14 posts / 0 new
leaftye
Last seen: 11 months 3 weeks ago
The low mode should be lower.
Edited by: leaftye on 07/01/2019 - 01:39
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 4 hours ago
I did this with my razor too, by plugging in an 18650 in a place of an AA.
Now? A 15 min job turned in a 5 min job because of how powerful it is.
It now pushes 2A instead of 1.3A, at a higher voltage too. It also has higher capacity too, so that is a plus.
I would not try putting cells in series though. Way too dangerous.
AlexGT
AlexGT's picture
Last seen: 5 hours 26 min ago
LOL
Pete7874
Pete7874's picture
Last seen: 7 hours 53 min ago
My Sonicare toothbrush has an inaccessible li-ion cell. Its most likely an 18650 cell. Too bad I can’t swap it out for a fresh one when its time is up.
Edit: I was wrong. It is actually a 14500 cell. It requires resoldering to swap out. PITA!
flydiver
Last seen: 13 hours 13 min ago
Did you get inside or find info online or something?
I tried to put new batteries in an old Sonicare with NiCads. Had to break open the case. The 2 batteries were mega-epoxied in. No way to change them.
To Air is Human, to Respire….Divine.
Pete7874
Pete7874's picture
Yes, I found a video.
https://m.youtube.com/watch?v=puHS8SY5VBo#
deleted-200707
Had a cast on my strong hand for awhile…can’t imagine using an enhanced toothbrush in my offhand…
(let alone the toilet paper fiasco)
Pete7874
Pete7874's picture
No more difficult than using a manual toothbrush. I think the electric one may actually be easier.
I used to have an Oral-B one in the past. The Sonicare diamondclean is way better, IMO.
BlueSwordM
@chinooker, I would advise you to try an electric razor that is usually powered by AAs with 14500s.
That will blow up away.
Lightbringer
Lightbringer's picture
Last seen: 4 hours 56 min ago
Don’t try turbocharging a bidet with a waterjet…
Pete7874
Pete7874's picture
Or your g/f’s vibrator… she might leave you for good.
BlueSwordM
Of course, don’t use 14500s in series, that would be just dangerous.
Boaz
Boaz's picture
Last seen: 1 hour 16 min ago
My Sonic care has stupid low frequency PWM …of course ..it follows me Silly
Scallywag
Scallywag's picture
Last seen: 10 hours 27 min ago
I used to replace batteries in rechargeable items like cordless razors and stuff.
Usually a pair of NiCd cells. Occasionally NiMh. The fun ones had LiFePO4, but the place I worked didn't carry replacements for those. Would have been easy enough to do, though.
