List of 18350 flashlights (currently available)
Subscribed. Pining for NW/WW with sub-lumen, realistic turbo (something that will last longer than 20 seconds), some throw, small as possible.
ah yes, Im dreaming of the perfect light also
Copper body, w N219b 4500k
My Copper olight s mini has 0.5 sublumen that I like. but its not 18350
as far a realistic Turbo, how many turbo lumens can you live with, and how long do you want it to last?
The D4 w 18350 cannot do 1000 lumens for long, looks like it could do 500 lumens for about half an hour
That’s decent. But I recently read something about problem with D4 sub-lumen mode, couldn’t quite understand it, like either it didn’t exist or was hard to land on with ramping.
The D4 does not have a sublumen mode in stock form. A few more facts
the lowest low is 1.7 lumens
No true overdischarge protection
Not compatible with protected cells
No reversed battery polarity protection
Uses PWM above 150 lumens, and has no constant output regulation above that.
Im not a fan, but plenty of people are.
Where can i get the 18350 tube for Astrolux s2 / BLF x6.
I tried using the s1 / A6 shorty tube but it just wont fit.
Thanks~
Armytek Partner C1 Reg and Pro
If I’m not mistaken it’s the “Eagle Eyes” tube:
But I’m not 100% sure. Hopefully someone will chime in with a definite answer.
I noticed today there’s an 18350 tube available for the Convoy S9 (S-series tube light with side switch):
https://www.aliexpress.com/store/product/18350-tube-for-convoy-S9-flashlight/330416_32859752335.html?spm=2114.12010608.0.0.727c7394ZoFjQq
Nice!
Just adding some information since I have the Astrolux MH10 with the 18350 tube — I think it’s one of the most throwy flashlight for its size (almost rivals the Astrolux S3/BLF X5). I got the “neutral-white” tint, but its tint is more on the warmer side (maybe 4500K) — the tint is very similar to the Convoy S2+ XP-L Hi U6-4C and the Astrolux S1 ‘5A’ warm-white (not similar to the S1 ‘3D’ 5000K neutral-white).
Real flat-top 18350 cells won’t make contact with the positive nipple (eg. PKCell ICR/IMR18350 — need a magnet spacer and it will work).
Using KeepPower UH1835 (unprotected 18350 1200mAh), it works properly (UH1835 is a slightly-raised flat-top).
The KeepPower P1835C2 (protected 18350 1200mAh) will NOT fit the 18350 tube at all, tried inserting from both ends, won’t fit.
Thanks for posting the info, that light always reminded me of the Nitecore MH20.
I wanted to add the MH10 to the list in the OP but since it’s out of production and unavailable I couldn’t.
Don’t forget El Cheapos:
XANES WT518 with BLF A6 tube
Ultrafire S5 with BLF A6 tube
Is the Ultrafire S5 still currently available? I couldn’t find it.
I see this UltraFire S5 but I think you’re referring to the older S5 “tube light” circa 2012-2013? (But maybe it’s still available somewhere?)
https://www.tmart.com/UltraFire-S5-LED-10W-1000LM-300M-Spotlight-White-Flashlight-Set_p374425.html
XANES WT518 is also sold under many different brand names, but I’ll add it to the Lego List. Thanks for reminding me about it.
