Nope, no glue or heat gun on that joint. Simple wiggle it back and forth while putting it out and it should loosen up. Then you can twist it to where ever you want.
Yeah, I agree the plastic is better for the readings, I am wanting to figure out how much adjustment the spheres need. The more data the better.
I don’t know how malkoff measure their lumen… wildcat v6 is rated 1050. Maybe they are using 4 cr123 or protected 18650… we got 1400 lumen range using unprotected.
I just realize you got 11k lumens for the M43vn. That seems much too high. I thought even Skylumen couldn’t boost it any above stock because it’s already overdriven from the factory, which is rated at 8,000 lumens for the XPL-HI. My M43 w/ XP-L HI v2 measured 7,000 lumens at turn on using ceiling bounce, whereas my MT09R with TA driver and TA swapped 4000k 80CRI emitters measured 22.8k lumens at turn on using ceiling bounce.
I currently use my 5000k 219c MF01 modded by Lexel (I think I measured about 10k lumens) for indoor photography by bouncing light off ceiling. Works very well and allows for fantastic looking pictures.
Everyone should know that the measurements you get with a plastic bag or whatever over the sensor is not going to be relevant to anybody else. Not all plastic bags have the same density and reduce the output by the same amount. It’s best if we all just use the bare sensor and record the higher number so that we can all compare our lights with each other. Later on we will figure out an exact number to use as a correction factor. Then we will know the correct lumens.
I’m looking at sending 3 of my stock constant current lights to a lab in Lincoln Park Michigan to get tested. But for now I’m pretty satisfied with what I got, actually I could not be happier!
So hurry up Jason or who ever, come up with something better, the other BLF members are waiting….
The procedure right now is to simply use the lumen tube as designed even though it’s reading a little high. Texas Ace is having some of his lights sent over to Europe to get tested by Maukka. When he gets those back he will figure out a proper correction factor. (For the time being we can use .65 to .70)
THEN he will experiment with materials to use over the sensor to find something that eliminates the need for math to get the lumens. Something cheap and consistent that he can buy a lot of like a box of 20 to 50 sheets of a certain paper which can easily be mailed out so we all have the same exact material. Not from different sources or even different batches. All from the same box.
I’m not completely sold on plastic bags because it may have different densities from one to the other (a Walmart bag in Indiana might be slightly different than a Walmart bag in Florida) plus it’s prone to ripping. Also, it might reduce too much light or not enough.
I think we need to find a thin material that doesn’t reduce too much light so we can use multiple layers to find the right amount of light reduction.
I’m leaning toward white waxed tissue paper. It is cheap for one thing. The sample I tried needed 3 layers to reduce the light down to the level of my JoshK sphere.
So if you want a correction factor to bring it in line with the JoshK sphere (based on mine and emarkd tests) I would multiply the stock readings by .65
.64 to .73 seems to be the general correction range. Who knows, maybe the JoshK sphere is reading a bit low and .69 is more accurate? We will have to wait and see.
