I am sorry if I should have seen this elsewhere, but has an an XHP70.2 been run in a GT host yet? I am curious about the candella/throw figures.
Also, am I correct in understand the gt with the XHP35 is the strongest thrower in a hand-held light? Hummm, I guess Vinh can put a new type of LED in that has a smaller diameter making the whole throw process more efficient.
I am picturing Earth with 850 BLF GTs, imagining that apart from maybe a few dozen custom built exceptions, those 850, soon to be 1500, BLFGT lights are the most powerful hand-held throwers ever built. To me, that is so awesome, with a small caveat. The caveat is: it is awesome if true!
Yes, I have 2 xhp70.2 GT’s now. The first one I built with a modded stock driver a few months ago. I tested it at over 1300m of throw with the dome on and ~1600m of throw with the dome sliced off.
Lumens were around ~7000-7500.
The GT is the furthest throwing production LED reflector light in the world right now. With another LED it can throw further but at the cost of something else, either lumens and spot size or cash.
I just realized that the battery carriers are protected against flat top cells, and even my solder-blob-top cells don’t reach far enough to make contact. :person_facepalming:
It’s 2 AM and I’m far too tired to solder the carriers or more cells. :cry:
I will say the BLF GT is short compared to the TRJ-19 and TRJ-20, but the head is HUGE.
I need a handle for this thing, I was starting to get a cramped hand holding for a short bit. That said, I wish I could get an extended tube and use 3x battery carriers! :smiling_imp:
My GT arrived today. I am making a video of it performance on urban targets, such as the major league baseball stadium a few blocks from where I live.
Everything about my light is perfect. I read something a few months ago about the clicking sound in the glass from thermal expansion and contraction. I don’t remember if that is a potential problem, such as cracking the lens.
Got my BLF-GT a few days ago. As we pretty much have have daylight all the time now in Sweden, i have not been able to test it outside yet. But I’ve tested it indoors and it worked great. A couple of times. Now not so much. I get as much light out of it as a key chain led light. I have tried the factory reset, and I can see that it ramps up from very low to only low in just about 1 second. All batteries are brand new and fully loaded. When i connect the batteries the GT flashes 2 times. What could be wrong?
That is a very strange issue indeed. I would try removing the retaining clip on the driver and maybe pulling the driver out and making sure everything looks ok.
Then clean all the contact points really well and put it back together and see if the problem persists. If so then it looks like the driver is bad for some reason, it appears that the 2nd channel is not working for some reason. No idea why this would happen.
Yes to what TA said. The emitter, battery and switch all look good. It seems to be driver related. I typically mess around with the driver retaining ring on lights that have “an issue” and sometimes that fixes it.
In your video I think I see the slight blink indicating the top of the ramp even though it’s not at the 2A rate.
If this where a Q8 driver with a single 7135 and FET, I’d say the FET channel wasn’t working. This is a buck driver, though so I don’t know exactly how it’s channels are divided. So I will leave all that to TA.
The fact that it was working fine and now it does this, kind of makes me think something on the driver got fried or a component came loose.
Now I have removed the retaining ring and put it back several times. I have also looked for burnt components and bad soldering, but all seems fine, but the problem remains.
My best guess is that a replacement driver will fix your problems. Have you ever replaced a driver before? You already know how to remove the driver, it’s just a matter of soldiering 5 wires to install a new one.
This is the cheaper fix for lumintop and the one I’m sure they would prefer. Otherwise they may have to ship out that entire middle section of the light which costs a lot more and probably takes longer to ship.
I have not replaced a driver in a flashlight before, but I have quite good soldering skills, so I can’t see any problems (except for the short wires) doing it.
Now that I think about the pictures Neal posted a long time ago, the drivers already come with the switch soldered in place. Once you loosen the switch retaining ring, there are notches that allow the switch to slip through the hole quite easily.
So it’s really just the two emitter wires that need to be soldered.