In case anyone’s interested here’s a few links for the Xanes WT518:
https://www.aliexpress.com/store/product/2017-New-LED-Flashlight-USB-micro-Direct-Charge-Highlight-CREE-T6-Lamp-Bead-zoomable-Tactical-Flashlight/1246217_32830109187.html?spm=2114.12010612.0.0.492a2d05u3ZaIO
Review: XANES WT518 review
Rebranded S5:
https://www.aliexpress.com/item/Waterproof-Mini-LED-Torch-2000LM-CREE-Q5-LED-Long-Flashlight-Flash-Light-Lamp-Penlight-for-18650/32633950531.html?spm=2114.search0204.3.258.7a0e562cjQ9wAY&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10151_10065_10344_10068_10342_10343_10340_5722611_10341_10696_5722911_5722811_10084_5722711_10083_10618_10304_10307_10301_5711211_10059_308_100031_10103_10624_10623_10622_10621_10620_5711311_5722511_10814_10815,searchweb201603_11,ppcSwitch_5_ppcChannel&algo_expid=d1633ee8-da5e-401f-a0b1-34d3cce01ef8-41&algo_pvid=d1633ee8-da5e-401f-a0b1-34d3cce01ef8&priceBeautifyAB=0
https://www.aliexpress.com/item/Mini-LED-Flashlight-CREE-Waterproof-Lanterna-LED-5-Modes-Torch-18650-battery-Flashlight-Linterna-led-Black/32624048980.html?spm=2114.search0204.3.33.4b3a26b89VpxqU&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10151_10065_10344_10068_10342_10343_10340_5722611_10341_10696_5722911_5722811_10084_5722711_10083_10618_10304_10307_10301_5711211_10059_308_100031_10103_10624_10623_10622_10621_10620_5711311_5722511_10814_10815,searchweb201603_11,ppcSwitch_5_ppcChannel&algo_expid=05e05cc8-e68a-499b-be07-d3f7d7f932eb-8&algo_pvid=05e05cc8-e68a-499b-be07-d3f7d7f932eb&priceBeautifyAB=0
Also this Skywolf ,works with BLFA6 tube:
https://www.aliexpress.com/item/skywolfeye-Flashlight-Mini-3500-Lumen-3-Modes-CREE-Q5-LED-18650-Flashlight-Torch-Lamp-Light-l70124/32789285985.html?spm=2114.search0204.3.62.7a0e562cjQ9wAY&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10151_10065_10344_10068_10342_10343_10340_5722611_10341_10696_5722911_5722811_10084_5722711_10083_10618_10304_10307_10301_5711211_10059_308_100031_10103_10624_10623_10622_10621_10620_5711311_5722511_10814_10815,searchweb201603_11,ppcSwitch_5_ppcChannel&algo_expid=d1633ee8-da5e-401f-a0b1-34d3cce01ef8-12&algo_pvid=d1633ee8-da5e-401f-a0b1-34d3cce01ef8&priceBeautifyAB=0
It appears that Neal’s SS35-1 is available on BG as Dito XG1.
There’s aluminum Dito XL1 but the BG site utterly fails to style own shop on that site, putting all the actual content off-screen. So I don’t even know the dimensions.
I highly recommend the Eagtac DX3B mini.
It’s an excellent light.
  • lightweight. Just 64g with Aspire 18350 installed
  • excellent neutral tint that’s not greenish
  • Great UI
  • Great feel in hand
  • Antiroll
  • Quite slim for an 18350 light (22.5mm wide at head. 82mm long)
  • Excellent output: 1770 out-the-front (note the manufacturer claims around 2400 lumens, but it’s explained somewhere in the instructions that those are emitter lumens not OTF).
  • Switch is small and stiff enough that lockout is not needed for regular pocket EDC. Chance of accidental activation is very low.
Biggest downsides of the DX3B:
  • USB cover can pop out in the pocket. It’s easy to put back into place though.
  • Not sure about the battery voltage indicator. It still gives 4 flashes even with the cell down to about 3.5 v
  • Doesn’t have a real moonlight mode.
  • Not cheap
The specs say 86mm. Which one is correct?
Yeah, to say the least. :slight_smile:
Looks like a nice little light though.
I wish someone would sell a shorty tube for DQG Tiny 4th - this would make for a really small 18350 light since the 18650 version is only 87mm long. The 18350 version would be 57mm long.
I share your sentiment…
Pro variant (which supports 18650 extension) is 86, regular is 82.
The pro variant also has a magnetic tailcap, which is why it needs the extra 4mm. the regular DX3B mini has no magnet.
Eagle Eyes X1R
Amutorch AL1
(both L angle lights)
