So far I get better reading with the plastic… it is pretty consistent…
Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
I want to make my lumen tube stand like the one in the first photo…
Try losening the the closest locking ring
I will figure out… in the meantime, I tested the tn40vn90. Skylumen got 5000 lumen @30 seconds…
I got 5600 turn on… 5000 @ 30 seconds…
Olight sr96vn… vinh got 12000 lumen… TA lumen tube 12540 lumen.
Stock acebeam L16… 2100 turn on… 2050 @30 seconds…
So this tube is pretty accurate.
No heat gun. Eat your Cheerio’s Newlumen & twist that thing to where it belongs……
Yea… i am very agree. My wrist size is 206 milimeter or 20.6 centimeter… i am a small guy…
I am getting very comfortable with the TA lumen tube… I am getting better results…
Just set it like that and place your light…
More test… first one is turn on, and second number is 30seconds… batteries use were sony vtc5/5a/30q… give or take.
Malkoff wildcat v6. 1475/1408. Lg mj1
Thrunite tc20. 3820/3740. Shockli imr
Lumintop odf30. 3560/3410… oem cell
Thrunite catapult v6. 2670/2540
Fenix tk35ue. 4560/4470
Emisar d4 quad xpl. 4360/3660
Emisar d1s. 1796/1734
D4vn skylumen quad xpg2 dedome. 3580/1650
D1vn skylumen sst40 sd. 2400/2250
Fenix tk72r skylumen. 14000/13820
Pelican 7060… some box say 368 or 402… fresh off charger. 450 lumen
Noctigon m43vn xpl dedome… skylumen 11000, TA 11320
Haikelite mt09r xhp70.2 cw. 25500/22800
teacher: Newlumen:How do I make this tube stand level?? I can’t twist it anymore.: do you use heat gun ?
Just use your BLF GT for half an hour a day and watch your muscle grow
Btw, the numbers you got looks pretty accurate. Is this with the plastic sheet added at the meter or just stock from TA?
Nope, no glue or heat gun on that joint. Simple wiggle it back and forth while putting it out and it should loosen up. Then you can twist it to where ever you want.
Yeah, I agree the plastic is better for the readings, I am wanting to figure out how much adjustment the spheres need. The more data the better.
It is very difficult to get the turn on lumen number because number change quickly… but after all, we look for 30 seconds lumen…
So far so good. TA numbers are pretty close to skylumen…
Newlumen: teacher: Newlumen:How do I make this tube stand level?? I can’t twist it anymore.: do you use heat gun ?
I add one layer of grocery plastic bag. Make sure the light is stable.
I don’t know how malkoff measure their lumen… wildcat v6 is rated 1050. Maybe they are using 4 cr123 or protected 18650… we got 1400 lumen range using unprotected.
Noctigon m43vn xpl dedome… skylumen 11000, TA 11320Haikelite mt09r xhp70.2 cw. 25500/22800
I just realize you got 11k lumens for the M43vn. That seems much too high. I thought even Skylumen couldn’t boost it any above stock because it’s already overdriven from the factory, which is rated at 8,000 lumens for the XPL-HI. My M43 w/ XP-L HI v2 measured 7,000 lumens at turn on using ceiling bounce, whereas my MT09R with TA driver and TA swapped 4000k 80CRI emitters measured 22.8k lumens at turn on using ceiling bounce.
Newlumen:More test… first one is turn on, and second number is 30seconds… batteries use were sony vtc5/5a/30q… give or take.
I just realize you got 11k lumens for the M43vn. That seems much too high. I thought even Skylumen couldn’t boost it any above stock because it’s already overdriven from the factory, which is rated at 8,000 lumens for the XPL-HI. My M43 w/ XP-L HI v2 measured 7,000 lumens at turn on using ceiling bounce, whereas my MT09R with TA driver and TA swapped 4000k 80CRI emitters measured 22.8k lumens at turn on.
I bought my m43vn in September, 2016. Skylumen rated 11000 lumen, and I have it on my note…
free photo hosting
Found the spec card…
Oh wow that’s very amazing considering the size of it.
11k lumens from an M43 should be possible. I have a 12x 319A 80CRI light that does around 13k lumens, I use it as a photo light.
Found the m43vn spec card… check post #3510. I got 11320 lumen with the Sony vtc6.
Which light is that? :laughing:
I currently use my 5000k 219c MF01 modded by Lexel (I think I measured about 10k lumens) for indoor photography by bouncing light off ceiling. Works very well and allows for fantastic looking pictures.
