This is only for making the beam more floody, or is it for color correction as well?
About how much will this reduce the output?
do you think,its possible to change the leds for brighter? xpl…or so…i mean home custom
It’s very easy to swap the emitters, unless they decided to glue the bezel in the new batch. You won’t get much more visible brightness though.
For normal outdoor usage, the light is good as is.
For photography, indoor usage, or just hunting white walls, it might be a good idea to apply DC-Fix. This will not only make the beam smoother and floodier, but also reduce the tint shift (towards green on the edge of spill).
Would be interesting to try XP-L2, but unfortunately, that would probably require also driver changes for any major gain. Has anyone tried this on his TO46R?
You don’t need DC fix. These are standard Carclo optics. the slightly frosted 10508, and more frosted 10509 are what this light uses. The light comes with the clear Carclo 10507. I tried a 10508 in mine, and it smooths out the beam beautifully.
Thanks everybody for your input
Robert
Thanks The
Payment has been sent:
You sent $72.00 USD to 姚 巧敏
1-TO46R: $35 1-TO10R: $32 1- Extra emitter boards: $5 BLF
Thank for the updates on the process =the=! It is now closer to get the lights on our hands The light and emitters are paid!
Do we have to send you any kind of information or the info we sent to Wuben is enough?
[quote=the]
Hum, about this, I am not sure if - in terms of beam - the XP-L2 would be better! Brighter, for sure, but maye not better! I have 2 Sofirn lights that arrived with XP-L2 leds. One seemed more tending to 5000K and the other was a bit higher (5500 or 5700???).
However, both produce and yellowish and greenish tint shift similar to the one on the stock XP-G3 these Wuben lights have.
So…I am not sure if XP-L2 would be a good choice. However, a Luxeon V 4000 K, I guess that would be an interesting bet for these lights! No major shifts (or none), and a quite pleasant beam!!
But now let’s see how the leds we’re going to receive behave and that is the most important thing right now
I’m hoping there will soon be a Luxeon V 5000K
Lights are in and they are CRI90+
TO10R on high
TO46R on high
That’s good to hear, thanks for doing the tests maukka :+1:
Fantastic news. Thanks maukka!
Thanks for the tests maukka
Party-time now :partying_face:
awesome news maukka, thank you
Thank you the and maukka. Good news all around.
They are even better than first samples.
Thanks for testing maukka! I'll give Wuben a green light.
Tint graph in different modes. My sample of the TO10R is pretty good in the hotspot, but needs d-c-fix to even out the beam. I also added a tint measurement with d-c-fix and a Lee Zircon minus green filter on high for the TO46R. That’s an easy solution for the XP-G3 and makes the beam look quite pleasing.
Did you happen to measure the lumen output? I’m wondering the output of TO46R in Turbo.
Approximate numbers, not exactly at 30 sec nor did the usual sphere calibration routine, but should be within 5%.
1100 lumens for the TO46R
630 lumens for the TO10R
