I was thinking of a way to reduce this back and forth international shipping cost to Maukka drastically.
Maybe Maukka (I assume he has lots of flashlight parts laying around) could choose a suitable emitter and a reliable driver and wire it to a common battery (30Q) then record the levels in his sphere minus a flashlight body. Then he just mails that to TA. Wouldn’t the exact results be repeatable?
It’s also one way shipping of a thin envelope.
You guys would have to sort out the small details such as the size of the heatsink it’s mounted to and how long after turn on to take the Lumen reading. Maybe also how to hold the emitter to the sphere. So if Maukka says he measured this emitter/driver at 44lm, 160lm and 555lm then TA can measure in a couple of his tubes to get an exact correction factor.
Maybe you guys both have power supplies? Then you can use a set voltage and eliminate the battery as a variable.
If the integrating properties aren’t perfect it’s better to calibrate using a light with a reflector, since that’s what the tube will be used for.
The S2+ on a med mode and the BLF348 are very stable so they’ll do fine.
edit: the power supply suggestion is good. TA could just send the head of an S2+ without a driver with leads hanging out from the MCPCB. If he has an accurate PSU we could just drive it at 100mA to take the battery out of the equation.
You said “affordable/practical” then comment that you’d pay double for this service. At the risk of starting to sound like an HDS fanboi lol, I’ll just point out again that they do this with every light they sell, except instead of providing a certificate of that lights output, which would just lead to pissed off customers who didn’t get the brightest samples, they tune down the high performers, tune up the weaker ones, and sell them all with the same exact certified output (but variable and undocumented runtimes). At least, that’s the claim and I have no reason to doubt them. And yes its costs double (or more) than most other similar flashlights, but I find them worth the expense. So while I agree it would be nice to see more makers doing this, you can have what you want right now.
[quote]
HDS Systems is the only manufacturer to go the final step and calibrate each flashlight. We measure the output of each flashlight after it is completely assembled and adjust the output to produce the specified lumen output. This method allows the LED to warm up to operating temperature as part of the measurement process so the flashlight's true lumen output can be measured and adjusted under representative operating conditions. Thus, our 250 lumen flashlight can be counted on to actually produce 250 lumens.
[/quote]
I think he meant something more like starting out with a Convoy S2+ for $15 and then getting it measured and then selling it for $30.
HDS is in a very different price category ($230-$300).
I got mine last Friday, but have not had time to do anything with it yet.
It looks like rain today though so maybe I’ll have time to check it out further.
I just received my sphere today too. The box was all wet because the USPS guy just left it at my door without ringing door bell last night. I won’t have time to play with it this week but will do so after and report back.
That is the diffuser, you don’t want to put the light directly on it or it could melt.
The centering rings should be inside a bubble mailer in the box. Simply pick the one that best matches the light you want to measure and lay it on top of the PVC. It should fit inside the lip at the top of the PVC.
Then simply hold the light roughly level with the centering ring, move it in and out until you get the best readings.
It should come pretty naturally once you try a few lights.
