yes, i've been assembling the pieces for quite some time. 5 drivers will arrive this week. They were going to be modified and sandwiched but I'm much less likely to toast $100 worth of xmls using the KD driver...
it actually isn't very big at all - roughly stanley led spotlight size...
the emitters have been ordered (but are coming from HK). The only other part I'm lacking is the relay, but I'll probably just buy one from radioshack (local) when I get ready to wire the switch...
actually, I need to check if DX backordered the reflectors.....too many orders w/ them and I haven't updated my spreadsheet
this driver makes me MUCH more comfortable w/ this expensive endeavor - good chance I'd screw up the home brewed version...
The TR-J12 would be able to do low 4000 lumens OTF with the 5 LEDs driver. Not sure if it fits though... That'd be a good use for the MKNE or King Kong 26650s. Not sure if the switch can take it, but it should.....
is there a benefit to mosfet switching vs relay? I want to retain the stock switch from my host and I'm not sure how to do that w/ a fet, plus I can get the relay locally and relatively cheap...
Yes, they're MOSFET based. More likely this one: http://www.onsemi.com/pub_link/Collateral/NTMFS4835N-D.PDF
I bought one of the similar drivers at Kaidomain last month. I'm planning to build a triple XML U2 IC in a Maglite. I already have the LEDs from Cutter Electronics.
Here's the one I bought: http://kaidomain.com/product/details.S020121
Thermal conductive adhesive to smash between circuit board and body
I am a tech not but like TO-220 size because of mount and easy solder tabs. I used one on my Phatlight PT120 and a DX cheapo switch to activate. Was able to keep stock Mag switch location and machine the massive copper heasink (from front of Mag tube to back of old switch length) to house the mosfet internally. I'll try to take some pics possible to illustrate. Am currently working on several high amp projects (DD & CVCC) that may need to be mosfet switched. Have this on order and have been patiently waiting http://kaidomain.com/Product/Details.S020079
On the phone or would post this pic. I don't remember where it came from and hate to plagiarize but here it is http://imageshack.us/photo/my-images/503/fmosfetschemmjimmymos7.jpg/
Cuz of the low voltage was able to eliminate one of the resistors and used a 6.8k (had some) instead of the 10k. Search Lambda builds. I suffer from CRS but recall having issues with the positive ground on the PT emitters. Machined Teflon/plastic insulators to isolate components. This may or not be an issue with pcb mounted emitters.
