Is the lantern originally designed for two LEDs? If so, a two-color design should be feasible with four total emitters. Or if there’s too much angular shift with two of each, maybe it could do three of each? I doubt four of each would be needed, especially at the low levels the lantern is running at.
If it has two tints, I’d suggest doing ~3000K and ~5000K, or if they’re available, perhaps even warmer than 3000K.
If user-adjustable color is desired it may also be worth increasing the total number of 7135 chips, so it can reach the original brightness target at any tint. That will move the levels a bit farther apart at the low end, so the bottom end of the ramp won’t be as smooth, but it’ll probably be fine.
Since i am using the Q8 star in the V2 prototype, it now has four LEDs. Right now I plan to increase the number of the main 7135s to four (for 1.4 amps max) next week after the first field testing with the three , ( + the original one already on the driver for the low modes.
Both itsme and flashycali added for a second. Not sure why, but the second link posted by itsme does not work right, but the link in my post above does, as do the ones in this post.
Both. When i copy form google docs to a .rtf file, is spaces them twice, and cant get them to consolidate to a single line for each number as it is in the list in the OP.
Ok, send you both files in a few different formats, guessing the MHTML might be the best to try first. Here is what that one looks like when I post it, I am using Chrome, and I need to use the advanced post editor or else it gets all scrunched together.
Not sure if this will address what you are talking about but when composing a new .rtf on the toolbar just left of the ‘insert picture’ is a ‘line spacing’ tab. By default it is set to ‘1.15’ but I always change it to ‘1’ and remove the check for ‘add 10pt space after paragraph’ and it is easier if this is done before anything is pasted into the new .rtf……Hope that helps.
C
-Do any one know where i can get or source two bare PCB stars for the Q8? I need two for LED testing in the BLF Lantern project when i go on my east coast trip in a couple weeks.
