Guys…thanks a lot for your help! I’m afraid things are now even more complicated than originally expected…
Yesterday, I did an additional NOR test (C-D-C cycle) on three Samsung 35E and one Sony VTC5A…all of them are flat tops. The 35E has a nominal capacity of 3.500mAh, the VTC5A has 2.600mAh. Now, if you have a look onto the picture below it becomes clear that the Zanflare C4 is “a bit high” on all cells I have charged so far. The charger was in stage 3 of the C-D-C cycle when I took the picture revealing the capacities. iR readings were collected before.
That takes me to following conclusion:
My Zanflare C4 is absolutely inappropriate for measuring battery capacities, not only because it indicates too high values but also because slot #2 always indicates around 75-150mAh more than the other slots. It makes me wonder if it’s just counting wrong or if the device really “over-dis-charges” the cells. I doubt the latter case but how can I be sure? However, the device appears to stop discharging at 2.8V and charging at 4.20V as it is meant to be.
Most probably, my C4 is not a “faulty” one but more likely the product itself seems to have some kind of a design flaw when I compare my results with HKJ’s statement that measured capacities are “a bit on the high side”. I muss confess I was not aware of the right meaning when I read it first, so I still bought this device. However, iR readings seems to be fine as you can see on the secound picture.
Now, taking into consideration that all 18650 cells probably indicate too high values (up to 10% more on slot #2) it puts the Dolidada - the name reminds me in a fittingly way of dadaism by the way - into an even worse light. The actual capacity at 0.5A discharge current could be more around 4.700mAh instead of 5.000mAh - while the shrink label lets you think you bought a 5.500mAh cell. If you have received high dran KP cells with 5.800mAh under the same Dolidada brand in the past you’ll be even more surprised.
So, now I have mixed feelings about both the charger and the Dolidadas. There is no way to recalibrate the C4 to correct values, is there?
Danke Dir light-wolff! Those 30Qs were from NKON which is to my mind a trustworthy reseller from the Netherlands. So, as I stated above this post - the charger seem to be inaccurate.
Thank you, also for checking your 30Qs capacity for comparison. I will repeat the test with my MC3000 and report back.
Thanks Lightbringer! Your comment made me start to smile…“Didgeridoo”…haha. Yeah, I’m gonna ask the seller about his opinion. I just need to eradicate all the other variables in the equation before (i.e. to assess the capacity in the MC3000 for comparison). According to the charger I’m not sure how to proceed. If I ask Gearbest they would - in the best case - probably just send me another inaccurate C4 charger.
…as a result of all comments ordered 5 dolidada for $18.59 .Good price for 5000mAH battery and the name it’s so beautiful.
I will test with my original Lii-500.
from what i see peeking up from the + end those look like the ebl 5000 i got a bunch of.
every one was above 5000 after 2-3 cycles.
but the results with your 30q’s leads me to believe that analyzer is inaccurate.
That’s my long-time observation too….when I started in this hobby almost 6 years ago, I started out with laptop pulls only, no analyzing chargers then, the reason why I got the iCharger (and the Pila IBC and Maha C9000) at that time.
I remember that the only time a cell rating had actually reach or exceed by a bit its mAh rating on the lable from reputable manufacturer is when I set my iCharger to discharge down to 2.50V.
Innacurate cheap analyzing chargers? Welcome to the real world fellows. The current sense resistors used by these devices feature 1% tolerance, let's just start with this, and there are more variables over the table. I believe my Lii-500 measures close to 2% less, based on my observations for various cells.
I wrote an honest review about the Zanflare C4 on Gearbest’s website. After that, their customer service team contacted me in order to solve the issues I have with my device. I explained in detail about the high deviations concerning the capacity measurement incl. the fact that charging slot #2 always indicates much more than the other slots.
So…eventually, this is what Gearbest calls “problem solution”. Thank you very much! :person_facepalming:
Dear Thomas,
Thank you for your patiencer.
This charger comes with a volume detection function. Voltage accuracy deviation 2; Current accuracy deviation 5; Time accuracy deviation 1. The capacity is tested by charging voltage, current, and time calculations. Due to the fact that it is not a special compartment, the current market can only achieve a 10 accuracy deviation.
The use of interference Including factors: such as the ambient temperature, humidity, battery type, if the battery installed contacts are good or not and so on. For example, if use different brands of the sub-capacity tester to test, there will be some deviations.
