wouldn’t rule out 1100.
Pretty sure the driver is made up consisting of 8×380mA 7135 chips, making it effectively a QLite (3.04A) So actual output depends greatly on the emitter choice you make when you order the light. A 1A tint will be higher than a 4C, for example. Just how it is. Relatively simple to stack a few chips for more power.
Where are you referring to that it says this? I haven’t seen that info anywhere. As far as I know this is still the 2.8A driver and would not be putting out 1100 lumens. Am I missing something? I can see BG listing 1100 lumens but I don’t see anything like this in the Convoy store.
I got a tad over 700 lumens out of the box… maybe closer to 800 (log is at home). With a freshly charged 30Q. I replaced the driver with a blf a6 one and swapped emitter with a sliced SST40. Now it’s making just over 1600. Perfect light now.
Nice! What’s the throw like? The Astrolux C8 uses a BLF A6 driver and an XP-L HI emitter, getting around 100k candella with a fully-charged 30Q cell, at about 1300 lumens. Does the SST40 with 1600 lumens throw further?
In my own experience though, the de-domed SST-40 throws somewhat less than a clean de-domed XM-L2, albeit making much more lumens in the process. (The SST-40 makes more)
Does anybody know if the old bezel ring will fit to the new C8+?
https://www.banggood.com/de/Convoy-C8-Stainless-Steel-Tactical-Attack-He...
I saw a picture of a C8+ with stainless bezel so yes.
Reviews: Olight Seeker2 pro, Lumintop GlowI, Sofirn SP36, Convoy 4X18A, Convoy M21C, Brinyte SR8 Rescue Angel, Astrolux MF01 mini, Astrolux FT03S, YLP Sherp S15, Sofirn SP40, YLP Panda 3R and Unicorn, Armytek Prime C1 Pro, Acebeam M50, Imalent MS18, Convoy M3, Nitecore TIP2, Imalent RT70, Wuben T70, Sofirn SP32A, Thorfire VG15S, Thorfire VG10S, Thorfire TG06S
Mods: Imalent MS18 dedoming, Astrolux MF01-20K, Small sun T08 MT-G2, Eagle eye X6 triple XPL, Ultrafire F13 MT-G2, Convoy C8 XHP70, Solarstorm T3 triple XP-L HI
Big flashlight measurement and beamshot collection
3D printing stuff for flashlights
My flashlight related Instagram
My Flashlight related Youtube channel called Zozzlights
Naked makes news, always!
Found it. It was in a facebook flashlight group.
Thanks Zozz, a small gap but it looks pretty good!
Put a thicker lens in it, increase the gap, and you’ve just effectively added a cooling fin.
With these updates to the Convoy line, I wonder if there’s going to be any changes or new colors to the M series of Convoy lights…
Find all my reviews of flashlights and more gear at www.bmengineer.com
No idea if this video was posted already, but here it is. And my goodness it’s good looking…
banggood claims 1100 lumens for this, i guess its their usual marketing and its not really true?
https://www.banggood.com/Convoy-C8-Sand-color-XPL-HI-1100LM-Memory-Function-Professional-12-Group-55Mode-Tactical-Flashlight-p-1294747.html?rmmds=search&cur_warehouse=CN
...where Frugal meets with Flashlight!
つ ◕_◕ ༽つ
I look again and again. I think I like the old version better.
They should make more different than only it’s looks.
Take care of your flashlight and your flashlight will take care of you.
The clear coated Convoy C8 with 3A XP-L HI does 839 lumens @ 30 sec on high.
That’s L2 , are we talking about C8 ?
Thought I was losing it for a minute there. Yeah that is the L2 and this thread is about the C8+
Doh! Sorry. Okay, I take it back. I have no idea why BG is claiming 1100 lumens.
I’ll check it tonight and post here.
The SST-40 would have to be de-domed to throw similarly or better than an XP-L HI, not an apples to apples throw comparison if the SST-40 is domed.
