Lexels driver compilation
327 posts / 0 new
Lexel
Lexel's picture
Last seen: 1 year 3 weeks ago
JasonWW wrote:
Newlumen wrote:
Can you guys tell me estimate lumen and lux for the blf gt? Xhp70.2 and oslon black .. jason, we need you!
I’m just now seeing this thread. Sorry.
Texas_Ace already built a GT with the 70.2.
Texas_Ace wrote:
With the sliced dome 80CRI xhp70.2 at 6A (forgot to take a measurement at 5A) I got around 1500m of throw or 560kcd.
I seem to recall he upped the amperage to around 8A (12v). He was getting over 7000 lumens and I think 1600 meters.
I am not familiar with the black flat. Too small and weak for my needs.
OBF should get close to 2Mcd
If using normal CRI70 70.2 I estimate 650kcd with 12V 6A Buck driver possible to go to 7A, over 7A the sustained lumens do not increase much
I should get this week new boards for a far more efficient MOSFET than the old
at those currents it is critical to bridge the carrier springs
KawiBoy1428
KawiBoy1428's picture
Last seen: 15 hours 45 min ago
And the carrier contact springs too Wink
KB1428 “Live Life WOT
Lexel
Lexel's picture
The battery springs are from Copper alloy
but idnk why the carrier button spring is not, definately likes a magnet and has pretty high voltage drop
leroycp
Last seen: 7 months 1 week ago
lexel, I finally got around to installing your GT driver in the XHP35 MT09R and WOW! It was only “decent” before but now serious. Stock led, smooth ramp 80% NarsilM v1.2. Got a little chirp on contact charge but good now. I took your suggestion and did not bypass the springs. Great driver! Keep up the super work!!
Lexel
Lexel's picture
New generation of drivers releases now
replacing the at 2S unreliable AMC7135s
DD + small FET and resistors instead
MT03/09R XHP70.2
support of permanent switch LED plus MCU indicator with resistors
30mm for Convoy L6/ Thorfire S70S
20-22mm with 2 FETs and also 6+1 AMC
here with 1S configuration with 6+1 AMC
I had to drill out one via on the spring side partially that secures the switch pad from lifting if soldered too hot
17mm 2S with 2 FETs
17mm LX v1.0 FET+5+1
more filtering caps for very high drain builds
-X3-
-X3-'s picture
Last seen: 2 days 19 hours ago
Lexel, what should I choose to drive an MT-G2 with 2*26650, e-switch only ?
(Maglite 2D host, big aluminum pill for high current)
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Lexel
Lexel's picture
X3 wrote:
Lexel, what should I choose to drive an MT-G2 with 2*26650, e-switch only ? (Maglite 2D host, big aluminum pill for high current)
30mm LX v1.0 with no AMCs
-X3-
-X3-'s picture
No AMC ? DO you use PWM on the FET to get lower modes ?
eas
eas's picture
Not sure where the best place to ask this is, so I’ll give it a try here. I had some boards made using: your ‘new’ 17mm TA layout. I built one in a 1s configuration with an ATTiny25v with no LDO, Zener or bleed resistor using recommended components and resistor values.
I flashed it with the bistro-TAv1-OTSM-HD-attiny25.hex file provided in the Bistro-HD v1.7.1 distribution.
It works great, except for one thing. The voltage readout is wrong. It usually reads out 4.2. I may have seen it go as low as 4.1.
My understanding is that the firmware I am using reads the voltage from Vcc. So I am really at a loss as to what could be wrong. My understanding is that 1.7.1 is pretty well tested for OSTM configs, but should I be using v1.4.1instead?
Thx.
Lexel
Lexel's picture
eas wrote:
Not sure where the best place to ask this is, so I’ll give it a try here. I had some boards made using: your “new” 17mm TA layout. I built one in a 1s configuration with an ATTiny25v with no LDO, Zener or bleed resistor using recommended components and resistor values.
Thx.
It depends on the voltage drop on the diode, there is also some variation from MCU to another
voltage readout can be off 0.1V this is normal
AEDe
AEDe's picture
Last seen: 12 hours 19 min ago
Hi.
How can I buy those drivers?
I am interested in 17 and 20mm boost drivers. Is it works with low current buttons?
JasonWW
JasonWW's picture
Last seen: 3 hours 10 min ago
AEDe wrote:
Hi.
I don’t think he is selling the boost drivers yet.
Here is the thread that you can order from.
http://budgetlightforum.com/node/59724
eas
eas's picture
Lexel wrote:
It depends on the voltage drop on the diode, there is also some variation from MCU to another voltage readout can be off 0.1V this is normal
Thanks. I should have been more clear though.
The problem is that it doesn’t just reads out 4.2v with a charged cell. It reads out 4.2v even when the cell’s resting voltage is closer to 3.7v.
I also realize I have no idea what value caps to use for C4 & C5 on the larger boards.
