There are only 3 Hicri led in the shop I used.
1)351D 4000K 90cri
2)351B 3000k 90cri
3)XPG3 5700 90cri
All other variants available on order whith minimum 800-1000pcs with lead time obout 6 weeks.
If you need at least 500pcs. 351D 3000K 90cri(300pcs I can take for myself) we can arange order, but with a prepayment condition. I not have vacant >1000$
Mmmkay, for the time being sign me up for another bunch of 10x LH351D 4000K CRI90+ AEDe.
Already set and tested 6x for a room lamp under construction, and 2x in S2+ hosts with 30º TIRs. Had to reflow one for an S2+ twice, and I'm measuring at least 8% less light flux from its torch vs the other all else being equal. Wow…
Sorry if this is off-topic, but for the sake of completeness I have to add the explanation. The variation I measured in light flux between my recent S2+ builds isn't caused by faults in my reflow process, which I already have well mastered and allows me to do away with potential temperature related emitter damage. It is due to lens quality variation: Cree 30 Degree Angle Optical Lens (5-Pack) @ FastTech. Out of my 5-pack of lenses one is clearly brighter, the next two are good and about the same, the 4th one is a tad less bright but close, and the 5th one another bit less bright. Brightness delta between best and worst is ≈15%. Nuts…
Measurements and other data made me consider additional 30 pieces - probably will make several direct driven triplets and/or quads, thank you for your published measurement, djozz =)
I will ask manager of e-neon about 351D hicri in other CCT and will try to make GB. but it needs a lot of people, at least 400-500led shold be “preordered”
