First thing above all, run the test several times to measure consistency.
Then, if consistently low, I’d try contacting Duodenum directly, asking about it, nicely, and see what they say. They might offer to throw some bux your way, offer replacements and you keep the originals, etc., just to try to placate you. Offer proof, as pix above.
Whatever they offer, it’s likely to be a good deal for the price spent.
If they insist they’re not at fault, that you’re the one with the problem, then yeah, make it “official” and take it up with AX. Again, offer proof, cite your earlier interaction with Dobelina.
Fellows, there are sellers from the Far East out there who may think they're going to sell more and better if they exaggerate the ratings of their products. I could even put blame on the big manufacturers as some of their stuff does not meet their wrap specifications, at least the way I see it. This is a deceptive business model which I do not like, and if we aim to change this (as with any other thing worth to be fixed) we are to set aside with our communication fears and tell 'em where they are doing wrong, in a rage-free and respectful way, and see how can we contribute to fix this.
Exactly, which is why he should just contact Didgeridoo directly and ask them nicely what’s going on, then hear what they have to say, and hopefully offer. A few bux back makes them cheaper. Extra/Replacement cells means getting more cells. Either way it’s a win/win, just for asking. And it kinda puts them on notice that people can ask for what they paid for, even if “discounted” in price (ie, “getting a deal”) or exaggerated claims.
If they get bit a few times, it’d pay for them to list them more honestly at 5000 and have people be happy they got better-performing cells, instead of 5500 and feeling cheated.
And if not, p&m to AX and let them whap them into line.
Guys…thanks a lot for your help! I’m afraid things are now even more complicated than originally expected…
Yesterday, I did an additional NOR test (C-D-C cycle) on three Samsung 35E and one Sony VTC5A…all of them are flat tops. The 35E has a nominal capacity of 3.500mAh, the VTC5A has 2.600mAh. Now, if you have a look onto the picture below it becomes clear that the Zanflare C4 is “a bit high” on all cells I have charged so far. The charger was in stage 3 of the C-D-C cycle when I took the picture revealing the capacities. iR readings were collected before.
That takes me to following conclusion:
My Zanflare C4 is absolutely inappropriate for measuring battery capacities, not only because it indicates too high values but also because slot #2 always indicates around 75-150mAh more than the other slots. It makes me wonder if it’s just counting wrong or if the device really “over-dis-charges” the cells. I doubt the latter case but how can I be sure? However, the device appears to stop discharging at 2.8V and charging at 4.20V as it is meant to be.
Most probably, my C4 is not a “faulty” one but more likely the product itself seems to have some kind of a design flaw when I compare my results with HKJ’s statement that measured capacities are “a bit on the high side”. I muss confess I was not aware of the right meaning when I read it first, so I still bought this device. However, iR readings seems to be fine as you can see on the secound picture.
Now, taking into consideration that all 18650 cells probably indicate too high values (up to 10% more on slot #2) it puts the Dolidada - the name reminds me in a fittingly way of dadaism by the way - into an even worse light. The actual capacity at 0.5A discharge current could be more around 4.700mAh instead of 5.000mAh - while the shrink label lets you think you bought a 5.500mAh cell. If you have received high dran KP cells with 5.800mAh under the same Dolidada brand in the past you’ll be even more surprised.
So, now I have mixed feelings about both the charger and the Dolidadas. There is no way to recalibrate the C4 to correct values, is there?
Danke Dir light-wolff! Those 30Qs were from NKON which is to my mind a trustworthy reseller from the Netherlands. So, as I stated above this post - the charger seem to be inaccurate.
Thank you, also for checking your 30Qs capacity for comparison. I will repeat the test with my MC3000 and report back.
Thanks Lightbringer! Your comment made me start to smile…“Didgeridoo”…haha. Yeah, I’m gonna ask the seller about his opinion. I just need to eradicate all the other variables in the equation before (i.e. to assess the capacity in the MC3000 for comparison). According to the charger I’m not sure how to proceed. If I ask Gearbest they would - in the best case - probably just send me another inaccurate C4 charger.
…as a result of all comments ordered 5 dolidada for $18.59 .Good price for 5000mAH battery and the name it’s so beautiful.
I will test with my original Lii-500.
from what i see peeking up from the + end those look like the ebl 5000 i got a bunch of.
every one was above 5000 after 2-3 cycles.
but the results with your 30q’s leads me to believe that analyzer is inaccurate.
That’s my long-time observation too….when I started in this hobby almost 6 years ago, I started out with laptop pulls only, no analyzing chargers then, the reason why I got the iCharger (and the Pila IBC and Maha C9000) at that time.
I remember that the only time a cell rating had actually reach or exceed by a bit its mAh rating on the lable from reputable manufacturer is when I set my iCharger to discharge down to 2.50V.
Innacurate cheap analyzing chargers? Welcome to the real world fellows. The current sense resistors used by these devices feature 1% tolerance, let's just start with this, and there are more variables over the table. I believe my Lii-500 measures close to 2% less, based on my observations for various cells.