Lexel
Lexel's picture
I got no idea what could cause this, I had never voltage readout making problems, sometimes the diode bridge was closed by solder paste and I got 4.4V readout
C3 10uF and C4 0.1uF on 2S boards
Lexel
Lexel's picture
MF01 v2 3S 14A dual Buck driver with new MOSFET and now single sided
eas
eas's picture
Thanks. I’ll have to refer to the schematics to better understand the extra caps.
I wonder if I bypassed the diode by mistake somehow. I cant remember how low I took the actual cell voltage. I know I haven’t tested it with low SoC cell, but I thought I’d check with a cell @ ~3.7.
-X3-
-X3-'s picture
Got my 30mm 2S driver today, I can’t wait to try it in my 2D Maglite !
Yourrid
Yourrid's picture
Last seen: 4 weeks 17 hours ago
Any chance you might come out with a driver for the HaikeLite SC26?
JasonWW
JasonWW's picture
That uses a boost driver, yes? I think he should be selling them soon, but not at the moment.
Yourrid
Yourrid's picture
Yes I believe it’s a boost driver. 28mm if I recall correctly.
Lexel, any hint as to what you may come up with for a SC26 replacement?
Lexel
Lexel's picture
I got atm not enough time to get ahead with the Boost, I made some progress just to run into a problem again
I ordered version 3 of prototyp boards 10 days ago, with enhanced thermal path to cool the MPS chip as I ran likely on 50W output into thermal problems I hope the new board will fix it
Lexel
Lexel's picture
Updated a few drivers with newer designs
TA drivers:
http://budgetlightforum.com/node/56618
new 17mm for 2 S eliminating AMC7135 dedicated indicator resistor and pad
20mm new dual small FET and AMCs
20-22mm
new version with 1S 3 channel AMC and 2S dual MOSFET
24-30mm
new design with added LED resistor to support new 2s 2×2 LED Boards and a little bugfix
new 2S version without AMC for more realibility, also added 2 switch LED support
46mm 2S/2P MT03
new enhanced version no more AMC7135
3 step filtering to get the rininging from PWM under control
Buck drivers:
20mm and 22mm
4 layer for better thermal properties
new more efficient MOSFET and minor changes
23mm for Klarus XT11/12GT running 2 18350s for Oslon BF or other 3V LED
30mm cheaper but bigger inductor
new with L6 compatible Ground ring and new MOSFET
42mm TN42
new version up to 8A also for TN40S mods with XHP35s
46 mm MT07/MT07S
new version a lot more efficient MOSFET
47,5mm MF02
new with better MOSFET and a lot imptrovements
46/47,5mm 2S/2P or 4S/1P AstroluxMF01/ Haike LiteMT03
MF01 v2 in 3S/6P LED Board mod, driver has 4S input 3S Output
BLF GigaThrower driver
XHP70.2 or Oslon Black Flat up to 8A
new version
also made a programming adapter for my future drivers
same order in 2 Oz from Oshpark that gives 0.8mm thickness
Order from OSH Park
Fits those pogo pins from banggood
https://www.banggood.com/100Pcs-P50-B1-Spring-Test-Probe-Pogo-Pin-Dia-0_...
Lexel
Lexel's picture
So I think final version of programming port found
rearranged pins to fit MCU pins arrangement better than original v1.0 had
improvement machanically
2 traces on the pogo pin board to self align it by the solder
increased pad size on drivers to 0.8mm, to compensate wrong pogo pins
length of the solder traces on board reduced as some flux went in the pogo top, can be solved with alcohol but more distance is better
Added a key head for easier handling
added 2 holes to use a wire strap to secure the programming wire
Picture of v1.1 on V1.0 board, pin alignment does not work on the small 0.6mm pad on first reflow
DavidEF
DavidEF's picture
Last seen: 1 week 2 days ago
You have quite a collection of drivers already! So, how many of these existing drivers will be updated to use the programming key?
- The YKK Philosophy
Lexel
Lexel's picture
over time new ones, but I have here hundreds of old boards stocked up, likely 600-800
so if I take a new board over an old I would charge something, as I am usually try to use older designs if the performance is the same
If a board got new MOSFET like on the Buck I am sitting on dead boards and parts if noone want a XHP35 Buck driver, where old parts have no disadvantage
I even cancelled the current enhancement fee for high power parts, but those 6-8A all get all new parts
FmC
FmC's picture
Very nice, Lexel Thumbs Up Beer
Lexel
Lexel's picture
new ones
already got the boards, but not time to post it
new 1S/2S combination from my LX driver
added programming port but got 33 without here stocked up
JasonWW
JasonWW's picture
When you say “LX driver” are you taking Texas_Ace’s design, tweaking it and calling it by your new name?
I’m a little confused on this.
Yourrid
Yourrid's picture
Any 28mm boost drivers in your new inventory?
JasonWW
JasonWW's picture
He has it listed on page 1. They are not available yet, though.
We just have to keep waiting.
