Maxtoch 32mm pad screw spacing?
8 posts / 0 new
zpinch
zpinch's picture
Last seen: 1 year 8 months ago
Like the title says, I am looking for the mounting screw spacing dimensions for the 32mm DTP pad. Are they M2.5 mounting holes?
Is the value 28mm?
Thanks.
Electric Universe theory will overtake the Dr. Seuss Big Bang hypothesis in the coming years.
“The modern astrophysical concept that ascribes the sun’s energy to thermonuclear reactions deep in the solar interior is contradicted by nearly every observable aspect of the sun.”
—Ralph E. Juergens (1980)
Thunderbolts of the Gods – The tutorial.
https://www.youtube.com/watch?v=5AUA7XS0TvA&list=PLwOAYhBuU3UfvhvcT1lZA6...
Edited by: zpinch on 05/23/2018 - 01:36
Enderman
Enderman's picture
Last seen: 4 hours 58 min ago
~27.5-28mm spacing and 2.5mm diameter.
zpinch
zpinch's picture
Thanks Enderman. Is this caliper measured?
Enderman
Enderman's picture
Yeah, measured the small holes, not the big notches.
zpinch
zpinch's picture
So you are saying 28mm would be a safe bet.
This is for 24 LEDs… just want to be sure. Smile Facepalm
Enderman
Enderman's picture
Lemme double check for you.
Enderman
Enderman's picture
The whole PCB is 31.6mm diameter.
The small holes are 28mm spacing but I noticed that the side of the hole towards the outside of the PCB is kinda squished flat somehow, so it only is 2.35mm wide in that direction.
Probably something to do with the manufacturing process.
You can just fix them and make them round again by pushing a 2.5mm drill bit or tapered rod through it.
zpinch
zpinch's picture
You are a gentleman and a scholar. Beer
Cheers.
